Question about Kodak EASYSHARE V1253 Digital Camera
Lens jammed on a kodak v1253
Have you had any diy solutions for the jammed lens
  • chareesims Feb 02, 2009
    the lens will close partialy and open partialy...the lcd will no longer show a display...i've tried charging but it's not the charge...the camera shop said the lens was jammed...just going off what they said...
I fixed my v1253 following these steps:
1. Pulled the battery when the lens starts to come out before it could power itself off.
2. Gently pull the telescope out until it clicks.
3. Use a fine tip paint brush to clear debris out of the cracks.
Camera works just fine now.
Posted on Mar 31, 2009
  • 3 Answers
WELL....DEFENSE WHAT KINE OF LENS PROBLEM YOU HAVE ITS LOT OF JAMMED LENS WE COULD EXPLAIN IF YOUR LENS WAS IN AND OUT YOUR LENS WAS DIRTY IF YOUR LENS WAS BENT MY BE YOU DRAPE IT THE BARREL INSIDE WAS BENT OR BROKEN ITS A LOT OF WORK ON THE LENS
Posted on Jan 31, 2009
Kodak v1253 camera turns off when zoom lever is activated
Maybe the lens movement is sticking and causing additional overload for the camera circuits, thus causing it to shut down.
Dec 21, 2013 | Kodak EASYSHARE V1253 Digital Camera
The camera switches off immediatly after switching it on, an the lens is not closing anymore. Is there a way to reset the camera with a combination of the buttons?
Not really, but it's most likely a lens problem. Resetting wouldn't help anyways. I have repaired a lot of these V1253 / V1233 with such a problem. It has to be taken apart and cleaned. Sorry for the bad news. I have worked in a Kodak service center.
Jan 23, 2011 | Kodak EASYSHARE V1253 Digital Camera
I have a kodak easyshare v1253 and the unit turnes on, the lights activate and the lens clicks to try to open the unit turns off. The lens does not open. I sent it in for warrnety for the same problem a...
Im sorry about that, well anyway it seems that the lens of your camera is already defective,
are you using the recommended battery Lithium-Ion battery (KLIC-7004)? If yes try to charged the battery and if this issue not solve Please call kodak Toll Free 1 800 235 6325 canada and U.S support only
Nov 03, 2009 | Kodak EASYSHARE V1253 Digital Camera
Lens won't retract. Camera powers off immediately after powering on without retracting lens. New battery didn't help.
Are you using the recommnded battery KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7004
first you need to do make sure the battery is fully charged., now if you if this solution will not resolve the issue it means that the Gear Lens is defective thats why your Lens will not retract and camera will not stay On. you need to call kodak to send your camera for repair call toll free 1 800 235 6325., Gudluck!
Oct 31, 2009 | Kodak EASYSHARE V1253 Digital Camera
Kodak V1253 lense won't close
Use the vacuum cleaner to suckout the dust/sand particles stuck between the lens casing and the body.
Aug 11, 2009 | Kodak EasyShare Z1275 Digital Camera
My kodak easyshare V1253 Powers up, then shuts off
You have damaged your lens. If the camera can not move the lens it goes through a built in diagnostics test and shuts down. Beyond repair as cost to replace is beyond the value of your camera.
Jul 03, 2009 | Cameras
Easy share V1253...will not stay on...lens will not telescope
I have had the same issue were the lens would not retract. took it in for extended warranty work. lens now retracts but takes lousy pictures.
When I purchased this camera family members ran out and bought thiers shortly after I did. One by one the same issue has happend to their v1253's.
I dissmantled one and found that there is a tiny battery on the power board inside of the camera. apparently the tiny battery's life is about 1 1/2 years. This battery is not serviceable as it is welded in place. I am not one hundred percent sure if this is the cause but it makes sense.
It would be nice if kodak would own up to this issue and make good on repairs as they did with my kodak 5500 all-in-one printer and it's crappy print head. Kodak has sent me 4 print heads in the 2 years I have owned it.
I have 5 of the v1253's in my family and every one of the are dead. I would think a $250 product should last longer than 1 1/2 years.
Hope this helps you out.
Jul 01, 2009 | Kodak EASYSHARE V1253 Digital Camera
V1253 Kodak Lens stuck open, will not power on
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.
Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u rate me!!!
Feb 12, 2009 | Kodak EASYSHARE V1253 Digital Camera
Lens jammed will not retract, canon pc1147 zoom
hope this helps.
Aug 16, 2008 | Kodak EASYSHARE V1253 Digital Camera
Kodak EASYSHARE V1253 Digital Camera Logo
565 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
