Tablets & eReaders Logo
Anonymous Posted on Jan 27, 2013
I want to get rid of an about blank screen, how do i do this
When i open my browser, i have an about blank screen and i cannot get rid of it, how do i do it
Mr.Mike
Level 3:
  • Master 580 Answers
  • Posted on Jan 28, 2013
Mr.Mike
Master
Level 3:
Answers
580
Questions
0
Helped
195905
Points
1906
When you say you cant get rid of it you really mean " it pops up every time you launch you browser, you can then navigate away from it?" if this is true you will need to set your home page to your liking and this will stop the about blank page from showing--Good Luck.
  • 2 more comments
  • Anonymous Jan 28, 2013
    i dont really know how to do that on the tablet
  • Mr.Mike Jan 28, 2013
    thought it was computer, what tablet? i can tell you
  • Anonymous Jan 29, 2013
    yes it is a tablet, a samsung10.1
  • Mr.Mike Jan 29, 2013
    Assuming it's running ics, Browser > Settings > General > Set homepage] and then just open new tab to see what happens.--Good Luck.
I have a iPad Pro and my screen has changed from a full screen to one that us 1/2 full what is my problem
How to Turn Off Split Screen on iPad Split View is enabled by default on the iPad. To utilize the feature, you can drag an app from your dock to the right or left edge of your screen to open the app on a portion of the screen. If you have multiple apps open and want to close one without turning off the Split Screen or Multitasking functions in settings, you can return to a full-screen view of a single app by dragging the edge of the app you want to remove to the edge of the screen.
If, however, by "getting rid of split screen on iPad" you mean turning the feature off completely, that's something you can do in Settings. To turn off split screen on the iPad:
  • Open the Settings app on your iPad.
  • Tap General.
  • Select Multitasking & Dock.
  • Toggle off Allow Multiple Apps.
How to Get Rid of Split Screen in Safari on iPad Using split screen in Safari on iPad was a new multitasking feature for iOS 10 that continues in iOS 12. This allows you to open two separate Safari web pages simultaneously on your iPad. To start, open Safari on the iPad. You can then open a second Safari tab in split screen in one of four ways:
  • Tap and hold a link; select Open in Split View.
  • Tap Command+N on an external hardware keyboard to invoke Split View.
  • Drag a tab from its space to either the left or right side of the screen to open it in split screen.
  • Tap and hold the icon that opens your tabs view in Safari. It looks like two overlapping squares. When you tap and hold, options will pop-up. Select Open Split View.
But what if you want to get rid of split screen in Safari? What if you're done using the two tabs-how do you turn split screen on the iPad off? To close split screen in Safari on your iPad, you can do one of the following things:
  • Drag the tab(s) from one of the screens to the other. Once the last tab has been dragged to the opposite side, Safari will return to full screen, which will turn off split screen.
  • Or, you can tap and hold the tabs icon, which looks like two overlapping squares. Then select Merge All Tabs. This will merge all your Safari tabs back into a single window, which gets rid of split screen.
Clear a totally blank page on my apple iPad screen is all white..
You could try pressing the button on the front side twice and then swipe up the screen to get rid of it, when mine gets stuck I often do this to clear it off and it usually works for me.
2answers
Is my samsung galaxy tab 2 10.1 compatible with the your texas benefits website? I just get their logo with a blank screen
See if you can install the Chrome browser app from the Google Play Store and try that browser instead. Usually the default browsers don't work well with different sites. It may work better than the default browser. I tried it on my iPad with Chrome and it worked well.
If you need further help, reach me via phone at https://www.6ya.com/expert/michael_e7c2c48c6e65f808
How do I close the 16 open browser tabs on my 10in digiland tablet? It won't !et me open a new tab bc 16 is the max. I can view them and open them but no option to close any/all.
From the home screen, if you look at the bottom of the screen.. the square which is second from the right should bring up all apps currently and previously used. You should be able to tap the X on the top right of each app box to close them individually. Alternatively, opening a browser window then to the right of the address bar is the amount of open tabs you have.... tapping on the number should bring up the open tabs... give them all a little time to completely load up, then you should be able to close them the same as above.
Hope this helps you solve your problem :)
How to get rid of open screens when I'm done on an acer tablet
Press and hold the home key. All open screens should pop up and allow you to close them. You may have a close all options that comes up..depends on the android version
I cannot access the Internet. It says i am connected, and comes up with a sign in notification. When i select the notification, it opens the browser and loads a completely blank page. This network does not...
REGARDLESS of what the initial notice says . open the drop down menu by swiping from the top notice line downward . tap the wifi icon and it will turn off. then turn it back on and tape the gear icon that will open settings , tap the wifi line to open the wifi settings. you should see your network there and be able to sign on.
you should start with a blank browser page just type in a website or topic. it should go to the site .
also try installing firefox from the store and then use the desktop icon to open the browser.
if you still have problems comeback and describe.
I have 3 galaxy products Tab 4 ", Tab S 8.4" and note 3 smartphone
all using kit kat. so i should be able to walk you through this one
Opening browser the first time
-Go to the settings menu
-Choose applications manager
-Find the application
-Clear the cache or find reset to default
when you open the application, tap the top of the screen and the url bar should be there for you to type whatever you wish my friend.
Get rid of google searches
You can choose another website as default website, or use Firefox browser. I think it's hard to get rid of it, because when you want to search something, you have to type Google.com.
Android 4.0 Tablet PC
Top Samsung Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
