Question about Panasonic Viera TH-50PZ80U Plasma TV
Panasonic Plasma with C.A.T.S Feature is Causing IR sensor issue
I'm a Comcast Cable Tech. I was sent to a customers home to check a DVR/Remote issue. after about an hour of troubleshooting, swapping the DVR and several remotes, I realized that the problem was caused by Pannosonic Plasma's C.A.T.S feature. The problem the customer was experiencing was our DVR remote would intermittently opporate the set top box. When I turned the TV off, but left the set top box on, the remote keys worked without a problem. What I discovered was when C.A.T.S. is disabled, we experience the IR issue, when C.A.T.S. is enabled the problem goes away, but it resulted in a much dimmer resolution on standard deffinition channels. Another Tech experienced the same issue with a SHARP AQUOS wich has a similar feature (OPC). The strange thing about his issue was IR interference occurred when OPC is enabled but no IR issues when disabled. Sharp is aware of their issue but I have not been able to find any answers from Pannosonic. Any info you might have would be greatly appriciated.
Thank you,
Joe
SOURCE: Can I set up tv remote to also control cable box?
Just bought a Vizio 22" 1080 p TV and need to set up a Verizon Fios remote for it. The codes for Vizio for the remote do not work. Can anyone help me with this.
Steve
Posted on Jan 14, 2009
SOURCE: Panasonic 50pz80u remote code
They posted updated codes:
http://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Posted on Feb 15, 2009
  • 197 Answers
SOURCE: I need the code for a comcast cable remote
go to comcast.com
Posted on Jun 07, 2009
SOURCE: Viera Link not work between two brand new Panasonic devices
You need to select setup from the TV menu then switch the Viera link on. I think retuning must have switched it off.
This worked for me
Posted on Oct 03, 2009
tvservice306
  • 458 Answers
SOURCE: My Panasonic TH-42PX60U Plasma tv will not respond
need panasonic remote
Manufacturer Panasonic Part Number EUR7737Z20 Description REMOTE CONTROL
Posted on Nov 09, 2009
Why wont the remote control feature work on my Panasonic TCP50UT50 Plasma, is there a feature to disable the remote, panel works well
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
Jul 21, 2015 | Panasonic Televison & Video
Comcast DVR caused house to blow a fuse
Hi Karen,
Based on your issue I believed your DVR was already damaged too due to electrical issue. You may want to talk to their Tech support in order for them to replace your box, anyway it is free swap to the new one. I was previous Comcast Tech Support that is why I know their process. Contact them here 1-800-XFINITY(1-800-934-6489). or you can visit their website here:
Comcast Phone Number Customer Service Contact Information
Mar 03, 2014 | Comcast Televison & Video
I have a problem with my Panasonic CT-27SX12 27"
On remote you must push the TV button first then the on button to activate or deactivate the TV. Channel or volume on the TV does not need to select anything on remotes.
Nov 18, 2010 | Panasonic CT-27SX12 27" TV
Remote Code for Comcast DVR
See http://www.comcast.com/corporate/customers/customer_support/remotes.html
You will most likely have to use a VCR code and program it to the AUX button.
Feb 26, 2010 | Panasonic PV-C2541 25 in. TV/VCR Combo
I have bose v30, dishnetwork 612 dvr. When
I recommend you switch from using HDMI cables to using component (R/G/B RCA-style) cables. HD picture is superior through component cabling, and solves several HD picture issues.
What is happening is that when video resolution changes (like from regular programming to commercials) the video information is poorly sent down the HDMI line. Component cabling from your DVR will eliminate this problem.
I hope that helps.
Feb 06, 2010 | Bose 36037 Remote Control
I got Two TV's My TV Connected to remote 1 in IR mode. After trying to record some thing using dvr the remote dies on satellite cannot change channel... Tech team tries every thing send new remote and...
topscrew2002
From what you have written, when you try to record on your DVR the remote stops working, is that correct? How long has this been happening? Have you received a new remote? If yes and it is still happening, you are probably getting IR interference from some source in that room. It could be from a florescent lamp, another player, or even the TV. Is the receiver in a open space or in an enclosed area? The IR sensor has to have a direct line of sight to work properly. You may also check on the receiver if anything is obstructing the sensors, maybe dust. I hope this helps.
Ray Calo
DISH Network
Dec 02, 2009 | DISH Network IR Remote Control
Panasonic 42" connected to comcast dvr, and dvd player
To solve need more info if this is still a problem.
Is your comcast dvr connected directly to the tv, and also the DVD connected directly to the TV?
If so then you will need to change the input selection on your tv remote to determine which inputs these devices are connected to.
If you are connected differently, please post how your devices are connected.
Dale
May 11, 2009 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Comcast DVR 3 Remote doesn't work with TV
You may have to use a separate remote control for your TV.
Jun 05, 2017 | Emerson Televison & Video
Program a Comcast Custom DVR 3 remote for Samsung HT-X40 system
What is the color of the Select/OK button on your Comcast remote: is it red or grey?
Feb 24, 2009 | Samsung HT-X40 System
Panasonic Viera TH-50PZ80U Plasma TV Logo
2,483 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
