Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Fisher and paykel iwl10 or iw810 changing motor controler
Hi, if i change the motor controler on my machine do i have to do anything special first or can i just replace it and turn it on?
  • 145 Answers
Hi, welcome to FixYa.
Typically, the "machine size" setting must be programmed into the new control when it is first powered up. Fisher Paykel includes a tech sheet with the replacement control that explains how to do this. On most machines, with the power off, you hold the water temp UP button down with one finger, then press the power button. This activates the mode for setting the machine size. You then select the machine size and lock it in when you shut the power back off. Now the machine is ready to use. On some models, the digital readout screen displays these settings and it is very easy to do. I hope this is useful info to you and thanks for using FixYa.
Posted on Jan 30, 2009
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
Code 43 for a fisher and paykel Iw810
In the back right corner is a out of balance switch which is either activated and stuck activated or is faulty. This is the most likely cause, have a look , lift the lid to check it out.
If you can handle a screwdriver - open the lid lift upwards to disengage, remove screws in top rear, lift control cover, remove fixing screw on bottom controller, find the switch fitted to the top of the base, give it a clean and reassy.. turn off the power supply first however.
May 05, 2015 | Fisher and Paykel Washing Machines
After changing the cold water valve on a GW612 do I need to do a reset
The motor controller board could have a faulty water valve mosfet.
have part replaced by tech or replace motor controller board.
Feb 21, 2014 | Fisher and Paykel Fisher & Paykel Washer
Need to do a reset on a gw612 after changing the cold valve
There is no reset for these.
If you are getting error code 48,49,50
your motor controller board is faulty.
My Fisher and Paykel IW810AU has stopped mid wash full of water and just beeps constantly and flashes message I need Service Fault 105. Have turned it on and off at the wall with no change. Please help.
Hi, the faults 105 is reported when the Display Module detects an error in the communications between the Display Module and the Motor Control Module.
The primary source of the problem is the Pump and you have to measure resistance of pump. If resistance is less than 33 ohms, replace pump.
May 16, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Hi our F&P iw810 washing machine makes a loud squeeling noise at the start of the wash cycle. What is it? (no belts or gearbox)
sounds like tub bearing or stator is cracked it also can be the clutch between the two tubs check for any hoses or wires touching the rotor its worth fixing as its a very goog model you have
Aug 28, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
When I turn the machine on it says I need service error 105
Hi just read your posting.Now error code 105 is called COMMS. ERROR TIME-OUT.This means the display module has detected an error in the communications between the display module and the motor controller.There are 3 reasons why this error code appears, the 1st is a faulty display module, the 2nd is a faulty motor controller and the 3rd is a faulty rotor sensor.The way this fault is tracked down is to 1st change the display module and if that does not rectify the fault then change the motor controller and if the fault is still present then change the rotor sensor.Sorry for the bad news on this fault and unfortunately you need the components to find the fault.I have double checked to see if there is a way to check the components easily and I have not been able to find one.Please reply on how you would like to proceed and I can help you as much as I can.
Aug 08, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
I HAVE A GWLO8 WASHER ..DRAIN MOTOR SHORTED OUT ,BLEW FUSE . PUT IN NEW DRAIN MOTOR NOW WHEN I PLUG IN THE WASHER THE DRAIN MOTOR WILL NOT STOP RUNNING UNLESS I PULL THE PLUG. ALL THE PANEL LIGHTS RESPOND...
Hi Joe.Unfortunately if your drain pump shorted out and when you replaced it with a new one, it keeps draining, then the fault now is your MOTOR CONTROLLER.It became faulty when your pump shorted out.This happens sometimes with the Fisher and Paykel washers.Hope this helps and if you need further assistance then please reply and I can help you replace the CONTROLLER if you decide to change it.Just a note before you go and purchase a new controller ring your local FISHER and PAYKEL dealer and ask them if they can test your CONTROLLER for you,Just to be sure.I know my diagnosis of your fault is correct but I think we must cover all our bases.Looking forward to your reply.
Jul 31, 2010 | Fisher and Paykel Washing Machines
I have a fisher & paykel IW810 washing machine that will not fill the bowl with water. While filling, it is also pumping the water out, in the autowater level sensing mode. I have gone into the command...
hi, reading your posting it tells me that the machine will fill on traditional wash but on auto fill mode it pumps the water out at the same time it is filling. i"m pretty sure it is your diverter . on auto fill mode it fills a little bit then the pump comes on and recirculates your water by pumping the water from the bottom of the bowl to the top of the bowl over the clothes. on auto fill mode it also activates the diverter to pump the water back to the bowl. on your machine the diverter is stuck in the drain out position so when it trys to recirculate the water it drains out the water instead . the problem could be a faulty diverter, control module or a broken wire.hope this helps, please reply if you need more help. good luck.
May 17, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Hi, I have a Fisher & Paykel Phase 5 IW709 top load washer. It has an intermittant problem (although becoming more often) that appears related to the pump . Upon power up at the wall plug there is...
i have come across this problem before ,yes the pump is apart of the switch mode power supply in motor controller,the motor controller also changes the speed of the pump by altering the hertz range ( for lint rejection) unfortunatley you will have to replace motor controller ......to solve this problem
Feb 11, 2010 | Fisher and Paykel Fisher & Paykel Washer
Washing Machines Logo
184 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
