Rotate the mode dial to A. Press and hold the exposure compensation button and press up or down on the selector to change the aperture. For full details see page 28 of this manual.
The Fujifilm Finepix HS10 camera features a manual aperture ring on the lens barrel. If you're experiencing issues with the aperture not functioning when you turn the ring, there are a few potential causes and troubleshooting steps you can try:
Check the camera mode: Ensure that the camera is set to Manual (M) mode or Aperture Priority (A) mode. In these modes, you should have control over the aperture settings. If the camera is in a different mode, switch to M or A mode to enable manual aperture control.
Enable aperture ring control: Some cameras have a setting that allows you to enable or disable the use of the aperture ring on the lens. Check the camera menu or settings to ensure that the aperture ring control is enabled. If it's disabled, enable it to regain control over the aperture.
Ensure the lens is properly mounted: Check if the lens is securely mounted to the camera body. If the lens is not properly attached, it may result in the aperture ring not functioning. Remove the lens and then carefully reattach it, ensuring it clicks into place.
Clean the electrical contacts: Dust or debris on the lens contacts or camera contacts can sometimes interfere with communication between the camera and lens. Use a clean, lint-free cloth to gently wipe the contacts on both the lens and camera body. This can help ensure proper electrical connections.
Update the camera firmware: Visit the Fujifilm support website and check if there are any firmware updates available for your Finepix HS10 camera. Updating the camera's firmware can address potential bugs or issues that may affect the aperture functionality. Follow the instructions provided by Fujifilm to update the firmware if necessary.
If you have tried these troubleshooting steps and the aperture ring still does not function as expected, it is advisable to contact Fujifilm customer support or take the camera to an authorized service center for further assistance. They will have the expertise to diagnose the specific issue and provide appropriate solutions or repairs if needed.
The lens on the S2980 only opens up to f/3.1, and that only at the wide end of the zoom range. At the wide end the only available aperture settings are f/3.1 and f/6.4. At the long end they are f/5.6 and f/11. See the specifications on page 119 of the manual.
In general, compact cameras simply do not give you the control that larger (heavier, more expensive) SLRs do.
Try blowing ******* the lens. If it doesn't work, hold your camera with the lens facing the ground and tap your camera repeatedly so any dirt inside the lens mechanism will fall out.
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
One problem with many point&shoot cameras is that they expect you to point and shoot, without fiddling with things like aperture and shutter speed. This camera doesn't give you any direct control over the aperture, which is restricted to a range of less than one full f/stop in any case. About the best you can do is to select the Portrait or Sport mode when you want a wide aperture and the Landscape mode when you want a small aperture.
