Question about Powr Flite PD2500 Handheld Vacuum
Powr-flite PD 2500
I need a control knob (speed control, on/off) for a powr-flite PD 2500. Where can I find one?
I need a control knob (on off and speed) for a powr-flite pd2500, any ideas when I can obtain one
Posted on Feb 26, 2008
Eleven ********* stop flite297 Alanta to Houston
The details are not clear and some media outlets have sensationalised the incident to the point where the actual events are mixed in with reports from December 2009.
Even Snopes.com could not verify the tale.
http://www.snopes.com/politics/religion/flight297.asp
Aug 15, 2014 | Vacuums
How do you remove the filter in the waste tank, does it screw or do you just pull it off?
Hi from what i have read about your steam cleaner thr filter should just lift out, failing this, give it a bit of a wiggle to help release it
hope this helps
Mar 03, 2011 | Powr Flite PFX1380 Steam Cleaner
My pump blew need a new one which one is it
In the event you do not have a manual, though it sounds like you do, you can find one at this URL:
http://www.powr-flite.com/text/powr_pdf/manuals/extractors/PFX1350_Manual.pdf
The location and telephone number of the company is at the bottom page of the URL. They are located in Ft. Worth, Texas and should be able to provide you with the information and part you need.
If this solution is of help to you, I would appreciate a Thumbs Up.
Be well. Paul
Oct 05, 2010 | Powr Flite PFX1350 Upright Steam Vacuum
Hoover SteamVac brushes aren't turning ...
Sometimes this speed knob can be really stuck on there. Even if you were to break off the part that the knob sits onto, this part is actually part of the turbine assembly, and the new turbine assembly would have that prong that the button sits on.
As long as you have the screwdriver underneath of the knob, I wouldn't worry to much about putting too much pressure on it.
Let me know if you still have any questions, I'll be happy to help you figure it out.
If you found this helpful, please be so kind to rate the repair that I wrote, or leave feedback.
Thank you,
Chris Jones
GoVacuum.com
May 27, 2010 | Hoover V1 SteamVac SpinScrub Vacuum
Why does battery die so fast
use till battery is dead, then put a full charge one it, if it has water ports, check to see if at proper level, if still bad, take to have tested, look in phone book(batteries) if it test ok, charger is bad
May 19, 2010 | Powr Flite PAS20DX Canister Vacuum
Tornado wide area commercial vacuum
Hi There,
Your Tornado Wide Area vacuum cleaner is actually manufacturered by Powr-Flite. The two companies are sister companies, and owned by the same parent company Tacony.
It sounds like to me that your belt may have broken, or fallen off of the motor shaft. This may explain why the roller brush is not spinning. There is also a reset switch on the machine, on the top (item # 41 in diagram below), you should check the reset switch first. Try pushing down on this switch to see if this will restart your brushes.
If it doesn't, here are instructions on how to open up the belt, and inspect it or replace it if it's broken:
If you need to purchase a new belt, you may contact Powr-Flite at 1-800-880-2913, and request them to send you part number 19802.
Here's links to the instruction manual, and parts diagram for your Tornado, which is the same exact machine as the Powr-Flite model PF2030:
Owners Manual & Parts Diagram
If you have any follow up questions, please don't hesitate to ask using the add a comment form here on the Fixya repair page. If you have any problems ordering from them directly, feel free to contact us, and we'd also be able to provide any parts for you.
Here's how you may contact us:
http://www.govacuum.com/info.html
Thank you,
Chris Jones
GoVacuum.com
Apr 16, 2010 | Tornado 93030 Wide Area Carpetkeeper...
Low suction
Replacing the motor cover solved the problem, it must have been warped and was letting suction out thru it.
Jan 03, 2008 | Vacuums
Powr Flite PD2500 Handheld Vacuum Logo
244 people viewed this question
Top Powr Flite Vacuums Experts
Marvin
Marvin
Are you a Powr Flite Vacuum Expert? Answer questions, earn points and help others
