Question about HP DeskJet 3550 InkJet Printer
Hp 3550 printer color cartridge printing but black not printing
Hp 3550 printer color cartridge printing. But black cartridge got printed of 2 pages after refilling and now its not printing.
    Genius:
  • 2,035 Answers
Try to clean the black cart :
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Posted on Jan 30, 2009
    Genius:
  • 1,550 Answers
Perform print head cleaning and also try to take a test page and ensure that ink is properly injected out of nozzle.
If this doesnot work take out the cartridge and clean the contact and reinsert the cartridge .
Print appears on multiple pages
check the fuser unit in the back of the machine; typically the shadow effect is caused by the fuser assembly. Inspect your toner cartridges for any leaking toner. Genuine HP or ? ? ? ?
Dec 20, 2012 | HP Color Laserjet 3550 Printer
1510 black cartridge can print how many pages
There are 2 black cartridges which can be used in PSC 1510 ie 92 and 94
92( 5.5 ml) can print around 210 pages if its being used with HP 93 ( Tricolor) cartridge
94(12 ml) can print around 470 pages if its being used with HP 95 ( Tri Color) cartridge
You can also check it on HP Website click here to check on HP
Apr 04, 2011 | HP PSC 1510 All-In-One InkJet Printer
My HPLJ3500 Color Printer wont print black even tho we just put in a new cartridge. Prints magenta, cyan, yellow, but no black. HELP!
Run the PQ troubleshooting diagnostic.
See if the black is printing.
If not, run the Disable Cartridge check. This will allow you print with only one cartridge in the printer. Take out all the cartridges. Put the black in another slot and put the cyan in the black slot(the top). Print the config page. If the black is printing, is the cyan printing. If black isn't printing the cartridge is bad. If black is printing and cyan isn't something is wrong with the printer. If they are both printing put them back in the correct locations along with the other two colors. It isn't the printer.
Jan 11, 2011 | HP Color Laserjet 3550 Printer
My HP 3550 won't print black when it is out of a color.
restore the properties.... set as "print in grey scale" or "print color as b/w images"...
also if the print become less or more dark you can change the settings to print whit more intensity or less...
there is no necesary change all your documents as "watter ink" only change the print options to fade to black
May 15, 2010 | HP Color Laserjet 3550 Printer
My hp Color Laserjet 3550 Printer wont print black when it is out of color ink
The 3550 won't print in any color if any of the colors are out. You'll have to replace the color ink that's empty to get it to print.
In the future, if you're just printing black and white, you can select "Print in Grayscale" from the print properties to just use the black ink cartridge, which will help the color cartridges to last longer.
May 11, 2010 | HP Color Laserjet 3550 Printer
How to set hp deskjet 3550 inkjet printer to print in only black and white by ignore the color ink,for the important document. endliam< endliamc@gmail.com>
To Save the color ink you can change the printer settings to Black Only.
To Setup:
  1. Press START Button.
  2. Select RUN Command.
  3. Type these commands in CAPS.
  4. CONTROL PRINTERS and press OK or Enter.
  5. Now you will get Printers & Faxes Window.
  6. There you select the ink jet printer which you want to change the color settings.
  7. Right Click on it and Select Printer Properties later.
  8. Select Printing Preferences
  9. There you can see lot of window tabs (just like a worksheets). Depends on printer in any of the TAB you can see the option Black Only / GrayScale Printing Only.
  10. Choose the appropriate option and Select APPLY.
  11. Then give a test page for it.
That's it...
Hope this will be helpful to you..
Thanks & regards
Nandu :)
Dec 31, 2009 | HP DeskJet 3550 InkJet Printer
Deskjet doesn't print real "black"
In the printer preferences, you can choose to print black or color. Check to make sure that when you print, you haven't specified color only.
Apr 30, 2009 | HP DeskJet 3550 InkJet Printer
I want to change printing to black and white only
u have to do this remove your colour cardige then print it u will get black & white print
Jan 11, 2009 | HP DeskJet 3550 InkJet Printer
Printer shows color cartridge m/t
Have you replaced with original HP cartridges? HP mark is well known for sensitivity to non-original cartridges.
Jan 25, 2018 | HP PhotoSmart C3140 All-In-One InkJet...
HP DeskJet 3550 InkJet Printer Logo
270 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
