Question about GE Security Simon 3 Wireless Home Security System
How do I get into the program mode to activate motion detector
I bought a extra motion detector and my manual dont show hot to program it HELP!
  • 423 Answers
Remove the mounting plate (on the back) and press the button, or trip the tamper.
Posted on Feb 11, 2009
We have modern Miele induction hob not sure of model it has three single hot plate, one large double extra speed hot plate one double hot plate its in demonstration mod how can l cancel?
I am assuming the timer display is showing "dE" . If you have the manual page 50 (programming) shows how to cancel demo mode. It is program P 0, currently it is set to "0" (demo mode), you need to change it to "1" (demo mode off).
Feb 07, 2016 | Miele Cooktops
Tip
Eaton Home Heartbeat Motion Sensor Description
This indoor wireless motion sensor from Eaton HOMEheartbeat is theperfect wireless motion detector for your home or business. The Motionsensors alert you via email or phone on movement or motion within 15feet of placement. Wireless motion detectors throughout your buildingwork with other sensors to track activity in multiple rooms.
Important Note: Use of this product requires the purchase of the HOMEheartbeat Starter Pack
Review the User Manual at FixYa
on Jan 03, 2009 | Eaton Home Heartbeat Motion Sensor
When arming doors/windows and motion, after the time delay and actually arms, the motions light goes off.. why only doors/windows arm and not motion too?
Is this alarm part of the original car or an add on? Some alarms have different zones that can be activated or deactivated depending on the preference of the owner. If it is aftermarket you will need the manual to execute a sequence to arm or unarm the motion detector zone. The motion detector could be faulty and the alarm is isolating that zone. Need more information to help you
Jul 06, 2015 | Cars & Trucks
Why is the LED light completely off after the walk test and lockout time?
Yes, it works normally. Things have evolved in the technology of security systems and now it is standard to have any LED turned off on any motion detector (the LED's are now used for walk-testing only), the standard DSC and Honeywell wireless motions also do the same thing.
  • This is a normal function for your motion detector. It's also a great power saving function since most of the current draw on the batteries is when it's transmitting a detection signal so if you're home and moving around it will only transmit every few minutes instead of every second, saving on battery life significantly (up to 5 years on average) but after the 3-minute lockout the passive infrared scans continuously until it transmits another motion signal.
Reason: most burglaries are done by someone who has been there before, if they see the LED then they know the motion will catch them moving in that given spot, then they can "map-out" where it's safe to walk (where the LED doesn't light up) for when they plan to return for a robbery.
You can also make this device "more sensitive" by moving the jumper pin position by the right side battery and having the back mounting plate mounted using the bottom screw presets so it faces slightly downward instead of straight forward.
Helpful tip: Change the batteries every 4 years if you're using Alkaline (dead or not) since the detector was engineered "too energy efficient" and the batteries actually leak and corrode the interior PCB at about the 5-year point on about 15% of the detectors with factory original duracell batteries (from what I've experienced in field service).
Apr 06, 2015 | Interlogix GE SAW Wireless Indoor PIR...
Ds 924 motion detector
It may have been previously learned into a zone. Sometimes, the motion will trip and activate a signal that can be learned into another zone you are trying to program. exit programming, then "tamper" the cover for the circuit board, not the battery access, on the motion, check the "status" light to see if a zone is displaying "tamper". Also check battery orientation in back of motion. When battery is first installed correctly. The light should activate during the first minute.
Sep 15, 2017 | GE 60-511-01-95R - ITI Wireless DS 924...
I have a MOD 600 alarm, installed about 9 years ago. Every time I pass a sensor the alarm makes three beeps. How do I stop it?
Hello. This is a normal response to the motions detector while people are active within the home.
The alarm is a semi active mode that is the motions detector will beep, if a door is open there could be active voice alarm or beeping from Central alarm within the home. The same will happen if a window is opened, beep,beep,beep.
In this mode it lets the home owner while in his/her home that the alarm is on and it will let you know when the doors, windows or floor pressure sensor is activated.
There another mode for the alarm system that is if you have pets. It can be activated that only things that are inactive is the motion and pressure sensors. They beep but will not execute the full alarm system.
The there is full alarm system activation where every sensor is operational----full Alarm On....
Now, if you don't like the beeping, then you can turn the alarm system off while you or your husband is in the home. But it will not notify you if the door, window, motion, pressure sensor are activated. I hope this help you. GB....stewbison
Aug 24, 2011 | Kitchen Ranges
Hi my question is motion spot light has has two black wires one from each light and two white from each light and one red from the motion detecter which is connected to the black wires there are two wires...
The red wire from motion detector connects to both of the black wires from the lights. The black wire from the motion detector connects to the incoming black wire from the switch or source. The white wire from the motion detector connects to both of the white wires from the lights and to the incoming white wire from the switch or source (all white wires are under one wirenut).
Dec 18, 2010 | Home
How can I disconnect the motion sensor from the GE Simon 3 Wireless Home Security System?
Your wireless motion detector has been "learned" or programmed into your system. It may be difficult to remove it without a knowledge of how to de-program and you'll also need an installation program manual. A much simpler alternative is to mask off the lens portion of the motion detector. If you are able to open the case cut a small piece of cardboard or heavy stock art paper and place it in between the motion's circuit board and the lens assembly. Once reassembled this will block the detector from seeing motion. If you can't figure out how to open the case another way is to take a piece of cardboard and tape it over the lens face on the outside. Hope this helps.
Apr 15, 2010 | GE Security Simon 3 Wireless Home Security...
I have the Simon 3 security system with one motion detector installed. I didn't set this system up but would like to add another motion detector and was wondering how hard this is to program it into the...
I don't of any system that is simpler to add a device to. The process is in the manual and is something like press "add" on the panel, follow some prompts and press a button on the rear of the motion sensor. Pretty easy if you dont have keypad phobia. Electronic version of the manual is at this location (adding a sensor starts on page 18).
http://www.home-technology-store.com/assets/PDF/GE/Simon-Install.pdf
Mar 19, 2010 | GE Security Simon 3 Wireless Home Security...
Wiring diagram 3 way motion detector switch I want the motion detector to be in the hot line box, and I want a regular 3 way to turn the light on from the load box. So far I can only get the motion...
Sorry, but you need one extra wire between the switches to wire "the opposite configuration" that you want :-(
That means going into the attic and pulling another cable :-( I can walk you through it if you are willing to do all that work.
The only other solution would be to purchase the commercial version of that motion switch, which would also require a sensor at _each_ switch location :-(
Jan 02, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
GE Security Simon 3 Wireless Home Security System Logo
240 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
