Question about Dewalt 3800 PSI Pressure Washer
I have a dewalt 3750 pressure washer, when I pull the trigger on the spray wand the engine dies
  • tbenzman Mar 22, 2009
    how does the solution come out how do i hook it up
  • John Lowery May 11, 2013
    Good advice to give the machine a break and run it at 75%
  • Dewalt Master
  • 1,388 Answers
I worked at a tool rental center while attending college and learned many tips and tricks about Dewalt and other brand pressure sprayers. Your machine probably has a 13 hp honda and has max pressure of about 3500 to 3700 psi. Most of the problems that customers had were engine related due to severe working conditions including totally wet engine /plug, wet air filter, and or other problems that were easy to remedy. We would set the pressure regulator to minimum pressure and explained to the customer how to increase the pressure as necessary but only after the engine was completely warmed-up to running temp to prevent engine stall. Your machine has a throttle lever between the tank and carb that should be set to max if you are going to set pressure at or neer max range. Most cleaning jobs do not need much pressure. Use lowest pressure to get the job done. Your engine developes around 13hp at about 3600rpm. If you want to maximize the life of you sprayer, then use your machine at about 70% of capacity or about 2000 to 2500 range that will allow you to run your engine slower increasing lifespan. Your sprayer is likely rated at 4 gallons per minute so make sure that the tip is that capacity. The tip has the size stamped which would show the fan degree and flow in gpm. The wrong tip, say a 3.5 gpm will strain the engine to point of stop because the smaller tip increases pressure. Most engine stall is due to high pressure setting on new machines. Lower pressure when warming-up machine and use max pressure rarely when necessary to max life. Please email for other information/questions or simple tests to determine faulty parts, good luck.
Posted on Jan 30, 2009
    New Friend:
That didnt answer the ? at all go back to school.
Posted on Jul 01, 2015
Engine is running faster than normal & causing spray to come the wand without pulling trigger?
Trigger for wand needs replacing, water bypassing it and not allowing pressure build up enough to close pressure switch, allowing engine to go back in idle
Sep 16, 2015 | Garden
Engine runs fine. But it quits when I pull the trigger on the wand to start washing
Does this behavior change if the engine is warm and on minimum choke? Do you get any water spray before the engine quits? Carburetor could be dirty or float stuck. Try putting dose of carburetor cleaner through engine and cycle choke lever and engine speed lever back and forth while engine is running after it has warmed up without running water spray. See owners manual.
Apr 03, 2015 | Craftsman 2700 PSI,2.3 GPM Briggs &...
Pressure washer starts fine and sprays fine but will not continue to idle after nozzle trigger is let go. Have to have trigger pulled to start & cannot let go without unit stopping.
The pressure unloader us usually the first part/s that fail. An unloader can fail resulting in no or very low pressure or good pressure, however will not unload when trigger is released and stall the motor. Look at breakdown for your pump and determine if unloader parts are available and reasonable. If too costly to replace these parts then install an ez start valve to help start engine and tie back wand handle to deal with unloader problem (workaround). Ez start valve can be seen here:
When not in use, store washer with oil in pump to displace the water. The oil will help lube internal parts and possibly cause the unloader to begin working (if stuck due to debris/rust). You can find a gizmo to help you feed oil into pump on ebay /other web locations. Good luck with your repair.
Apr 27, 2011 | Dewalt DPD3100 Gas Pressure Washer
New Troy-Bilt 3000 psi - Very Hard to Hot Start
When you run the unit and shut if off, release the pressure from the spray wand before trying to restart the engine. This built up pressure will cause it to be very hard to start as you have found out. If it does not start on the second pull release the pressure again. Another option is do do what I did on mine. I simply put a pull tie on the handle so I can pull the trigger back and use the pull tie to hold the trigger open. Make sure if you do this, that you remove the high pressure orifice from the end of the wand before attempting to start the engine. Otherwise the pressure will come on abruptly and could injure you or do property damage.
Apr 25, 2010 | Briggs & Stratton Prosumer 20324 Gas...
Cannot get it to uptake the bleach for spraying Dewalt pressure washer 3100 psi
On most pressure washers you wont be able to draw soap/bleach into pump unless you are spraying on low pressure.There is a valve on the inside of inlet hose fitting that closes when high back pressure is sensed.Would it draw bleach into hose when wand tip is removed?
Nov 21, 2009 | Dewalt Garden
Gas engine will not start without pulling trigger on wand to relieve pressure-engine dies when letting off trigger
I am afraid that is how they work even electric ones wont start unless you squeeze the trigger ,once they are running you should be ablr to release the trigger , and then squeeze it again whilst running . if yours dies when you release the trgger while motor is running -----good chance you are working at too high pressure. but to start you have to release all the internal pressure
Aug 22, 2009 | Campbell Hausfeld 2000 Psi Gas Pressure...
Ex-Cell VR2500 Builds Pressure but Won't Spray
I have a similar problem and diagnosed it to be a problem with the gun. I spoke to a technician that services this pressure washer and he walked me through all the diagnostic steps. The pump is working because there is pressure being built up and the gun sort of works because you can get water out before the washer is started. The technician said that the mechanism inside the gun is either clogged or broken. I am going to Home Depot or Lowes to purchase a new gun and will try it tonight. Guns are only about $30-40. He said generic is fine as long as the thread matches and PSI is in range. Good luck!
Aug 09, 2009 | Karcher 2500 PSI Pressure Washer
Pressure washer stalls out when wand nozzle is released
common for not starting unless trigger engaged as you are turning the pump as well as engine creating pressure,as for stalling pump has unloader valve which is probably in need of grease(use good silicone grease)this allows water to ciculate when trigger released.
Apr 19, 2009 | Campbell Hausfeld Garden
Dewalt 3800 PSI Pressure Washer Logo
1,222 people viewed this question
Top Dewalt Garden Experts
John Trevino
Are you a Dewalt Garden Expert? Answer questions, earn points and help others
