Question about SanDisk Sansa Clip MP3 Player
When I turned on my sandisk I pushed something and now there is no sound. In the "window" there is a little solid block that I can't figure out how to get it off. HELP!
All you have you do is go to your computer and put da USB cord and whene something comes up.........poop!!!!!!!!!!!!!!!!!!hahahahahahahahahahahahaha
Posted on Jan 30, 2009
Saeco vienna plus red solid light cannot prime water line
Make certain the line from the water resource is cleaned and not obstructed. If the pump fails to move the water from the reservoir to the heating tank, then the pump needs to be replaced.
Mar 25, 2014 | Saeco Vienna Espresso Machine
Logik refrigerator lfc50s10 has a blocked drain hole how do i clear it
Logic fridge/freezer
no! I pushed a plastic coated flexible steel wire down the hole and it hit something solid after 2 feet, I pushed it up from the bottom and it hit the same solid. it feels like plastic, I blew down the pipe in the top hole and water blew back. Water is not flowing down.
Mar 01, 2012 | Refrigerators
Yesterday morning I turned the water on to get in the shower and realized the hot water wasn't working I figured it was just something little but this morning I realized that the hot water is still not...
If this is an electric water heater, you should see a little access panel on the side. This contains the thermostat and, most importantly, the circuit breaker. It'll be a little red button you push in. If it pushes in, you've found your problem and you then enjoy a nice, hot shower!
I hope this helps! :)
Jan 07, 2011 | Rheem Water Heaters
My mouse works but is flaky! Mouse icon is
I just wanted to say Guru's probably right. I had this same problem and realized my cell phone was right between it. Moved the transmitter a little closer, moved my phone, and it works like a charm.
Mar 06, 2010 | Logitech LX6 Mouse
I have a 2005 Chevy Malibu and the drivers side door does not seal properly at the top of the door and the elements leak in. How do I fix this?
What sometimes happens is something gets caught in the door when closing and bends the window frame out. If your hinges and latches are not worn out and the door opens and closes properly this solution should work for you.
Place a block of wood between the inside bottom of your door and the rocker in a solid place. this will allow you to push gently on the frame around your window (roll the window down). Try a little at a time and open and close the door as you do this.
Be careful, they are not as strong as you think and going too far may create a metal kink.
Nov 15, 2009 | 2005 Chevrolet Malibu
Icemaker not making ice
check your fill tube
it might be frozen solid
Oct 02, 2009 | Refrigerators
It will not turn on any longer
the problem lies within the mp3 all you got to do is fisrt.becarefull and take it apart once you have the other layer taken off then take the back off then at te top where the power button was there should be a lil square take something small and push in the lil square and it should come on the reason it wont cut on any more is due to the power button. the lil hole at the end of it is missing the part that normally pushes inside the square button is missing you will have to figure something from there to turn it on.i had to rig mines and your welcome.for further information you can call me at 771-3337
yours truly C.3.C
May 19, 2009 | SanDisk Sansa Clip MP3 Player
Stuck in language mode
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
May 13, 2008 | SanDisk Sansa e260 MP3 Player
Unable to get anything onto the computer
the cd is only for windows 98. Do not use it for windows 2000, xp or vista. if you did you need to uninstall the drivers
Feb 08, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa c150
hmm, sounds like the hold button may have a faulty connection. have you checked that it's fully pushed to the left (ie unlocked)?
Oct 22, 2006 | SanDisk Sansa c150 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
21 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
