Question about Whirlpool WTW6400SW Cabrio Washer
F51 on a Cabrio WTW6400
The machien stops, water fills in and proceeds and then beep beep and F51
  • Anonymous Feb 27, 2009
    I have the same problem. I have only had this washer for 11 months and now when I start a load...the cycle starts and the its like its stuck and then beep beep beep....F51.
5 Suggested Answers
  • 23 Answers
SOURCE: Type 111 filled with water and stopped
with the machine off, turn the cycle dial around 3x very harshly, then try it again. If it works normally now, you'll need a new cycle switch soon!
Posted on Apr 01, 2009
SOURCE: Cabrio top load flashing F51
F51 error is a rotor position sensor error.Its a very common error in carbrio washers.heres a website just for this error.Refer for the solution through it.
http://cabriof51error.blogspot.com/2008/01/my-f51-experience-day-7.html
Posted on Dec 15, 2008
  • 39 Answers
SOURCE: Whirlpool Cabrio W10106470 has an F51 code. What
F51 error is a rotor position sensor error, two parts really need to be replaced. 1) the rotor sensor itself ($43) and 2) the control board ($197)
Posted on Jun 23, 2009
  • 26 Answers
SOURCE: Whirlpool Cabrio F51 code flashes and stops the cycle.
Posted on Sep 27, 2009
richroth
  • 9472 Answers
SOURCE: Whirlpool cabrio WTW6700TW1 only fills little bit,
The F51 error is a RPS (rotary position sensor) board failure where the control board looses contact with the RPS during the machines operation. The RPS uses hall effect sensors to determine the speed and direction of the drive motor, allowing the control board to constantly monitor the motors operation. Because this error is a communication error and not a mechanical error with the motor itself (that would be and F52 error) we can limit our trouble shooting to the three items that make up the RPS circuit, the control board, the wiring harness, and the RPS itself.
Posted on Jan 16, 2011
Testimonial: "Thanks. Quick and helpful. Need to call for service!"
Whirlpool cabrio washing machine doesn't spin
Try to turn the drum by hand, if it hard to turn, there may be something stuck underneath spin basket. If it does turn freely but makes a loud growling sound, you probably have a bad bearing. You should notice black oil and water mixture at bottom of washer, on the rotor. It will usually throw a f51 error code. This unit has service bulletin on this problem.
Apr 05, 2014 | Whirlpool WTW6400SW Cabrio Washer
What does F 51 mean?
The F51 fault code on your Cabrio washer indicates that the control board is not sensing the proper drive motor spin. To clear the fault code, press the Pause/Cancel button.
Make sure that the drain hose is not stuck way down the stand pipe. This can cause siphoning of fill water which will inhibit proper motor rotation.
Check to see if the wash basket spins freely. If it does not, you may have an item of clothing stuck between the outer tub and the inner basket. This restriction in rotation will also cause an F51 fault code.
If these tips do not help you resolve the F51 problem, then you probably have a component failure. Possible failures include: wire harness or wire connection problem between the machine control and the RPS sensor (Rotor Position Sensor), a failed RPS sensor, a failed drive motor, and a failed machine control board.
Mar 08, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Sd 51
In addition to the above tips, check the installation of the drain line. Make sure that the drain hose is not stuck way down the stand pipe. This can cause siphoning of fill water which will inhibit proper motor rotation.
If these tips do not help you resolve the F51 problem, then you probably have a component failure. Possible failures include: wire harness or wire connection problem between the machine control and the RPS sensor (Rotor Position Sensor), a failed RPS sensor, a failed drive motor, and a failed machine control board. You will probably need a technician to diagnose and repair one of these component failures in your washer.
Aug 02, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Code F 51
Jul 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
FL error code generally means 'flood condition' which is telling you the machine is overfilling with water with water.
Try pressing STOP/CANCEL to clear the display.
If the condition persists the water fill valve or sensor may be faulty and may need replacement.
May 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Stopped
This is a typical Anti Flood system activation. This system activates when water leaks onto the floor of the machiene due to a leak fault (pipe/hose clamp/ partly blocked pipe). The machiene automatically switches to pump out mode and stops water inlet. The anti flood system is a polystireen float / micro switch at the base of the machiene floor. Dry the floor and drectify the leak and it should work.
Jan 24, 2010 | Baumatic 23 in. BDW13 Built-in Dishwasher
Machine started filling with water - then stopped and flashed F
I have the f51 code filled up with water and stopped. They are coming today to fix it. Called whirlpool and they are fixing this at their expense. I have the extended warrenty they said they are fixing codes f1 and f51
Oct 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool WTW6400SW Cabrio Washer Logo
138 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
