Question about Samsung SCX 4200 All-In-One Laser Printer
Printer won't print
My samsung SCX-4200 will not print anything off the computer.  the copy function works, but nothing off the computer.  when I hit print on the computer, the printer says printing, but it does not print.  in the print dialog box the print job disappears as if it had been printed but it hasn't?
  • 2 more comments
  • Phil_in_Vn Jan 30, 2009
    I just bought a new 20" iMac running OSX 10.5.4  and after installing the Samsung drivers from the CD and also from their website - I have the identical problem.   The print queue dialog pops up on the Mac, the green light blinks on the Samsung device.. the motor whirls.. then.. nothing.   The print job disappears from the queue but no paper is forthcoming from the printer... any solutions out there???
  • Anonymous Feb 06, 2009
    My printers start doing noise and then nothing...
  • subito Feb 20, 2009
    exactly the same problem with Mac. Copying without problem, but doesn't print, despite writing in the dialog box:completed
  • laura622 Mar 23, 2009
    We have an apple network with a time capsule as the router. At the beginning we used to print directly from the computer, and it worked, now we connected the printer to the TC and sometimes it worked, and sometimes the printer decides to respond hours later. We tried to connect the printer directly to the computer again, but now it is not responding at all any more. I updated the drivers but this does not seem to help either...
Mac OS X 10.5.5 update disabled some printers.  you have to reconfigure the printer on your computer
Posted on Jan 31, 2009
I fixed the problem by downloading other Samsung drivers from the Samsung websiet.  In the end I think it was the SCX 4300 driver that worked.
Posted on Feb 21, 2009
Managed to solve the problem, through choosing add another printer (in the box, after choosing Print). Then my Mac looked automatically for drivers, which this time worked (the ones installed from CD and downloaded from www.samsung.com didn't)
Posted on Feb 20, 2009
I have a printer samsung scx-4200. when i click start button in order to make a copy it remains unchanged no voice at all and no errors as well, when i connect to the PC it is being detected by PC but the...
Appears to be a driver problem. Toward the end of the page of this supplied link are purportedly a couple of solutions. They may require translations. Either Google translate or Q Translate freeware may assist.
Updating to Mavericks Samsung Scx 4200 can no longer print and scan
Dec 09, 2017 | Samsung SCX 4200 All-In-One Laser Printer
Just brought my SCX 4100 into use in my office, worked perfectly at home on a Windows XP system but in the office on a vista system the printer works fine, the copy function within smart thru 4 functions...
Did you install the correct driver including the scan driver? The drivers are available at the Samsung Site: http://www.samsung.com/us/support/downloads/SCX-4100 . Click on the Driver tab for most or the Software Tab for the SmarThru4 program. Make sure to get the correct version for the OS on the office computer. Generic OS drivers often only run the printe, not the scanner. Uninstall the generic driver before attempting to nstall the Samsung driver.
Next check the data cable. Scanners require bi-directional communication with the computer and can fail when the printer works.
I hope this helps.
Jan 24, 2011 | Samsung SCX-4100 All-In-One Laser Printer
When photocopying, leftside print missing/text
it is only happned when you takes only photocopy ? or Printing... The same will be affect while printing and copying may be the problem related to Laser Supply unit, open the LSU and clean the LSU mirror with a cotton waste. Your issues must be solve....
before that pls. check your cartridge unit...
Apr 24, 2010 | Samsung SCX 4200 All-In-One Laser Printer
I/O error when trying to scan. Used to work OK
Good day Sir,
These are my suggested solutions.
  • There ma be a copying or printing job in progress. When the job is complete, try your job again.
  • The selected port is currently being used. Restart your computer and try again.
  • The scanner driver is not installed or the operating environment is not setup properly.
  • Ensure that the machine is properly connected and the power is on, then restart your computer.
  • The USB cable may be improperly connected or the power may be off.
Thank you and God bless.
Nov 19, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Won't Scan
try scanning through your computer printer/scanner programs. This is the only way I could get my Samsung to scan anything
May 20, 2009 | Samsung SCX 4200 All-In-One Laser Printer
SCX-4200 cannot make multiple copies
I believe on this unit that when you increase the # of copies, you have to press the set or enter button to accept the amount, then press copy. Most small Samsungs are like that.
Jul 01, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Sharing the scanner
no it is not possible it will only share fax and print mode but not the scanner.
bye
Nov 19, 2007 | Samsung SCX 4200 All-In-One Laser Printer
Cannot operate scanner
Just posted two solutions to my problems. see here.
http://www.fixya.com/support/t134648-scanner_not_working
Hope it helps
Nov 02, 2007 | Samsung SCX 4521F All-In-One Laser Printer
[no paper] in SCX-4200
there 9is a paer sensor which senses when there r papers ,prob might b that either it is not functioning or on of the sensor is depressed
Jul 29, 2007 | Samsung SCX 4200 All-In-One Laser Printer
Samsung SCX 4200 All-In-One Laser Printer Logo
549 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
