Question about Intuit QuickBooks Pro 2007 Full Version (299116)
My QB crashes everytime I try to invoice...only with one company, but with others it runs fine. Problem is i need the giles from that one company, What do I do?
  • 32 Answers
You should verify your data file (Click on file, click on utilities, click on verify data) If quickbooks doesn't find any problems, Back up your company to a different location and if your using 2006 or higher, create a portable file, close quickbooks, reopen quickbooks, and then click on open portable. When it prompts you to backup, click ok and back up again using a different file name.
You then need to go to templates, and (sorry to tell you this ) change each one to the default setting (click on lists, click on templates, the click on templates at the bottom, and click on edit, click on additional customization and then default. Then click save and close. Do this for all templates.
Also resort each list (item customer and vendor) to their original order.
Close the file and then reopen and verify data - if this doesn't fix the problem you will need to contact a pro advisor or intuit for aid in fixing the file
Posted on Feb 06, 2009
Duplicate invoice number
Quickbooks runs invoice numbers in sequence. If you overwrite an invoice number (for example, QB may number an invoice number 2, and you may change it to 3), then QB will not remember your selection, and its next number will be 3. Under edit preferences, select to warn of duplicate numbers, and then you can fix the problem before finalising the invoice.
Feb 26, 2014 | Intuit QuickBooks Pro Edition 2003 for PC
Error message:The file was not closed in the previous session. Rolling back to last fully recorded transaction. Click ok and lock up
It sounds like data damage. Go into Qb, then go to file, utilities, verify the data. If it fails you may need to rebuild the data.
Mar 26, 2012 | Intuit QuickBooks Pro 2002 (260102) for PC
Quickbooks Pro 2007 has stopped working. when i
uninstall the software 100% reboot the machine so the information obtained in ram is not going to interfere with new installation. using your original cdrom that came with the kit, install your quick books 2007 software register it with the original code and product id sequence numbers. when it tries to run theirs 3 things happening now. the program in initializing it;s visual c run time libraries. and well as calling the dynamically loaded libraries from the windows directory and other locations. if a program was removed that used these files and it was uninstalled with the files then it is possible you will have to install qb from scratch and use the qbw or quick books workspace file to run your company files afterwords. backup the qbw files encase of problems. this is often tell take sings of viral or system melware. then scan with your virus software. and see if anything was crashing the program. other options involve system files missing that are used. good luck.
Sep 20, 2009 | Intuit QuickBooks Pro 2008: Windows
Quickbooks Premier 2008 will not open quickbooks 2008 Pro files. What's up?
If you need the resolution, please reply with the foll :
1. Which Windows Version you have . Is it Win XP or Vista or 7?
2. How do you try to open the company file ? Please list the steps .
3. Do you get any erro msg ?
4. Does QB crash?
5. Do you have a backup company file QBB or main company file QBW ?
Please try these steps or reply to my questions:
1. Change the location of the company file.
2. Disable UAC.
2. Rename the company file .
3. Delete the ND and TLG file .
Apr 24, 2009 | Intuit QuickBooks Pro 2008: Windows
Upgrading from Quickbooks Pro 2003 to Quickbooks 2009
I would not open up the company file in 2009. Open your 2003 Quickbooks, make a backup and then restore the back up in 2009. If you do run into problems you might want to upgrade into 2006 and then to 2009. (you will need to find someone who can do this for you if you don't have a 2006 version. I can help you with that if you need it
Jan 21, 2009 | Intuit QuickBooks Premier: Accountant...
QB Ed 2008, When I
Error -6177 means that the file is not accessible at the location QuickBooks is trying to open it.
The reasons for this may be:
1. The network is offline. Make sure that the directory is available or that you're still connected to the network.
2. The file was deleted by someone else available on the network.
3. If you have recently updated Quickbooks from an earlier version, then the cause may be a bug with the product itself. It has been reported by other users that they experience Error 6177 everytime they try to open a previously existing file.
Try the following link. Might help:
Mar 04, 2008 | Computers & Internet
Printing landscape instead of portrait
this article may explain how to change it
Mar 05, 2017 | HP OfficeJet 7410 All-In-One InkJet...
Web Server Crashes on port 80.
A couple of questions for you...
1) What do you mean by 'crash'? How do you know its crashed?
2) Can you look in the Windows Event Viewer to see if there are any warning/error messages in the Application or System logs around the time of the starting or crashing of your web site on port 80? If so, anything that suggests the issue. If you don't understand the errors, try posting some of them here.
3) Is there any other web server running on port 80? If your running Internet Information Server, open the Internet Information Server Manager (mmc) console and click on "Web Sites" and it should list all the sites in the right pane. If you have anything 'running' on port 80, it will conflict.
4) Are you running Apache or any other web server on the system? If so, you're going to need to look at those configurations as well.
5) How about any other applications that might have a built in web server?
Let me know.
Jan 14, 2008 | Computers & Internet
Intuit QuickBooks Pro 2007 Full Version (299116) Logo
157 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
