Question about Samsung LN37A550P LCD TV
LN37A550 LCD TV has washed out image
I have a SAMSUNG LN37A550 LCD TV with washed out images. The menus are equally washed out. I got this TV secondhand and it was like this when I got it. The user controls (contrast, backlight etc) do not solved the problem. Can this be solved in service mode ? Is this caused by a bad pc board ?
  • 1 more comment
  • marionbagget Feb 04, 2009
    This SAMSUNG LN37A550 also has a "reversed video" effect. The dark parts of the images appear light and the light parts appears dark. I set the Picture Options to the "Blue Only Mode" (bad idea)
    and the screen was so light nothing could be made out. I did a
    "Picture Reset" to get back. Going into "Service Mode" is probably not a good idea with menus that can barely be read.
  • marionbagget Feb 17, 2009
    SAMSUNG LN37A550 Problem solved
    I replaced the LCD Controller (TCON) with a "pulled" unit from another TV. The same problem is still present. So I put the original part back. Now I am seeing vertical lines also !! (hmm I've seen this before on other lcd displays) The Controller has two flat cable connectors at the top. I disconnected and re-connected the flat cables. Now one side of the display looks clear and correct !!
    Ahaa, just as I though! The problem is - the flat cables has to be positioned correctly on the board connector. So I disconnected and re-connected flat cable for bad side only. (the connectors on the board simply flip up like a door) Now all works.
    Reassembled tv for the 'last' time and tested. The washed out picture is back ! Took off back cover tested. Problem still present. Dis-connected top of "H" frame and tested. Problem gone ! When both sides of top of "H" frame are pressed down to re-assemble the picture goes bad. Either a short or something along the top of the set is out of place. So I put the screws back in on side and put insulation under the other side and put that screw back. Problem now solved. Re-assembled tv for "last" time and no problems present after a week of watching.
  • Anonymous Mar 13, 2014
    sound normal tv running normally the t con board connen=cter also unplug and plug. no loose contact
    Problem Solver:
  • 8 Answers
It is possible the problem is caused by a wrong option byte setting in the service menu. The correct setting depends on the type LCD panel used in that version. Version number can be found on a sticker on the right side of the television. A bad main board or TCON board can also cause that type of problem.
Posted on Jan 30, 2009
Problems with colors and display on my Samsung LN37A550P3FXZA flat LCD.
Replace all busted capacitors in power supply board inside.
Jan 10, 2014 | Televison & Video
I have a Samsung LN37550A LCD TV (full HD 1080) that is 2 years old. 2 days back the images got washed out. All I see is mostly very bright images and negative images. I am told that the TCON card needs to...
U can't buy the T-CON board in any stores in anywhere in the world because this T-CON board it is not buy able it new u only can buy it as a salvage tv PCB board only.This T-CON board u can buy it as refurbish board only.Tries websites like, to buy a refurbish T-CON board for the replacement.
Sep 22, 2011 | Samsung LN37A550P LCD TV
Our Phillips flat screen TV picture is split down the middle vertically. One side shows a mirror image of the other side, and then sometimes one side is a lighter shade than the other, when it is full...
This may be due to a faulty Timing Control board (TCON board). I had a similar problem with my Samsung LCD TV picture being split vertically down the middle. The image on both halves appeared fuzzy and in reverse (mirror) including the menus. I replaced the TCON board and the problem was resolved.
Aug 18, 2011 | Televison & Video
There is a brownish spot near the bottom of the screen - almost looks like a burn spot about 6" by 2.5" on my Samsung LCD 40" tv screen.
U have a burn in image to LCD screen panel like display the same image too long like hours in and out.Sorry this problems,have to live with it.Can't remove burn in images problems.
Mar 22, 2011 | Samsung LN40B530 40 in. LCD HDTV
To remove the base stand, place the TV face down on a smooth surface. Place a cloth underneath it to protect the screen. Remove the 4 phillip screws from the stand. The stand can now be removed. The set can with a cover plate you can use to cover the opening.
See page #86 in the User Manual.
Mar 15, 2009 | Samsung LN37A530 37 in. LCD HDTV
Green noise on all black images on my SAMSUNG LN LCD TV screen
I had a similar problem with my LG plasma. I used the Image Sticking Minimization
(Pixel Orbitor, White Wash, and Inversion) feature which is designed to prevent image burn in and ghosting. This ISM feature may be available on the Samsung or any other brand under a different name. I activated the "white wash" option for about 30 mins, the screen turns white and somehow the pixels get reset. The green noise disappeared after that.
I hope this helps. Phezbuster
Dec 20, 2008 | Televison & Video
Samsung tv
Hey tj1217,
The most common problem that may occur when you connect a video game console to a TV (especially front and rear-projection models) is a condition that is often called "image burn" or "image retention." This typically happens if the same image is left on the screen for a prolonged period of time, like when playing a video game that has many stationary images or if the game is left on pause for an extended period. In some cases, this may even be caused by test patterns, on-screen programming menus, or picture-in-picture boxes.
Before connecting your Nintendo Wii, I would first suggest checking the owner's manual for the TV itself to see if Samsung has any warnings or disclaimers against doing so. If you are unable to find your owner's manual or are unsure of what to do next, you may always contact Samsung directly for more information.
Should you choose to connect the Wii based on the manufacturer's suggestions/warnings, keep in mind that you can usually avoid issues like image burn by taking simple precautions such as turning the TV off when taking a break. The less time that the same images (or backgrounds) are displayed on the screen, the lower the risk is of image burn occurring.
Hope this helps you out.
Go Ahead. Use Us.
May 18, 2008 | Televison & Video
Image cut off of Samsung LCD TV picture
if you have a time warner remote press the # to zoom
cox has another button . don't know it. ask them.
Mar 08, 2008 | Samsung LN-T4671F 46 in. LCD Television
Sony WEGA KV-27FS100 picture size
hi there, you may have a power supply section trouble, check the biggest electrolytic capacitor in the power supply, the rectifier diode, the regulator, and check for some cold solder, do some test, there is a part to be repalced. ty
Dec 28, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Samsung LN37A550P LCD TV Logo
2,929 people viewed this question
Jerry Greenberg
Jerry Greenberg
