Question about Microtek scanmaker 3840
Not detecting usb
My scanner is not ditecting USB .so ui mhave to re install but i have no software
  • dirinda89
    dirinda89 May 11, 2010
    What kind of scanner do you have? I'll do my best to help you.
    Scholar:
  • 51 Answers
Below is a Link to the Microtek Support site.
  • It links to the Drivers and Software portion of their site
  • I already have your specific scanner's support page up in the link.
Pick your Operating System, and download the drivers.
Go To Microtek's DRIVERS PAGE
I Hope This Helps.
Posted on Jan 30, 2009
Install scanner pc
Most installations like this require you to run the install software first.
Then connect the device once the software gives the ok to attach.
Most devices today are USB and these can be plugged in hot.
IDE, Parallel, serial, PS2 etc are not. Meaning don't plug this in when the PC is powered up. Be ready to swap USB ports should the software not detect the device. This is rare but can happen.
USB 2.0 is a standard now with USB 3.0 on many newer machines.
If the Device can utilize USB 3.0 and your pc has this. Use it!
It is very fast and you can recognize a USB 3.0 part by the color.
It will be Blue inside. I have also installed scanners and other devices by connecting the USB cord, power up and then running the software.
Does not seem to matter to most devices now. But it is best to follow the instructions that came with the device.
Good luck and hope this helps!
Mar 27, 2014 | NComputing Computers & Internet
Usb driver xp
You do not need a USB driver for XP - just plug the device in and it will load the drivers. If the device comes with software then install that after it says your USB device has been detected
Aug 08, 2012 | Zebra Symbol LS 1203 Barcode Scanner
Have downloaded a driver for mustek 600cu but still not recognising scanner
First install software driver if finish, connect your scanner USB cable to USB ports of CPU(make sure that your USB ports working good, test also using your USB flash drive).then you can see on screen automatic detect your scanner. if not detected try to change your USB scanner data cable. then try again connect to USB ports of CPU.
Just let me know if not yet working.
Thanks for using Fixya.
Jul 13, 2011 | Mustek Plug-n-Scan 600 Flatbed Scanner
Hai my hp 4GB usb drive is not ditect to system it usb ofer pluging its dispaying insert disk please sallo...
The memory chip inside your USB drive has died - most likely you have used it till it failed, old age of sorts.
Nothing you can do apart junk it and buy a new one.
Jun 30, 2010 | Computers & Internet
Epson Perfection 1660 Operation Problem
Possible driver issue.
Please trash and re-install the drivers.
Drivers are available for download at the epson.com site.
Apr 29, 2009 | Epson Perfection 1660 Photo Flatbed...
USB driver problem in my computer
for checking whether they are detected or not goto the control panel then select system then hardware then device manager check whether there are yellow mark on usb, if there are then you have to update the driver
Sep 29, 2008 | Computers & Internet
J5780 Installation Problem on Windows 2000 PC
hi this is due to improper Software Installation stapes below
  • Un install all printer driver & software u install
  • disconnect printer from computer
  • restart u r computer
  • insert Software cd in to cd rom
  • install software ,follow instruction & fill up Information.
  • when notify you to please connect printer thorgh USB please connected Usb cable to your Printer.
  • printer shuld be ditected then follow instruction
  • complite Installation & cheak it out..
If this information is useful for u please rate me....
Jun 09, 2008 | HP Officejet J5780 All-In-One InkJet...
Scanner
THE PROPER WAY ON INSTALLING USB DEVICES A. Enable usb ports on the BIOS. 1. Do not plug in your device right away. Install all drivers and software first! 2. Reboot 3. Plug the power or turn on your USB Device 4. Plug in the USB Port. 5. Windows Will detect the Device Automatically. Finish! Hope this helps.
Sep 21, 2007 | Microtek ScanMaker 4900 Flatbed Scanner
Windows can't find driver for FI-5660C
THE PROPER WAY ON INSTALLING USB DEVICES 1. Do not plug in your device right away. Install all drivers and software first! 2. Reboot 3. Plug the power or turn on your USB Device 4. Plug in the USB Port. 5. Windows Will detect the Device Automatically. Finish! Hope this helps.
Sep 19, 2007 | Fujitsu fi-5650C Path-Through Scanner
Microtek scanmaker 3840 Logo
55 people viewed this question
Top Microtek Office Equipment & Supplies Experts
Alun Cox
Tony
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
