Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Hooking up a dish network to my tv
I have a HD Sharp Aquos t.v. So I went to hook up a dish network cable to my t.v and I only get a few channels for the sky. none from my dish network can you help me?
    Scholar:
  • 118 Answers
Well, I don 't have that T.V. but I can tell you that you may have to go to your menu and look for your channel setup and change it to another channel output. If that doesn't help then have it search for channels.
Posted on Jan 30, 2009
Want to run Dish network DVR 2nd TV thru cable to Sharp lc-c5255u Dish uses channel 73. It was not on my TV. I did a channel search and it did not find it. It also erased all channels and I can't...
Go into the setup menu and do a channel search again selecting digital and analog channels. Then change the input type to cable and you should get your channels back.
Aug 31, 2011 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Does the sharp Aquos LC-52 support HDCP? I have Dish Network and for some reason can't watch any HD PPV channels, Dish Network says it's a TV issue. Can you help?
DISH Network blocks multiple video outputs on all PPV and most premium content to prevent recording, and they will tell you it is a TV issue. Ensure that your receiver only has one video cable coming out, to only one device (ie HDMI to the TV) and try again.
Oct 03, 2010 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
Digital signal for my Sharp Aquos
Hi
On the TV menu did you change it from Cable to ANT?
Mar 13, 2010 | Televison & Video
Sharp Aquos LC 32G4U not receiving any channels-
Most locations are real hard to get local stations using indoor antennas. If you are in a location where you do not have cable, I would try either a outside antenna on the roof or go with Direct TV Dish / Dish Network system.
I hope this helps,
Skyassoc
Jan 04, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Speaker distortion on SHARP 37" Aquos Hi Def
When you are changing channels you are using the tuner of the sat reeiver. the tv does not know you are changing a channel . It is just receiving a constant signal from the SAT receiver. I would suspect a problem with the receiver. Try another one first .
Apr 24, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
New Sharp Aquos LCD 46 TV
If you hooked up the satelite box to your tv Automaticly the Satelite box is the one who pick up the channels (from the satelite)
In this case your tv is acting as a monitor only. Try to connect your tv with HDMI cable or COMPONENT cable for best picture. Don't use RF antenna input to hook up your Satelite Box. Hope this Helps
J
Dec 28, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Sharp aquos vertical black line
Call Sharp at 1-800-237-4277. There are firmware upgrades that this lcd needs to resolve issues. Good luck!
Nov 15, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Need help setting up My Sharp Aquos LC-32D44U, also volume issue
GA293wJSA my friend gaveme this sharp tv. Nothing happens after I plugged it in I just get a blue screen what do I need to do to view a picture?
Jun 12, 2008 | Televison & Video
Turn off closed caption on input(component) on Sharp Aquos 42"
I have a Sharp Aquos 46" and go a Comcast HD receiver as well, and had the same problem turning off the Closed Captioning. I order to turn it off you need to go into the box user setting by (starting w/ the cable box and tv on) pressing the power button for the cable box then the menu button for the cable box. This will open up the user settings menu. Just toggle CLOSED CAPTION to DISABLED.
Jan 29, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Connection problem
The best hook up for this unit is to use the hdmi if your samsung box offers hdmi output. The panasonic vcr should be hooked to any one of the composit video inputs with the yellow video cable and the red and white audio cables. If the vcr does not have composite output then use a rf (coax cable) to antenna a input and put the tv on channel 3 or 4 as vcr is set for.
Jan 13, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
365 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
