Question about Qca Spas Majestic Series Aruba Xl Hot Tub
Filter for QCA Aruba xl
Just moved in to the house.Spa has no filter .Where I can find filter for it?.What size,part #?
  • 125 Answers
QCA has used 4 different sized filters in their tubs through the years.
  • c-4326 4-15/16" x 13-15/16" 25 sq ft
  • c-4950 4-15/16" x 13-15/16" 50 sq ft
  • c-4995 4-15/16" x 23-5/8" 95 sq ft
  • c-5397 5-5/16" x 17-13/16" 80 sq ft
you will need to measure the inside height and diameter of housing and see which one will fit best.
Posted on Feb 26, 2009
Aruba spa model1060
bad motor or if it pops breaker disconnect the heater leads remember where they go try it again if it runs bad heater element
Aug 08, 2014 | Qca Spas Majestic Series Aruba Xl Hot Tub
How to adjust pressure switch on hottub aruba spa
IF YOUR GETTING A CODE TAKE SCREWDRIVER AND TURN SCREW ON SWITCH CLOCKWISE
Jul 06, 2014 | Qca Spas Majestic Series Aruba Xl Hot Tub
PSF error code on my artic spa drifter
pressure switch failure check recirculation pump and filters and pressure switch
Apr 27, 2013 | Qca Spas Majestic Series Aruba Xl Hot Tub
Drained my 2000 Great Lakes Spa now OH is displayed when I turn up the heat it kicks out the breaker..
OH is overheat due to insufficient water flow through the heater.
Common Causes:
  • Gate valves not opened/partially closed.
  • Air trapped in suction lines or pump
  • Blocked suction fitting
  • Dirty filter
  • Restricted water discharge lines
Try remove filter cartridge and run spa.
Check pressure switch for continuity.
Unplug & plug hi limit sensor.
Oct 14, 2012 | Qca Spas Majestic Series Aruba Xl Hot Tub
Flo code is on and pump won't start up
Flo = Improper flow or pressure switch malfunction or Flow switch malfunction (system specific).
Before you purchase a new pressure switch:
- Clean or replace your filter cartridge (if its older than 1 yr).
- Check that all slice/gate valves are up/open.
- Check water lines for blockages incl. suction cover & ensure sufficient water level in spa.
Jan 29, 2012 | Qca Spas Majestic Series Aruba Xl Hot Tub
I bought my hot tub used it has no filter i need to no what size of filter it takes also what size of fuses does it use.it is a 220 volt do you know ehat size heater core?
Your tub needs to be hard wired through a 220 Volt 60 or more amp GFI by a professional electrician. Your tub needs to comply with your local codes.
If you will go to your local professional pool supply with dimensions of the filter cavity, they can provide you a cartridge.
The heater 'core' is a large calrod that sits in the water flow.
I hope this information helps you.
Thanks for your interest in FixYa.com
Aug 03, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
Hello! the pump on our qca majestic hot tub
If you live in cold weather and are not using it much lower your thermostat. If the freeze control kicks on (at about 38-40degrees) it will constantly try to heat the spa to where you have the heat set when the air temp is low. Hope this helps.
Oct 28, 2009 | Qca Spas Majestic Series Aruba Xl Hot Tub
Qca Spas Majestic Series Aruba Xl Hot Tub Logo
309 people viewed this question
Top Qca Spas Pool & Spa Experts
Ian Kime
Ian Kime
byrdhaus188
Level 1 Expert
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
