Question about RCA Scenium D40W20 40" Rear Projection HDTV
RCA R52WM24 NO CONVERGANCE
I HAVE A 2006 RCA R52WM24 AND WHEN I GO TO THE MENU AND THEN TO SETUP IT DOESNT SHOW THE CONVERGANCE MENU AND IT HAS ALL THE COLORS R,B,G SIDE BY SIDE AND CONCAVE SCREEN, WHAT I HAVE READ THERES A $5.00 PART THAT I COULD INSTALL MYSELF ( I THINK ) AND I ALSO HAVE A HD52XXX THAT TURNS ON AND WORKS FOR ABOUT 10 MINS AND THEN SHUTS OFF AND TRYS TO TURN BACK ON AND THEN QUITS I UNPLUG IT FOR A WHILE AND IT STARTS ALL OVER. ANY HELP ON THESES PROBLEMS WOULD BE THANKFUL
  • RCA Master
  • 8,617 Answers
The convergence issue is caused by FL231, DL231 and CL230 the following link has the parts under the RCA category plus they help explain the repair procedure.
http://servicemanuals.vstore.ca/
Posted on Feb 04, 2009
A curve of red blue yellow lines at the top of screen and when dish is off it has these colors in a square around the screeen. When dish is on almost look like a double picture. Was fine one second and...
hello it sound like convergance problem go in to the menu on your tv and try resetting the convergance. if don't reset then the convergance ic need to be replaced hope it helps
regards
shaun
Feb 25, 2011 | RCA R52WM24 52" HDTV Projection Television
RCA r52wm24 projection hdtv. Colors of tv not aligning images look like they are in 3d without glasses.
this is called convergence.the first step in diagnoseing this set is to go into customer menu under the setup option. DO you have the donvergence listed in this menu. if you dont read this http://www.fixya.com/support/r1062030-fl231_problem_convergence_not_in. if you do then try using autoconvergence and manual options in this menu. if it doesnt work then more than likely you will have some faulty components in the convergence cuircit. let me know and ill seel if i can help more
Oct 30, 2010 | RCA R52WM24 52" HDTV Projection Television
R52wm24- images looks blurry with some lines, how can i fix it?
Go to menu then setup Look for convergence if it is not listed on the menu then you have an open fuse FL231 Located on the deflection board on the right hand side of the FBT flyback transfomer theu will be 3 in a roll small brown looking caps it will be the one in the middle .Partstore.com has them
May 29, 2010 | RCA R52WM24 52" HDTV Projection Television
Color doesnt line up
Need to use convergance, if you cant do it from your remote go to menu and align.
Apr 28, 2010 | RCA R52WM24 52" HDTV Projection Television
Convergance is off
I have an RCA 52” HDTV Model R52WM24 the other day it developed a convergence problem (The picture took on a 3D effect and it the screen had an hour glass type of shape)
This appears to be a common problem or a pattern failure.
I wanted to confirm that I did find the fuse p/n FL231 to be blown.
I think it said the RCA part # is 259213 and it is a 400 ma, 125V fuse, Looks like a square capacitor by the fly back xfmr.
I bought a generic part from Digi Key and it seems to be the identical replacement part to the fuse that was in the circuit.
The Digi-Key part is part # WK4440BK-ND (99 CENTS EACH).
THIS IS A 125V, 400 MA ( 0.4 A FUSE). Digi Key PHONE # IS 1-800-344-4539
I am watching the TV right now for last 3 hours and it seems to be a good fix.
The fly back transformer solder connections looked good but it is recommended to re solder these part ( so I did).
Good luck
Dec 27, 2009 | RCA R52WM24 52" HDTV Projection Television
Convergence menu not available on my RCA HDTV. Model R52WH74YX58
Itsalmost that simple, But you will need to replace the FL231, DL231 and CP230 and that should take care of your problem. You can get the replacement parts at the following link under their RCA Parts category. The total cost is around 13.00 and shipping is free and they even send detailed instructions with pictures that show how to do the repair which is very easy.
May 28, 2009 | RCA R52WM24 52" HDTV Projection Television
Convergance
push the menu button - leftmost button on front of the tv. use the arrows on the ch and vol buttons to navigate the menus. go to the bottom item on the menu select it select autoconvergence you will however likely have to do manual blue and red convergence because often auto is not enough. see how that does.
Jan 25, 2009 | RCA R52WM24 52" HDTV Projection Television
I have a rca r52wm24 hd monitor the color is bad theres 4 of everything cannot access the convergance on menu ,watched tv repair person one time and he pressed some buttons together to get into a grid and...
Shut off tv, wait 30 seconds, then at the same time press the channel down and the volume down buttons and wait for power light to come on and then release.
Sep 10, 2008 | Televison & Video
Rca d52w23
if u press menu on remote control and scroll down to set up , press ok and see convergance as an option choose it and adjust convergance.(lines up your colors) if u do this and convergance does not even show on your menu at all anywhere! like mine, then u have an open fuse for convergance board. mine is going to shop for this today.
Sep 17, 2007 | Televison & Video
RCA Scenium D40W20 40" Rear Projection HDTV Logo
99 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
