Question about Texas Instruments TI-83 Plus Calculator
Not turning on/replaced all batteries including back up/
Hey everyone, i havent used my calculator since may 2008 (my last math class) and i need it this semester  for another math class. i've had it since 2003.
the casing has no noticable damage/no damage at all. i've tried the brightness thing to see if it was all the way down and i still get nothing.
i replaced the 4 AAA's and the backup battery (1616 3v). solutions?
  • 2 more comments
  • francis b Jan 30, 2009
    could i have banged it somewhere hard and made it stop working? i dont think im that uncareful to bang something thats as solid as a rock & damage it.
  • Anonymous Feb 03, 2009
    Not turning on at all
  • Anonymous Feb 04, 2009
    same problem here... the last time i used it was last summer and it worked fine then.tried both the vacuume thing and the brightness thing but neither worked...X(should i open up the calculator and vacuum it?
  • Anonymous May 08, 2009
    i can't get it to turn on or reset itself.i even tried putting rechargeable batteries in it.Clues anybody?
I had the same problem nothing worked after raplacing the batteries. The problem with me was dirt/dust in the IO-port, I put the nozzle of the vacuumcleaner on IO-port and turned the cleaner on for a few seconds. After that the calculator worked like a charm.
Posted on Jan 30, 2009
7 letter word with the letters a u f n h c u e h c a u d w
very good
you give a list of letters that you want to use in a maths class
I would have thought that with letters , the class would have been a english class and numbers for a maths class
or maybe you are doing the theory of probability and want to know how many words could be made from those letters
Sep 06, 2016 | Office Equipment & Supplies
I'm in a statistics class and need to find the area under a standard normal cube. I have a TI-81. How do i find that specific function?
Hey there,
You are looking for the cube root function which can be found under the MATH menu selection. the answer you get will simply need to be squared and you have your answer
Oct 03, 2013 | Texas Instruments TI-81 Calculator
My TI-83 PLUS wont turn on
Remove one battery from the calculator and then press and hold down the CLEAR key while re-installing the battery. While continuing to hold down the CLEAR key, press and hold down the ON key. If this doesn't work, then hold DEL and then ON. If unsuccessful, remove all the batteries, including the lithium watch battery, and leave the calculator like that for a while.
This is documented in the TI-83 Plus Guidebook, but unfortunately, not many people know about it.
If that doesn't work, send it to TI for repair. They probably won't even charge you!
Mar 20, 2017 | Texas Instruments TI-83 Plus Calculator
How do you calculate the cubed root of a number or 5th root of a number?
For cube roots, use the cube-root function in the MATH menu. For example, to calculate the cube root of 8, press MATH 4 8 =
For other roots (including cube root), use the xth-root function in the MATH menu. For example, to calculate the fifth root of 32, press 5 MATH 4 3 2 =
Mar 02, 2011 | Texas Instruments TI-83 Plus Calculator
I am getting the wrong results when performing some basic FV math problems. Doy you have any math problems that would help test my calculator?
It might be more efficient to make the calculator perform a self-test. Here is the procedure.
Verifying Proper Operation (Self-Tests)
If it appears that the calculator will not turn on or otherwise is not operating properly, use one of the following procedures.
1. With the calculator off, hold down the [ON] key and press [X] (the multiply key)..
2. Release the [ON] key, then release the [X] key. This initiates a complete test of the calculator’s electronic circuitry. If everything is working correctly, within about 25 seconds (during which the word RUNNING the display should show –8,8,8,8,8,8,8,8,8,8, and all of the status indicators (except the * battery power indicator) should turn on. If the display shows Error 9, goes blank, or otherwise does not show the proper result, the calculator requires service.
Tests of the calculator’s electronics are also performed if the [+] key or the [divide] key is held down when [ON] is released. These tests are included in the calculator to be used in verifying that it is operating properly during manufacturing and service.
