Question about Epson Stylus CX5400 All-In-One InkJet Printer
Error right cartridge`
I had my cartridge refill when i used back my printer have this error check right cartride
    Genius:
  • 2,035 Answers
Try this steps if this did not resolve the issue just turn off the printer power on if still get the error then you need to install original new cartridge from the company as the printer cart have inbuild chip which detect refilling ..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Posted on Jan 30, 2009
Lexmark x4650 refilled ink cartridge but printer says it's empty and won't print
Lexmark does not recommend using refilled cartridges. However, if you have successfully used one before, there's a possibility that the refilled cartride got damaged along the process of refilling. Try to insert a different known working cartridge to determine if the other is faulty. Or better yet, try to purchase a new genuine Lexmark cartridge.
Jun 14, 2011 | Lexmark X2500 All-In-One Printer
Error 5...ink cartridge is not recognized after refilling
Clean the contact point of the cartridge to the printer before placing it, then **** some ink in the cartride by a cyringe to lessen the level of ink inside the cartridge. full ink cartridges encounter this error because the absorver inside the cartride overflows.
Mar 28, 2011 | Office Equipment & Supplies
I changed my cartride but it is not alligning?It is giving default value error.How do I solve tthis?
check expire date on cartridge
you can still use it by s*cking all the
old ink in the cartridge and refill it like this
utube.png You-Tube video "sOriLrbuBao" placeholder (do not delete) utube.png
utube.png You-Tube video "II9gpIXs_lE&feature=related" placeholder (do not delete) utube.png
Apr 01, 2010 | HP Officejet 5610 All-In-One InkJet...
I have a brand new cartride ,but my printer prints blank pages
If its a new cartridge then check if you have removed the pad below the print head to print.
Jan 29, 2010 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X3550 ink cartridge #23 receiving error message "left cartridge incorrect" when trying to replace. Using Lexmark Cartridges only for over 1 year, now cartridge won't work.
There are a small number of #23/#24 cartridges that are not properly recognized by the printer. Lexmark has a firmware upgrade to correct this issue. The upgrade for the X3430 is available from Lexmark at:
To install the firmware upgrade,
  1. Make sure the printer is ON and connected with a USB cable.
  2. Download and run the appropriate firmware upgrade for your computer.
  3. Be sure not to disconnect or power off the printer until the upgrade is complete
When the update finishes the printer will restart and will accept the cartridges. Please contact Lexmark support if this does not fix the problem.
A similar patch is available for the X3430 and Z1420 models. See http://bit.ly/LoXxv
Jun 19, 2009 | Lexmark X5470 All-In-One InkJet Printer
Resetting the cartridge icons on MP 480 printer after refilling cartrdges
I found that if you just hold down the 'stop' button with the little red icon on it for a few seconds, it resets the ink. But the cartridge has to have the error message that says it is completely out of ink, not just low on ink. Hold it down for a few seconds until it starts processing. It will check the cartridge, and then it worked for me!
May 31, 2009 | Canon Office Equipment & Supplies
Cartridge errors..cartridge incorrect
sounds like they're the type of cartridges that cannot be refilled, due to the computer chip on them.
Dec 31, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Keep Getting Error Message "(Colour) Toner Not Installed"
I think in the menu you have to select replace cartride.. then new or same with new toner...
each toner cartridge has connections and you must make sure all are tight... or you get alot of errors.
Sep 10, 2008 | Konica Minolta magicolor 2300DL Laser...
Epson cx6600
If you are using a cartride that has been refilled it may just need recharged. I purchase my cartridges off Ebay and some will not charge, so I just use a small devise, which you can purchase off Ebay, that allows you to reset the cartridge. IF a cartridge does not charge it will not work.
Aug 03, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus CX5400 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
