1992 Honda Prelude Logo
Posted on Jan 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I hear a clicking noise when i make a turn
I just bought a prelude of the street for 1500 hundred theres nothing really wrong wit it but just this clicking noise that i hear when i make a turn either right or left. The noise only seems to happen when i push on the gas the most. even at like 1mph. and most of the time i dont hear it when i am not pressing the gas. Sometimes i hear it but not as bad as if i were to push on the gas,,.... =) can an1 help me plzzz.
Anonymous
Level 3:
  • Master 491 Answers
  • Posted on Jan 30, 2009
Anonymous
Master
Level 3:
Answers
491
Questions
Helped
196341
Points
1413
You need to replace both front axles.
I have a pontiac g5 gt 2008. I just got it and its gm certified. I noticed that when i turn or am traveling on gravel there is a noise inside the steering. I don't know how to explain it best, maybe a...
traveling on gravel roads vechicle make all kinds noise due to vibrations.if you only hear noise on gravel road not much wrong if you hear noises all the time you have problem.
4wd grinding
It could be your differential nut on the input shaft of the front drive has backed off and causing the noise you hear when in 4x4 mode.
1994 Honda Prelude si starting problems
Your starter motor is either not getting power or in need of replacement. Otherwise, there is nothing wrong with your car.
Also check your battery connections for no corrosion there as well as by the starter motor. Low voltage circuits in a car are extremely vulnerable to poor contact issues.
When it rains my dodge ram 1500 will stall. After awhile of sitting it runs again. Aside from this I hear a water noise coming from under the dash in the cab like it in the AC, Heater or Vacuum hoses. I...
my 98 has the same water noise. i went to a well established garage and asked the owner. he and his brother both have rams and have the same noise. i guess its a ram thing. its coming from the heater core. they said its nothing to worry about. his done it since he bought it 6 years ago
I just bought a 93 prelude with the 2.3l vtec the guy said that the engine was just rebuilt it has the dohc engine the valves are clicking he told me to run the car so the valves will seat??? then he...
not really. The engine uses hydraulic lash adjusters, so there is nothing for him to adjust. If the engine has been run at all, the valves should be seated. If not, maybe the guides were over-knurled. Can't really tell why they are clicking. Can he provide specifics of what was done to the engine? Does it have new lash adjusters? Were the guides knurled or what was done with the guides? What was done to the valves? Are the springs new? Are the camshafts new? etc. etc.
1helpful
1985 Honda Prelude replaced alternator and regulator trouble shooting wires, battery light still comes on
I had an 84 Prelude with a similar problem. I will assume that the car runs just fine as though there is nothing wrong but has the light on. When this happened to me it was just a bad diode in the alternator. If the battery takes a load fine and shows good charge then take off the alternator, take it back to autozone or wherever you bought it and have them test it. I would bet there is a diode bad and they will give you a replacement. Good luck!
WHEN I TURN THE IGNITION I CAN HEAR A CLICK SOUND BUT NOTHING ELSE AS IF ITS TRYING TO SEND POWER TO THE SPARK PLUGS OR WTHVER EVERY THING WORKS JUST WONT ATTEMPT TO TURN OVER
if it clicks when you try to start it might be the battery.
Turn on the lights and try to start.. and see if they dim out,
if so replace or charge the battery KC
Axel
Usually the indication is around corners the CV joint will make a popping sound. You can also tear the boot on the CV joint, but my theory is just to drive it until it makes noise. No sense in changing it when there is still life in the old one.
Really the only thing that goes wrong is the CV joint portion of the shaft wears out, except accidents and other unforeseen instances.
You can buy lifetime warranty axle shafts from Auto Zone or Advance and those kinds of parts stores.
2answers
1989 Honda prelude makes a clicking noise when turning
Sounds like it an outer cv joint on that side. They start making a ticking noise under load and it gets worse as time goes on. Have a shop look it.You'll need a pretty well stocked tool box if you want to do it yourself.
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
