Question about Dell 922 All-In-One InkJet Printer
Printer Ghosting Hi I have a Dell Photo all-in-one printer 922, When I print any document I get a repeat of some of the lines like a ghost beneath the first line of print. It does this when it copies too. Any help would be appreciated. D
  • stmoll Mar 11, 2009
    My printer does the same thing. I have aligned it several times and cleaned the cartridges. I even called Dell and someone walked some other steps to clean the printer. Nothing has helped. I hate to throw the printer away. Does anyone else have any ideas?
  • PaolaH Mar 16, 2009
    I have the same printer problem.
    Can somebody help us?
  • 41 Answers
Assuming you are using a Windows operating system, go to Start, Settings, Printers and Faxes. Once the windows opens, right click your printer and go to Properties. Each printer's options here are slightly different so look around in all the tabs here for an option to align the print cartridges. I hope this helps.
Posted on Jul 28, 2007
SOURCE:
How can I correct double or repeat image down a page?
Solutions - Brother International - Frequently Asked Questions
www.brother-usa.com/FAQs/Solution.aspx?...
Brother IndustriesThe text and images on my printed documents are ghosting or double printing. ...checks, or other media can cause reprinting or ghosting on the page. ... NOTE: This cleaning process may have to be repeated several times to remove certain ... Remove the toner cartridge from the drum by holding down the green lock lever ...Missing: intellifax ‎4100e
[PDF]FAX-4100e FAX-4750e FAX-5750e - Brother
https://www.brother-usa.com/.../UM_IntelliFax_4100e_E... Brother IndustriesYou can download the latest software documents ... Paper Cassette #2 (Option for FAX-4100e and FAX-4750e) .... repair or replace the Machine and/or ..... 4 Double-click the icon for the documentation you want to read. ... To return to the main page, click Back-OR-If you have finished your setup, ..... Repeating Letters .
Jan 30, 2016 | Brother IntelliFAX 4100e All-In-One Laser...
Not printing full solid, lines, ghosting, streaking, often type is not even printed/unreadable
go to the printer control software on your pc and find maintenance or troubleshooting menu. select option to clean print head.
Feb 14, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Ghosting on HP2015 Printer
Hi gpeirce:
Ghosting is the result of a worn fuser assembly. Try to print a half page by printing a document and then try to open the top while the paper is going under the toner cartridge. You have to listen to the paper moving through the paper path.You will see that the paper has print on it but not the hole document. This will tell you if the toner cartridge is bad or the fuser assembly.
Hope this helps
May 30, 2009 | HP LaserJet P2015dn Printer
Ghosting on my laser printer
You just need to run more print outs to clear the ghosting.
Apr 10, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Dell 922 won't print
Myprinter won"t print it says it is the Dell photo aio printer 922 is not working . how can i get it to work. thank you
Jan 26, 2009 | Dell 922 All-In-One InkJet Printer
Color printer won't print color
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 31, 2008 | Dell 922 All-In-One InkJet Printer
Text is "ghosting" when using card stock
I sort of solved my ghosting problem by selecting print, set up, and then under media type selected thicker paper. This apparently pulls the card stock through at a slower rate which helped tremendously. One of my documents turned out perfect and the other "ghosted" just a little.
Dec 17, 2008 | Brother HL-2070N Laser Printer
Dell 922 printer will not print on the lines of lables
My dell photo aio 922 says there a communication problem and i try to print i do everything it tells me to do for exaple recconect the usb restart computer and try and take the printer plug out but still i am haveing the same problem
Dec 08, 2008 | Dell 922 All-In-One InkJet Printer
Dell 1600n has been ghosting lately
The 1600n AIO (all-in-one) is a laser printer. Laser printer use a statically charged "drum" to place toner on the paper. Your ghosting problem may be from the drum itself becoming too charged or simply dirty and not the cartridge. Servicing laser printers is tricky business because they use a lot of wattage/voltage to create the static charge and also "bake" the image onto the paper. A very quick fix would be to de-ionize the drum and clean it thoroughly.
First, make sure you have the unit completely unplugged for, at least, ten to fifteen minutes before proceeding to ensure that all static charge has had a chance to dissopate.
Second, remove the toner cartridge and place it on some newspaper or paper towels. Inspect it for any residual toner and/or damage that may be causing the ghosting (look for cracks/grooves/lines in the cartridge that shouldn't be there).
Third, take a used dryer sheet (or one that's had most of the chemical fabric softener rinsed off and then completely dried) and wipe the entire drum to completely remove any static charge. Then, using denatured alcohol and static-free, lint-free wipes clean the entire drum to remove any remaining detritus. Allow to dry thoroughly before proceeding.
Last, wipe the drum down, one final time, with a clean dryer sheet or lint-free cloth. Reassemble the unit and replace the toner cartridge.
Run a few clean sheets (blank prints or copies) to further remove any particles knocked loose and check for any more "ghosting."
Final printing will be necessary to check for inconsistencies or success.
Nov 08, 2007 | Dell 1600n All-In-One Laser Printer
Dell 3100 printer ghosting
Ghosting can be caused by two things. Either too much toner is being laid down which incurs a starvation of it. Or, the image is being repeated due to a problem with the drum. In your case, I want it to be the "too much toner" deal, because a drum replacement can definitely be more costly in comparison to a design change. Yet, if it is under warranty, the drum will be replaced at no cost.
Dec 31, 2006 | Dell 3100cn Laser Printer
Dell 922 All-In-One InkJet Printer Logo
183 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
