Question about Harman Kardon AVR 110 Receiver
AVR 110 Harmon Kaedon
I moved to new house which is prewired for 5 channel speakers .I connected all the speaker and my sub also I connected two extra high quality spreaker to Front left and Front right.if I turn on the volume more than -20db it will go the stand by zone and I have to turn it on.I tried to reset and reprogram my AVR 110 but still does that ,I don't know whether it is compatible with wires inside the wall or I can not connect 2 speaker to one channel. thanks for your help. BOB
    President:
  • 1,114 Answers
Looking in the manual (link below) I see that this receiver uses 8ohm speakers, check that your speakers are 8 ohms or more. I think that connecting 2 sets of speakers to the same output is the problem as when you connect speakers in parallel (i.e. just twisting both pairs of wires together) you effectively half the impedance. So if 2 sets of speakers of 8ohms are connected this way the result will be 4ohms which is too low and will cause the unit to go into standby. Try removing the additional front speakers & see if the fault persists. If it does then it is likely a fault in the wiring. http://www.harmankardon.com/product_support/support_detail.aspx?Region=USA&Country=US&Language=ENG&cat=&prod=AVR%20110&sjump=om&#active
Posted on Jul 28, 2007
SOURCE:
I have a active sub woofer (akari bazooka) but the only connections available are the speaker connections. The front of the sub woofer has volume adjustment. How can I connect this sub woofer to my Harman...
hi,
You can't connect the pre out of your AVR to this sub woofer. Do one thing connect the frond left/ right channel speaker "B" out of harman kardon to the sub woofers left right speaker in put. you can connect the speaker out "A" to your normal left right speakers. Remember to switch Speaker "A" and "B" in ON position in your AVR. Also do one thing go to the speaker setup of AVR and switch OFF (slelect NONE) the sub woofer.This will disconnect the sub woofer pre our and the sub frequency will mix with frond left right channels.
ok
May 20, 2011 | Harman Kardon AVR 135 Receiver
I've had my Denon AVR-2308CI receiver for 3 years and last week I turned it on to watch a movie and there is no sound coming from my rear speakers? I have a 5 speaker set up (3 in front and 2 in the rear)...
On the front display of the unit, you should have indicator icons that light up if a speaker is being used. Are there only 3 speakers lite up, or are there 5? As a quick check, make sure your speaker connections are secure, and then make sure your surround mode is set to a 5 channel surround mode. 5 channel Stereo is a good one to test with. Also, you can hit the "test" button to see if the speakers are connected and working, it will give a test signal out of each speaker independently. Let me know what you find, and I can answer more.
Mar 05, 2011 | Denon AVR-2805 Receiver
I have a Harmon Kardon AVR 247 and I want to connect with Bose 901 VI equalizer. No other speakers are connected, just the 901's. Where do I connect the wires from the equalizer to the AVR 247...
I have this exact setup. 901s are my Mains.
The AVR247 has PreOuts on all of the channels.. No jumper to remove either. Just get a power amp or two and place the 901 EQ between the AVR247 and the Power Amplifier.
Jeff
Nov 28, 2010 | Bose 901 VI Main / Stereo Speaker
Distortion with HK AVR 144
This sounds like the amplifer is playing up. If the distortion is on more than one channel, you are looking at a faulty part common to both channels. If on one channel only, perhaps something in the pre-amp or power amp sections. Have a look inside, you might find a burnt resistor, which would cause it.
Dec 21, 2009 | Audio Players & Recorders
Connection between harmon receiver and A-bus in wall speakers...
There is a CAT5/RJ45 A-Bus interface on the back of the HK AVR 435. That needs to connect to your A-BUS "hub". HK has two hub products: ABH-4000 and ABH-4 (older). Then CAT5 cable can be run from this hub to Wall-installed room-specific controls. HK has the AB-2 product, but any ABus compatible wall control will work. From the wall control, you wire regular audio cable to the speakers. So, some of the questions/issues to solve are: where do the existing wires go that are connected to the in-wall speakers? Typically that location is where to place your in-wall volume and source controls. Then the CAT5 gets wired from those controls back to the hub. And all that's required is a single CAT5 from the AVR to the Hub.
Apr 04, 2009 | Audio Players & Recorders
Denon avr 2802 can't get subwoofer to work all else fine
in the Denon setup under speaker configuration set the sub to LFE+Main
Jan 02, 2009 | Denon AVR-2802
Harman Kardon AVR 110 Receiver Logo
355 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Don Hart
Laser Plus Computers...
Level 1 Expert
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
