Question about ViewSonic VX922 19" Monitor Flat Panel
17" lcd veiw sonic power blinks
If i plug this unit in . it just blinks green. If i unplug it , it blinks green 3 to four times for 1 sec at a time. the four or 5th blink is a little longer, if i catch it just right by pluging it back to the lcd on the 4th time it will stay on for good, till i shut it off. other than that you can shut it off with the power button, but it will start blinking again. Iam guessing its a leakly cap. thanks let me know what you think.
  • 624 Answers
This is a duplicate posting, click on the link below to view the active post: http://www.fixya.com/support/t161845-17_veiwsonic_power_blinking_green
Posted on Jul 28, 2007
SOURCE:
How do I fix my Sharp Aquos LC-42D62U TV?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Nov 06, 2015 | Sharp Televison & Video
My sonic 3 wheel scooter will not go status light blinks 3 times the 1 time,3 times then 1 time ect, batteries fully charged unit is in gear what is wrong
Pride Mobility Products Corp. - Product Owners Manuals ...
www.pridemobility.com > Resource Center
Pride MobilityProduct Owners Manuals & Specification Sheets ... Jazzy Elite ES PortableSpecifications ... I 02/03. Jet 3 Ultra ... Travel Scooter Throttle Control Lever OperationProduct Insert .... Brochures · Owners Manuals · Basic Operating Instructions · BasicTroubleshooting Instructions · EMI / RFI Information · Warranty Information.
Sep 25, 2015 | Pride Sonic 3 Wheel Portable Scooter
View Sonic VA720 monitor goes out after power goes
replace the logic board, not the power supply board. you can find logic board on ebay as low as $29...
Nov 15, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
MY 6310 just stopped on me. I have to unplug and plug it back in but stops again. All lights are blinking and it said to RESET POWER.
HP 6310 Reset
There are 3 types of resets in the printer
1.Partial Reset
2.Semi full Reset
3.Full Reset
To do partial Reset.
1. Unplug the power cable and turn off the the unit.
2. Press and hold # & 3 at the same time with out connecting the power cable.
3. While holding the button, connect the power cable and do not the release button for 5 sec.
4.Then turn ON the unit
To do Semi full Reset.
2. Press and hold # & 6 at the same time with out connecting the power cable.
4.Then turn ON the unit.
To do full Reset.
2. Press and hold # & 9 at the same time with out connecting the power cable.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 29, 2009 | HP Officejet 6310 All-In-One InkJet...
FAST BLINKING GREEN & WON'T POWER ON
I had exactly this problem. After plugging and unplugging it multiple times over several weeks (even plugging it in quickly after it was unplugged but with the green light still flashing as suggested here) all to no avail, it just started working on its own one day. It worked for a few weeks and then the problem re-appeared.
InFocus tech support recommended:
1. Check whether the lamp door is securely closed.
2. Check the color of the LED and the number of time it blinks. (For me, a very fast almost flickering flash)
3. Does the fan operate? (My fan would go on when plugged in)
4. Remove the lamp module, shake it gently and reseat the lamp module.
For me, these steps did not work. InFocus then recommended that I send it to ProjectorDoctor http://online.projectordoctor.com/, and it was diagnosed with a bad power supply. $395, but it is fully functional again. Good luck.........
Jul 24, 2008 | InFocus ScreenPlay 7200 Multimedia...
View sonic flat screen monitor
Problem seemed to be a short in the power cable to the monitor. Replaced the power cable and for the time, the monitor is working correctly.
Jul 07, 2008 | ViewSonic VX924 19" LCD Monitor
Monitor blink
1. this is may be due to the 5 volt power supply. which may be down. the current u can measure is ok (5volts) but the ampers may be down. because in off or stand by position it consume very little current but at the time of self test it consume more then 900 milliamps. ( replace the regulator of 5 volt)
2. May be the EHT transformer drive transistors are short. check them, if there is any leakage or if they are short then replace them.
Jan 22, 2008 | Dell E173FP 17" LCD Monitor
17" veiwsonic power blinking green
The flashing green power button is a well known electronic problem with this (and other) Viewsonic LCD monitors. There is a YouTube video (do a search) showing how to disassemble the VX924 and find out whether the problem is related to blown capacitors. When I took my VX922 apart I discovered 6 bad capacitors out of a total of 7 on the power supply circuit board.Only recommended for those handy with a soldering iron.
Jul 28, 2007 | ViewSonic VX922 19" Monitor Flat Panel
Power blinks green on lcd 17" veiwsonic
Lcd 17" veiwsonic power problem
ViewSonic VX922 19" Monitor Flat Panel Logo
187 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
