Question about HP Photosmart M425 Digital Camera (5MP, 3x, 1.7 ) Commercial Channel only
Card Format When I start up my camera, I get an error message saying "card has wrong format - press OK to format card", but when I press OK, I get another message saying "unable to format". ...help?
  • msconsulting Jun 13, 2008
    My camera gives the same message but the card is not corrupt.. It works in another M425.
    The camera will not let me reformat the disk either.
    Is their a firmware rest on the camera somewhere?
  • buskohl75 Apr 11, 2009
    says wrong format but then says cannot format nothing looks bent I cleaned and it still does not work
    President:
  • 2,961 Answers
The card may have become corrupt, try carefully cleaning the contacts with a pencil eraser and try again,or try formatting it using a card reader, but you may have to replace the card.
Posted on Jul 28, 2007
SOURCE:
How do I format sad card (32g) for my hp photosmart r927
Look for small (tiny) slide switch on side of card to unlock it.
Mar 09, 2015 | HP Photosmart R927 Digital Camera
I have a xd picture card H512mb and it has stopped working - an error message saying 'card is not innitialised' comes up on camera screen. Is this fixable?
If formatting the card doesn't help, the card is probably defective.
To format press Menu/OK / Setup / Format / OK.
Formatting will delete the card.
Feb 07, 2010 | Fuji FinePix S9500 Zoom Digital Camera
Card error
If you get a message as "Memory Card Error" on your camera AND you still need some of the photos , the first step is to format the card through the camera menu (Note: if you have an sD card, once you re-format your card any photos cannot be recovered.). check your camera manual to see how to format your memory card. If this does not help, try another memory card (say the small 16/32mb card that came in the box with the camera). If this card does not display a "memory card error", then the other card is at fault.
To format* a memory card:
(*instructions on formatting memory cards can be found in your camera's user manual) you equally format the card using your computer if the above method fails,if the micro sd card is inserted into the sd slot of your system the computer sees it as a storage device in that way you can format it the usual way you can format a drive on your system but mind you if you have valuable pictures on it ,they will be lost but in that case you can use the low level format utility
Jan 06, 2010 | Olympus SP-700 Digital Camera
It says picture error for every picture and cannot delete photos individually. One minute it said card full then every photo said picture error and switched itself off. Its not a happy camera
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the picture error messages and the card can be used again.
Apr 27, 2009 | Olympus FE-190 Digital Camera
Wrong format on HP M425
Just fixed this problem on a M525 camera (same physical construction).
Do a search with M525 and format.
Feb 10, 2008 | HP Photosmart M425 Digital Camera
Card will not format
memory card? and SD card? whatever the card hook your camera to a usb to computer and find it under "my computer"
look at all your drives you should have like c, d , e, f, g, h, select the last drive and see if it finds your card if so try formatting it through the computer, whatever you do dont select c or d to format. if problem persists buy a new SD. I find good deals on ebay or Walmart.
Dec 23, 2007 | Samsung S850 Digital Camera
Need help formatting PLEASEE!!!!
This is Vikram Kumar Thumu from India-Hyderabad. I have seen your message on the issue related to the Error message stating that Wrong Format. I would like to provide my suggestions on the issue.  I hope that this should work and will resolve the issue for  you.
If this is exact error message then try :
"CARD HAS WRONG FORMAT. Press OK to format card. "
Possible cause is : The memory card is formatted for a different device such as an MP3 player.
Solution : Reformat the memory card (remove the card from the camera if you do not want it to be reformatted).
I hope that this should resolve the issue.
If the issue still persists then you can take help of HP Chat Support.
For your convienience, I'll provide the link for you.
Hmm, this is the link to visit HP chat Support for  your Camera
link is :
http://tinyurl.com/3x6rev
Open the link and fill the information and this will get to the HP Chat support and I am sure that this will resolve the issue for you.
Bye.
Oct 22, 2007 | HP Photosmart M425 Digital Camera (5MP,...
HP Photosmart M425 Digital Camera (5MP, 3x, 1.7 ) Commercial Channel only Logo
302 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
