Samsung HL-S5679W No video No sound
I didnt think it had a lamp or ballast because it is an led tv also would that cause there to be no sound?
  • 1 more comment
  • mark pasley Feb 05, 2009
    if all three leds go bad would that cause there to be no sound?
  • mark pasley Mar 10, 2009
    I had a tv repairman come out and he said the led's were bad so I replaced them and it still didnt work. Then the company said they had replace the whole led engine, so they came out and did that still didn't work. So I just troubleshot it myself. The input power was good to main power supply board but the output to the led driver power board was bad so i inspected the card and found some bad caps. I read about this in some other posts and I changed 2 caps out earlier but I missed two others that went bad. I replaced them with the same caps that were in there but i hear they need to be higher voltage. Anyone know a good cap site.
  • thielectronick
    thielectronick May 11, 2010
    this might be answered on another thread.. all 3 leds = lamp failure
    in this case, LED lamp failure, or the LED power board.
    there are fuses that will blow on the board
  • 505 Answers
All 3 leds on the front panel blinking = lamp error.
if the tv doesn't come on, it may not put sound to the speakers.
you need to focus on the error at hand.. does the tv come up and appear that it is running and not turning itself off (shutting down)?
if it runs and doesnt turn off, then the audio matters, otherwise focus on the other problems.. you won't have audio on certain inputs, etc, don't use that to troubleshoot unless your tv is running and not shutting down.
Posted on Feb 06, 2009
Samsung HL-S5679W won't start - LED light blinking
Replace Lamp,but CK to make sure Fans are running if OK then replace Lamp Mats Has them for 99.00
1-800-628-1118
May 11, 2010 | Samsung HL-S5679W 56" HDTV
Samsung HL-S5679W - Power-up issue
There can be a few causes. One of the LED Modules has gone bad, The LED Driver board has gone bad and or the Power Supply has gone bad. You will need to have a good tech look into it.
Apr 03, 2010 | Samsung Televison & Video
Samsung tv model# HL-S5679W all three lights on front panel blink, no pix or sound owner's manual says lamp may be defective this is a DLP-LED. No conventional single lamp
The "lamp" in this set, I think, is called the "DLP" in the parts listings. That part is number: 4719-001960 and can be purchased from tritronicsinc.com for $249.75 plus shipping. Use the guest account to access this info.
Hope this helps,
Dan
Feb 17, 2010 | Samsung DLP HL-P5663W 56" TV
Have Samsung HL S5679W 56 LED 1080p DLP HDTV Problem no picture maybe Power Box??
could be the lamp, ballast, smps board(power supply board) or the main board.
Nov 05, 2009 | Samsung Televison & Video
I need to replace the bulb on my TV model # HL-S5679W. I can not locate the replacement number for the lamp. I have been unsuccessful with contacting Samsung and need help.
This model does not use a lamp----if the LED unit is bad you may want to just forget it---
Samsung part number for the entire optical engine:
BP96-01470BIt is marked as no longer available (2006 model) and had a suggested list of 495 exchange.
Google the above part number and you will find some places selling the engine---for much more than Samsung wanted.
SORRY TO GIVE YOU BAD NEWS---no replaceable lamp in this model----the LED light unit is part of the optical light engine.
SD TECH
Oct 28, 2009 | Samsung HL-S5679W 56" HDTV
HL-S5679W won't start three light blinking
There is no lamp on this TV.. Your issues sound like a bad DMD board or bad capcitors on the power board. Remove the power board and inspect it.
Jun 21, 2009 | Samsung HL-S5679W 56" HDTV
TV Stopped turning on.
Apparently you can fix the issue by replacing a few faulty capacitors. I haven't done this yet, but plan to try it out next week.
http://www.bking01.com/Samsung_HLS5679.htm
http://www.avsforum.com/avs-vb/showpost.php?p=12845033&postcount=2060
Apr 03, 2009 | Samsung HL-S5679W 56" HDTV
Issues with replacing Ballast
I have some proble dlp tv I put new lamp;put the problem didnt whant away
May 05, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung SP43W6HPX\XEU Rear projection
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Oct 25, 2007 | Samsung HCN4226W 42" Rear Projection...
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
Electro Med Services...
