Question about HTC S620 Smartphone
How can i format memory card in htc s620 - HTC S620 Smartphone
    Genius:
  • 1,550 Answers
Take out the memory card and insert it to pc and do format .
Posted on Jan 30, 2009
3 Suggested Answers
neogil22
  • 36 Answers
SOURCE: I need internet and mms settings for htc s620
Hi...
Why don't you call or sms the customer-service of your provider?
they will send you an sms with the settings for the phone.
friendly greetings, Gilbert.
Posted on Mar 10, 2009
NitrusInc
  • 326 Answers
SOURCE: changing htc s620 language from spanish to english
Alright... I am going to do my best here to provide non-language navigation.
If the screen is locked you will get:
Little response to buttons (Except Left Soft-Key, used with Z or * to unlock)
Just a clock on the screen with words above and below
Grey/dark screen brightness.
Providing the screen is unlocked:
Left Soft-Key (White bar above House)
2nd row last icon (Folder with gear)
7 Key
5 Key
Center Navigation button.
Select Language.
Left Soft-Key
These instructions should blindly take you to the language selection for languages that your ROM supports.
For other languages, a ROM Flash would be required, which is nearing outside of the scope of this site.
Please let me know if their are any other questions. If this information was helpful, please take a moment to rate.
Posted on Apr 23, 2009
How do i type a word document directly on my htc dash or s620
It is possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Copy only valid files to the card and do a scan before it is replaced. Now replace the card and battery and switch on the phone. If the phone hangs up or is slow when it is switched ON , then it is possible that the fault is relative to the software and will need a reinstallation. Possible hardware issue cannot be ruled out.
Nov 21, 2011 | HTC S620 Smartphone
Mhy htc s620 occasionally slows down. It may take 10 seconds for it to respond to pushing a key. Any help?
On the phone, click setting, and then click accessibility. Change the multi key time out to the slowest time. Also, make sure your phone has at least 10 MB free of Program and Storage Memory. To check this, go to task switcher, and click menu. Then click on system info. Check the remaining memory available for Program and Storage memory at the top of the list. (If you have an SD card installed, it will show up below the program and storage memory.) If you want to remove programs to free up memory, click on settings, then click more, then click remove programs (or press the "2" key.)
Feb 11, 2011 | HTC S620 Smartphone
After the battery run empty on my HTC S620 mobile, I cann't turn it on (off course the battery now is charged).
Take out the battery, then take out the sim card and the storage card for about a minute hen put back the battery in just the battery. Pushed the power button and then push both of the soft keys, which the keys above home key and the back key, then check if that will power ON the unit if it does you can power it off and put the sim card and memory back in.
But if still same problem I will advice you to try a different battery just to check if the battery is bad or something more is causing the problem.
Jul 29, 2010 | HTC S620 Smartphone
HTC Touch does not boot
Try doing a ROM upgrade from the HTC website.
Jan 03, 2010 | HTC S620 Smartphone
What's the biggest micro sd card that fits htc s 620 smartphone?
  • Micro SD Compatible with the following Smartphones:
  •  Blackberry 8800
  •  Blackberry Curve 8300
  •  Blackberry Pearl
  •  Palm Centro
  •  Samsung BLACKJACK
  •  T-Mobile Dash, HTC S621 & HTC S620
  • 4GB Micro SD - Secure Digital Card with SD Adapter
    Hope this helps, if it does please rate accordingly, David
    Mar 18, 2009 | HTC S620 Smartphone
    Hi...
    Mar 10, 2009 | HTC S620 Smartphone
    S620 Software Problem
    You might need to flash the ROM and start over again..
    <object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/i_BuN68vclM&hl=en\"></param><param name=\"wmode\" value=\"transparent\"></param><embed src=\"http://www.youtube.com/v/i_BuN68vclM&hl=en\" type=\"application/x-shockwave-flash\" wmode=\"transparent\" width=\"425\" height=\"355\"></embed></object>
    there is a guide how to flash from tmobile to s620 on there you will see links to and how to do this.. you don" t have tmobile dash version but the s620 version.. this will give you a step by step guide on doing this regardless if you have the tmobile dash version.. just follow the promps..
    Dec 17, 2007 | HTC S620 Smartphone
    My HTC S620 stays on second start screen
    Hello, These methods have been confirmed on my phone with both T-Mobile's ROM and Excalibur (S620 original ROM) Remove any memory cards before starting this process.
    With OS:
    1. Select Start
    2. Select Accessories
    3. Clear Storage
    4. Type in 1234
    5. Select Yes
    Without OS:
    Turn the hand-held off, hold the two soft keys (the dashes to the left and right of the phone buttons) hold the power button for 1-2 seconds and then release the soft keys. It should prompt you to clear storage. The “send” button is considered as the green phone button.
    Let us know if you have any other questions. If this information was helpful, please take a moment to rate the solution. Thank you.
    Nov 28, 2007 | HTC S620 Smartphone
    HTC S620 Smartphone Logo
    177 people viewed this question
    Top HTC Computers & Internet Experts
    SANJEEV KUMAR SURI
    SANJEEV KUMAR SURI
    Tom Chichester
    Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
