Question about Kodak EASYSHARE 5100 All-In-One Printer
Images print to light to see
I wonder if I need to install a new printhead--I have changed the ink cartridges-that didn't heIp--- don't know what else to do
    Genius:
  • 2,035 Answers
Please follow the steps to clean the print head and install it try to print
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Posted on Jan 30, 2009
I can't print with the black ink. I performed a print head cleaning, and then I printed the nozzle check pattern. I noticed that the Cyan, Magenta, and Yellow shows up. However, the black checkered...
Simple problem that print head cleaning will typically not fix. The black ink is pigment based so it tends to form more stubborn clogs. Just remove the print head and if you have a steamer hit the black printhead nozzles with some pressured steam. If not available, soak the surface of the printhead in shallow hot water (try not to get the contact wet or be sure to dry them if you do). You can tell if the printhead nozzles are open by folding a section of wet paper towel like 5-10 layers and then soak it, press the printhead surface up and down lightly on the wet paper towel and if the nozzles are open you will see some ink pulse in the black port screen (the colors will also pulse from the pressure of the liquid under the printhead). It's easier than it sounds so give it a try. I've saved 100s of Canon printheads this way.
Note: if you have a really dried out head, you sometimes have to soak from the top inlet ports and the bottom nozzle surface to clear, but unlikely in you case since you had a black cartridge installed with ink in it (this keeps the top port from drying).
Sep 15, 2011 | Canon MP520 All-In-One InkJet Photo...
I have an all-in-one Kodak ESP 3250 printer. Bought it 4 months ago. I'm interested in printing only in black, but now the color cartridge has emptied and it won't let me print with the black cartridge...
The KODAK All-in-One Printer uses an advanced built-in printhead. The system is designed to provide excellent image and text quality, while eliminating the need to purchase new printheads every time you replace ink cartridges, and saving you money. The printing system requires that both the black and color ink cartridges be installed to print. If either cartridge is not installed or is out of ink, the printer or printhead will not print correctly.
Install the color a new cartridge, avoid damage to the print head.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 15, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
Can the printer print with just a black ink cartridge?
Thanks, Joe
Jan 19, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
Color Copies - double image
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Dec 10, 2009 | Konica Minolta bizhub C250 All-In-One...
I have installed new ink cartridges but when I print, no text appears on the page and the images are in pink/red and very faint. I have tried cleaning the head and checked the nozzle but no change. Anyone...
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
Don
Nov 30, 2009 | Epson Stylus C66 Inkjet Printer
Easyshare 5500 prints very light even after cartridge replaced
Hi!
You'll need to call KODAK to get a new printhead. The # is 1.800.421.6699. This is a very common issue, and they will give you a new printhead and a set of new ink.
Jan 28, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Toner alarm stays on with new cartridge
Printhead is dried up and may need to be replaced. The printhead usually has a life kinda like the inks. You should be able to find a printhead from your local fax repair shop and installation should be simple. Once replaced you may install inks and run several cleaning cycles. Please let me know if this helped.
Jan 23, 2009 | Office Equipment & Supplies
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
22 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
