Question about Saws
I have a tsc-10 table saw...where can I get spec for parts
When moving the table saw...we took the round guide off to get saw through the doors...I put the screws and spacers in a good place so I wouldn't loose them...know I can find where I put them...I bet you have never have done that.
  • David Ford
    David Ford May 11, 2010
    What is the exact model and brand for this saw and I will see what I can do.
  • 80 Answers
SOURCE: How to change blade on 10" Craftsman table saw?
you need to grab the blade with something.maybe some pliers(if you are not going to refurbish blade) and loosen the nut in the center of the blade. i think it is a left hand thread(cw to loosen) because of the rotation of the blade. if the nut is on the left when looking from the front it is probably left handed. make sure it's unplugged and wear leather gloves so you don't get cut. install in reverse...
Posted on Jan 20, 2009
  • 1996 Answers
SOURCE: I need a pdf for my 1989 Grizzly Table Saw Model TSC-10
I'd need the model number, or more info to point you more closely, but take a look at this site and see if you can't sort it out:
If that works for you, please let us know. If not, provide a little more detail and I'll see what I can do.
Best wishes...
Posted on Mar 26, 2009
  • 59 Answers
SOURCE: old craftsman table saw parts?
most sears stores have a dept. that refurbishes and sells these tools. if it can be had, they can help.
Posted on Apr 25, 2009
  • 384 Answers
SOURCE: key switch on Craftsman table saw
Switch is filled with sawdust. Disassemble and clean out.
Posted on Sep 14, 2009
  • 3 Answers
SOURCE: New table saw, timber runninig off away from
I have the same problem but it is not the fence is the motor. This is a direct drive saw and the motor needs to be true to the fence. Sears has it set up to make some small adjustment but it is not enough to to true up the blade. I am in search of a good solution to at least make it cut straight when using the fence.
Posted on Jun 08, 2010
Grizzly tsc 10
sometimes using shim stock will allow pulley to grip shaft...prob need to visit a machinist.
Jan 09, 2014 | Saws
We need a downloadable user's guide for this product. Thank you.
Go to:
Sep 23, 2013 | Craftsman Sears Table Saw Manual Model...
Need to know how to change the agle on the blade for a protech 10 in table saw
Hi Ron,
You didn't give your model.
Protech is out of business so I could not find a user's guide for you.
The knob on the front that you use to raise and lower the blade also adjusts the angle. Depending on your saw, normally the knob releases from raise/lower mode to angle adjustment by either pulling the knob out and moving it or by pushing a lever to release it and then moving the knob.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
May 09, 2011 | Skil 10" Table Saw
I have a Delta 36-979 table saw. In a recent move, it seems I lost the drive belt when I took the motor off for ease of moving. Can I get a replacement at a local auto parts store or do I need to order...
I can't find any specs for this belt, You can buy it online from them the part number is 643928 and the cost is around 7.22, Sorry but this is the only information I can find for you.
Apr 17, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
Need electric motor for model #113241680. what is the rpm and horse power.
here is the sears parts for your saw
looks like they dont sell the motor any more. as long as you have the spec plate on your motor you should be able to match up something from a parts house or anyone that sells electric motors. in my area its Granger
Dec 28, 2010 | Craftsman 10" Table Saw
MAKITA #2703 table saw 10'' to rise and lower blade it
i would say the table is twisted then, strip it down first and if you need to "bend!" it back so it works
Mar 27, 2010 | Makita 2703 10" Table Saw, Electric Brake
How do i change the angle move it round
you would need to loosen the handle and I believe there is a spring type of clip that you need to push down on to move the table and then retighten the handle
Mar 18, 2010 | Makita 10" Miter Saw LS1030N
I have a Craftstman Table Saw Model #137.218240 and Serial # ROU 1041 and must replace the motor with a new one I have acquired. Where can I find a repair manual that will guide me in the proper...
CLICK HERE for blowout diagrams that details part numbers and assembly.
There is no "repair guide" available for most small power equipment, as there are relatively few parts to assemble, and easily figured out.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 10, 2009 | Craftsman 10" Table Saw
Best wishes...
Mar 01, 2009 | Saws
Dewalt 10" table saw, when ripping jambs @ back of guide?
Without knowing the full problem, (theheader is cut off) I would ask are you using the fence to help you rip? and when does the board jamb? If it jambs toward the back of the saw the guide might not be square with the blade. I would unplug it and put something that you know is square on the front edge of the blade away from the teeth and adjust the fence so that it is just snub then lock down the table and move the square to the back of saw, it should move with no resistance. If it does then the fence is out. What you would need to do if this is the case is align the fence to the blade, on the back of the saw are 2 10MM bolts that you need to loosen put your square at the front again and lock down the handle with that done move the square to the back and tap the rail on the back side to move tighter or looser and then lock down the bolts. What I do is move the fence away and then back and start all over again to make sure nothing shifted. It sounds more involved than it is. Let me know if this cures your problem
Jan 12, 2009 | Dewalt DW746X 10" woodworker's table saw...
Saws Logo
714 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
