Question about Mastercool 67471 Evaporative Cooler Air Conditioner
Bonaire Cooling system that stopped working after power failure..
I have a Bonaire Evaporative cooling system. We had a power failure that lasted 2 seconds and now the Vulcan LCD unit doesn't work. I called up about this a very long time ago and got the answer but have forgotten the solution. From what I remember, i had to reset something. I really can not remember. Can somebody help please..... I am boiling...
    Problem Solver:
  • 11 Answers
Unplug the unit or turn off the breaker to the unit for at least 30 seconds. If this reset does not work, the electronics may be damaged and need a repair person.
Posted on May 31, 2009
  • 1 more comment
  • rfranssen Nov 29, 2010
    There are still a couple of buttons to be pushed. Which ones are they?
  • Ninad Malavde Nov 10, 2011
    I have same issue. Any Idea?
    And where are the buttons?
pierre1811
  • 144 Answers
SOURCE: Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Posted on Jan 29, 2009
  • 30 Answers
SOURCE: control panel lights constantly flashing
You should have a dedicated line that feeds the equipment power look at your main electrical panel or search around your equipment for a pull out disconnect switch or sometimes they will wire it to a light switch. by shutting down the main power and turning it back on it should reset anything.
Posted on Jan 05, 2009
  • 400 Answers
SOURCE: We have a Vulcan Bonaire evaporative cooling unit
The problem may be with the drainpump not functioning properly. They sometimes clog up with scale. Easy to remove and clean by opening up the unit. Some units also have an alarm function when the cell pads need replacing. Again this one would be able to see visually. They simply slide out, you would have to locate a supplier and just buy four cellpads.
Posted on Mar 04, 2009
  • 35 Answers
could be the float valve is stuck or has some object blocking it so it cant cut off the water flow..( adjusting the float hight, or cleaning will solve this) or could be the plastic inserts that carry the pads are cracked & allowing water to escape the unit.( replace the pad carrier)..
If your going up on the roof to fix it... you may as well get a onedose cartridge from the hardware shop & put that in the tank whilest your up there...
Posted on Nov 10, 2009
koolbreezes
  • 540 Answers
SOURCE: Is it possible to get a new manual for my Vulcan
Check out this website for manuals.
Posted on Dec 22, 2009
Bonaire vulcan evaporative air conditioner
check your filter for dirts, clean or change it, check your evaporator and condenser coil and clean....
Jan 29, 2014 | Heating & Cooling
I have an evaporative cooler: vulcan bonaire. the only control buttons which appear to be useful are: on/off, cool in the 'appliance' window, and cool in the 'mode' window. i have a feeling that this is...
Hi and welcome to FixYa. The principle of operation of an evaporative cooler is to provide cooler air via evaporation. The evaporation process is achieved by water being pumped over very porous pads with air is drawn through the pads. Most all evaporative coolers unless connected with a centralized heat / cool system only have an on / off & cool function. "On" is fan only (air circulation while using outside air being drawn into the home) and "cool" turns on the pump to pump water over the pads for evaporative cooling. Hopefully I did not confuse you with my answer.
Happy New Year and thanks for choosing FixYa,
Kelly
Jan 01, 2011 | Heating & Cooling
Our Bonaire Evap Cooler stopped after power failure
Turn the power of to both the heater and the cooler. Turn the power back on to the heater and the cooler at the same time then reset codes on controller.
Feb 07, 2010 | Mastercool 67471 Evaporative Cooler Air...
We have a Vulcan Bonaire evaporative cooling unit and all is working well but water constantly leaks...wasteful. second last bloke I got to have a look at it didn't want to go on the roof...the last one...
Nov 08, 2009 | Mastercool 67471 Evaporative Cooler Air...
Bonaire evaporative cooling not coming on
Everything depends on the pump coming on and possibly the float switch. Check bot and your power supply. Let me know if they are ok.
Oct 31, 2009 | Heating & Cooling
We bought a Bonaire cooling system at yard sale, it leaks water after it is running for awhile, plus it sprays water out the front
I take it this is a window Unit , the water is coming in the room because the Unit has to be pitched about 1/2 into the back ( outside ) or the drain line is clogged ( dirt) stopping water from flowing to condenser ( that cools the coil)
The water is condensation from warm air hitting the cold coil .
Jul 17, 2009 | Mastercool 67471 Evaporative Cooler Air...
We have a Vulcan Bonaire evaporative cooling unit and the control panel is currently flashing on and off and there is a really annoying beeping sound every 30 seconds. We bought this house with the system...
Mar 03, 2009 | Mastercool 67471 Evaporative Cooler Air...
Jan 27, 2009 | Mastercool 67471 Evaporative Cooler Air...
Control panel lights constantly flashing
Jan 04, 2009 | Mastercool 67471 Evaporative Cooler Air...
Mastercool 67471 Evaporative Cooler Air Conditioner Logo
1,956 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
acrman404a
Level 1 Expert
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
