Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Water constantly runing to ice maker/ over flowing ice tray
The water over flows ice tray and drips down into ice bin frezing up agitater and flowing out ice dispenser in door. Also dripping down the inside of frezer compartment forming large ice build up.
Flow level has to be clean, or remplace.
Posted on Jan 30, 2009
Ice maker won't stop filling. Makes a little ice, but water is almost constant into the maker
The water control valve is shot. It's not making ice because there is a constant flow of water into the ice tray. Shut the water off at the feed point for the fridge for now. If the drain gets plugged you're going to have a small catastrophe on your hands.
Here's a procedure to test it to be sure:
How to Test Fridge Icemaker Water Inlet Valve Refrigerator Repair
Mar 20, 2016 | Kitchen Appliances - Others
Ice machine shuts down when bin gets half full wwhat should i do
There is an adjustment on the front of the ice maker for the amount of water that goes into the ice tray. It controls the number of seconds that the solenoid stays open and allows water to flow into tray.
Mar 02, 2015 | Kitchen Appliances - Others
Why is my Uline ice maker filling with water not ice ?
At first I wanted to say it has to fill with water to make ice but I know you mean the ice bin is filling with water. You either have an issue with the water control valve leaking or your timer isn't working properly. Listen for the water to flow and when it seems to shut off look at the tray fill spout and see if it actually stopped dripping. If it continues to drip (not flow normally) then the valve is leaking. If it isn't dripping but the water in the ice tray over flowed, then the issue is either with the timer or the adjustment is incorrect.
Jun 04, 2014 | U-Line ULN Marine Series 12-lb Crescent...
Ice maker over flows
Not sure on this brand, but on some ice makers, there is an adjustment for the length of time the water the water runs down the chute. See if the ice maker instruction sheet is in the back of the unit - it may show where and how to adjust the time. Another idea would be to partially close the water valve that goes to the ice maker unit, so less water gets into the ice maker. However, over time, this will mean the valve will leak through when the valve is turned off. Good Luck
Feb 20, 2014 | GE Monogram ZDI15C Automatic Icemaker
Kenmore ultra fresh side side 59507990
828a4e4f-c0b3-4029-a7f5-35b92db8b7ad.jpgKenmore model numbers look like this example=> 321.1234578 Are you sure that the water in the ice maker is melting and flowing down into the ice bin? What may be happening is the water control valve for the ice maker may be allowing water to continue flowing into the ice maker tray even when off due to the water control valve being defective. If your refrigerator also has a water dispenser and the water is not continuing to leak is because the water control valve has to sides. One side is for the ice maker and the other side is for the water dispenser. I am here if you have questions, Thanks Sea Breeze
May 29, 2013 | GE Refrigerators
Hoshizaki model AM50BAE not dropping ice...
Replace water float and check water inlet valve. with water constantly filling sump tray it will not make ice water will never cool down to 32 deg.
May 26, 2012 | Hoshizaki Cubelet Ice MakerDispenser Water...
Ice maker leaks water
The GE Icemaker has a center bottom plunger that drives the ice cube discharge tray up and down. If that center plunger oring has failed the ice maker will leak in a drip drip drip fashion. If it only leaks once every cube cycle then it is overflowing when filling. This can be corrected 2 ways. One is to turn of the water supply line and disconnet the water line on the back of the unit. Place the hose into a large bowl of some kiind and then have someone open the valve until the flow is full and then reduce that flow about 50 percent. Remember how many turns it took to get that flow and shut off the water supply line. Then reconnect the line and turn on the water the number of turns you counted when shutting off the water. The PROPER way of setting the water flow timing is to frome the front cover of the ice maker and turn the adjustment screw in the DECREASE direction. My suspicions are that the plunger o-ring is leaking. It costs nearly as much to have the service call to replace the o-ring as it does to replace the ice maker. Your choice but I would replace the icemaker if the plunger is leaking. (mid-bottom point of ice maker) Just note that once a leak occurs in the plunger area if the plunger has corroded the new o-ring will wear out rapidly.
Jan 03, 2010 | GE Profile Stainless Bottom-Freezer...
Ice Maker Overfills With Water
Ice maker has adjustment on right side of power head. If ice maker is inside on upper left, you can remove white cover from it and the adjusting screw in on right. Turning counter-clockwise will decrease fill by 1/2 to 3/4 of ounce. Sounds like a small amount, but ice make only uses 4 ounces per fill. If this does not fix, try replacing fill valve. If ice maker ice bin is in the freezer door, you have to remove cover to ice maker in the top of freezer. Ice maker is screwed into top of freezer and need to be removed to take off cover to adjuster screw. same procedure for reducing water flow time as above.
Jul 23, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice maker is overflowing, I replaced the valve and the water is still overflowing the tray
This is usually a problem with the icemaker. The only fix is to replace it.
May 21, 2009 | Refrigerators
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
357 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
