Question about ViewSonic VX922 19" Monitor Flat Panel
Power blinks green on lcd 17" veiwsonic
If i plug this unit in . it just blinks green. If i unplug it , it blinks green 3 to four times for 1 sec at a time. the four or 5th blink is a little longer, if i catch it just right by pluging it back to the lcd on the 4th time it will stay on for good, till i shut it off. other than that you can shut it off with the power button, but it will start blinking again. thanks dave
  • 624 Answers
This is a duplicate posting, click on the link below to view the active post: http://www.fixya.com/support/t161845-17_veiwsonic_power_blinking_green
Posted on Jul 28, 2007
SOURCE:
When I will plug in the pludg into power, LTV-42ASB whitout press a power knob, start blinks blue light in corner 3 times and then I see on screen logo ,,ASTAR.. After 3-4 sec TV want to show next ...
U can still hear the tv audio,after the picture logo is gone and went to a black screen panel a few sec later?Yes,than the tv have these 1 or 2 long boards call the LCD inverter baords are dead.These 1 or 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a pcture.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 long refurbishes LCD inverter boards for the replacement.
Dec 04, 2010 | Televison & Video
My wrt300n power led is blinking and the rest of
Hi Friend
Please follow the steps to reset the router in a different way
1) Press the reset button for 10 secs and after that unplug the power cable from the router and wait for 10 secs
2) Plug the power cable back and press the reset button again for 10 secs and after that unplug the power cable from the router and wait for 10 secs
3) Plug the power cable back and press the power button for 10 secs again and unplug the power cable from the router for 10 secs
After trying these steps if you see the power light still blinking then you need to replace the router. Please call the customer care of linksys 1800 546 5797,they will let you know how to replace the router
warm regards
Chiranjeet Mitra
Oct 06, 2009 | Linksys WRT300N Wireless Router
MY 6310 just stopped on me. I have to unplug and plug it back in but stops again. All lights are blinking and it said to RESET POWER.
HP 6310 Reset
There are 3 types of resets in the printer
1.Partial Reset
2.Semi full Reset
3.Full Reset
To do partial Reset.
1. Unplug the power cable and turn off the the unit.
2. Press and hold # & 3 at the same time with out connecting the power cable.
3. While holding the button, connect the power cable and do not the release button for 5 sec.
4.Then turn ON the unit
To do Semi full Reset.
2. Press and hold # & 6 at the same time with out connecting the power cable.
4.Then turn ON the unit.
To do full Reset.
2. Press and hold # & 9 at the same time with out connecting the power cable.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 29, 2009 | HP Officejet 6310 All-In-One InkJet...
FAST BLINKING GREEN & WON'T POWER ON
I had exactly this problem. After plugging and unplugging it multiple times over several weeks (even plugging it in quickly after it was unplugged but with the green light still flashing as suggested here) all to no avail, it just started working on its own one day. It worked for a few weeks and then the problem re-appeared.
InFocus tech support recommended:
1. Check whether the lamp door is securely closed.
2. Check the color of the LED and the number of time it blinks. (For me, a very fast almost flickering flash)
3. Does the fan operate? (My fan would go on when plugged in)
4. Remove the lamp module, shake it gently and reseat the lamp module.
For me, these steps did not work. InFocus then recommended that I send it to ProjectorDoctor http://online.projectordoctor.com/, and it was diagnosed with a bad power supply. $395, but it is fully functional again. Good luck.........
Jul 24, 2008 | InFocus ScreenPlay 7200 Multimedia...
Power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
I have a VeiwSonic Monitor model VA712b that went blank.
sell it.. the product and sevice from viewsonic in my opinon sucks nothing but problems tv less then a year old want to ship it back and forth to fix it piece of s**t
Feb 26, 2008 | ViewSonic VA712B 17" Flat Panel LCD...
Monitor blink
1. this is may be due to the 5 volt power supply. which may be down. the current u can measure is ok (5volts) but the ampers may be down. because in off or stand by position it consume very little current but at the time of self test it consume more then 900 milliamps. ( replace the regulator of 5 volt)
2. May be the EHT transformer drive transistors are short. check them, if there is any leakage or if they are short then replace them.
Jan 22, 2008 | Dell E173FP 17" LCD Monitor
17" veiwsonic power blinking green
The flashing green power button is a well known electronic problem with this (and other) Viewsonic LCD monitors. There is a YouTube video (do a search) showing how to disassemble the VX924 and find out whether the problem is related to blown capacitors. When I took my VX922 apart I discovered 6 bad capacitors out of a total of 7 on the power supply circuit board.Only recommended for those handy with a soldering iron.
Jul 28, 2007 | ViewSonic VX922 19" Monitor Flat Panel
Lcd 17" veiwsonic power problem
17" lcd veiw sonic power blinks
ViewSonic VX922 19" Monitor Flat Panel Logo
185 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
