Question about Blanco Plumbing
Blanco purus II poor water pressure
I bought a house with a blanco purus II. how do i increase the water pressure/ remove the flow restrictor?
  • 33 Answers
If the pressure is the same for both hot and cold. Then most of the time it could be just a blocked Screen/Aerator. Unscrew it and see if the pressure has improved. If so the replace it! Lowe's or Home Depot have them.
Posted on Jan 30, 2009
I have a two year old blanco kitchen faucet has low flow pressure.Is there a higher flow water regulator cylinder available
Hi. U can try removing g screen aerator and in there u will find a water saver plastic restrictor. Simply drill it a little larger. One size larger is usually enough.irs very easy to accomplish
Good luck
May 30, 2017 | Blanco Plumbing
I have bought several shower heads as the spray pressure is low but none have helped. The pressure is ok on low setting on half heat but too cold. On full heat its too hot on min setting. Help plz ?
The problem is that all shower heads sold now have to be low water volume. You can take the restrictor out and see if that helps. Look for a blue or white plug type insert in the fixture that has a slot on it. Pull it out and you should be good.
http://homeguides.sfgate.com/remove-water-restrictors-showerheads-27817.html
and http://www.ehow.com/how_5189790_remove-flow-restrictor-shower-head.html
Jun 22, 2015 | Home
My water pressure is very low from the original install is there a way to adjust the faucet to allow a better pressure flow
Your issue could be caused by the water restrictor in the shower head. To know for sure, remove the shower head and then turn the water on.
Very tough water restrictions have manufacturers using plastic water restrictors in the shower heads.
Although you are not supose to, some shower heads can be taken apart to modify, or remove the restrictor.
I hope this helps you.
Jan 31, 2011 | Moen 3175 Legend One Handle Shower Faucet...
Same problem with rinnai V1200.starts ok and as soon as you want to ajust cold water,the hot water line gets cold.**** all design
These units need water flow/pressure to work. If you use a mixer to get the right temperature as soon as you try to increase cold to make the water colder you unfortunately reduce the hot flow. Fairly complicated fault to explain, all continuous flow units have the same flaw. Solution is to try and increase flow and the best way is to take any water filters or restrictors out of your tapware. Most taps have the located in the end of the spout. Unscrew the end and remove any restrictors. Shower roses are a bit more tricky to find. This fixes 99% of these problems.
Dec 22, 2010 | Rinnai Water Heaters
It turns on ,starts to get warm.Then turns off
Sounds like you have a problem with water flow. Since your ground water is warmer in the summer, you mix less hot and more cold in order to get the same warm temperature. If your hot water flow gets low enough, your tankless will start to "short cycle" in order to prevent scalding. Use one of these three methods to increase your water flow at the shower:
1) Clean your shower head and descale
2) Widen the hole in the showerhead's flow restrictor
3) Remove your flow restrictor entirely
Aug 02, 2010 | Noritz 6.3 Gallon Residential Tankless...
Blanco 2.2 GPM Faucet/Side Spray#157-013ST Via Google NO PRESSUR
Try unscrewing the aerator and cleaning the screen that you'll find there. If that doesn't work then you should check the pressure under the sink by removing the cold water hose from the cutoff valve (turn it off 1st!). If the pressure there is good then try removing and cleaning the cartridge by soaking it overnight in white vinegar or consider replacing the whole faucet if it's old. You can also call Blanco and see what they'll do for you as it has a "Limited Lifetime Warranty." If the pressure at the cutoff is low it's time to call a plumber!
Jul 14, 2010 | Blanco Classic Single Handle Faucet with...
I installed a Price Pfister kitchen faucet model low water pressu
yes it should have a flow restrictor in the end of the spout. You might need to clean it out
Mar 08, 2010 | Plumbing
Sometimes the hot water just goes cold
Here are a couple things to look for:
1) flashing burner light - a flashing burner light indicates the unit is getting an error code
common error codes:
A. continuous flashing - ignition failure or abnormal combustion; look for visible water in the machine indicating a leak, check gas pressure, debris or buildup on flame rod/igniter plug, or clean unit with compressed air
B. 3 flashes - error 16, abnormal outlet water temperature; typically this code indicates you'll need to descale you unit
C. 4 or 5 flashes - exotic error codes; you should contact Noritz technical support to deal with these codes
2. If there is no flashing code, try increasing the hot water flow. In the summer time you typically use less hot water; this can result in intermittent operation of your tankless heater. Increase water flow by either: A. cleaning your showerhead and removing scale deposits B. widening your flow restrictor C. Remove your flow restrictor in the showerhead
3.If none of these resolves your problem, you probably have debris in your flow sensor. Contact Noritz technical support for a walkthrough on removing debris from a flow sensor.
Feb 18, 2010 | Noritz 6.3 Gallon Residential Tankless...
Water becomes ice cold in the middle of a shower
Jan 24, 2010 | Noritz NORTIZ Outdoor Propane Tankless...
Moen posi-temp for shower pressure
Is this only happening in your shower? Or through the hole house? Maybe you shower head has a flow restrictor in it. Try removing it!
Jan 31, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Plumbing Logo
626 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