If you had suspected that the calculator was not working properly but the proper display was obtained in step 2, it is likely that you made an error in operating the calculator. We suggest you reread the section in this handbook applicable to your calculation — including, if appropriate, appendix A.
If it needs repairs, contact FixThatcal.org
Here are some examples from the manual (there is overlapping in the first two screen captures)
Mar 07, 2010 | HP 12c Calculator
My TI 83 wouldn't turn on. So I changed the batteries but now it will not turn on, if I hold the on button down a few lines appear on the screen. Do i need to replace the back up battery? i really don't...
Here are some steps to perform in the order they are presented. The point A may solve your problem. If it does not do the others. Please read the post till the end.
A Try this before thinking of repairs.
  1. Push the ON button.
  2. Even if you see nothing, press the [2nd] key and release it.
  3. Press and HOLD the UpArrow key until the screen darkens.
  4. You may have to keep pressing UpArrow for a little while before you see anything.
B If that does not work
  1. Remove one of the AAA batteries.
  2. Press and hold the [CLEAR] key.
  3. While holding [CLEAR], reinsert the AAA battery and then
  4. turn the calculator on.
  5. The calculator should display the message "RAM Cleared".
  6. Release the [CLEAR] key and then press it one more time to remove the message "RAM Cleared".
C. Third option
  1. Remove batteries including the backup battery for 5minutes.
  2. After the 5 minute period, reinsert all of the batteries and
  3. turn the calculator on.
  4. Adjust the contrast if necessary.
D. Last option
The last option requires the reinstallation of the system. So to use it you must download the TIConnect 1.6 software from education.ti.com. You must have the TI USB SilverLink or the TI Black serial cable ready.You must be connected to the Internet.
  2. Press and hold the [DEL] key.
  3. While holding [DEL], reinsert the AAA battery and then
  5. The calculator should display "Waiting...Please install calculator software now".
  6. Connect the TI Connectivity cable between the computer and the calculator.
  7. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OS Downloader.
  8. Follow the on-screen directions to reinstall the calculator's OS.
If the message "Error! Press any key to turn unit off. Then turn unit back on." appears on the graphing calculator, quickly, remove one battery from the calculator and reinstall it while the transfer is taking place.
You have several ways to connect the calculator
  • Serial Black cable that used to ship with the TI 83 Plus. It connects to a serial port on a computer and to the I/O port on the calculator. It requires the Graph Link software available on the TI web site (Downloads, Software and Apps, Connectivity)
  • USB Silver Link cable. It connects a USB port on the computer to the the I/O port on the calculator. It requires the TI connectivity software, also available on the TI Web site.
  • A USB mini A to mini B cable to connect two units.
  • An I/O cable to connect two calculators through their I/O ports.
Jan 22, 2010 | Texas Instruments TI-83 Plus Calculator
When doing a simple math problem it anwers all zeros. I pressed on something earlier and I don't know how to fix it. Can you help me? I did turn it off and turned it back on and that did not work.
look on the back cover and find the reset button, use a pen and press it and see if it clear the problem also check the batteries they might be dead check the back cover and see what type you need take it to the watch repair dept and buy some batteries and have them remove the back cover of the calculator and replace them. put the cover back on . your calculator will work as good as new again.
Oct 06, 2009 | Texas Instruments TI-15 Explorer...
My Ti-84 plus silver edition froze
About the only other solution I can think of is to take out the backup battery if you haven't already done so. Might work.
Oct 02, 2009 | Texas Instruments TI-84 Plus Silver...
Math book for the fx-115-es
Use your internet seach engine or go to the casio worldwide web site. A google search returned this link to the New-Zealand site.
http://casionz.co.nz/Site/Pronto/Files/user_manuals/FX-115ES%20991ES.PDF
Hope it helps
Mar 09, 2009 | Casio FX-115ES Scientific Calculator
Texas Instruments TI-83 Plus Calculator Logo
167 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
