Question about Epson Stylus C88 InkJet Photo Printer
Can't delete print job for an Epson C** printer
If I go to control panel & printers/fax I can not delete a job.
I read a blog that indicated this problem, which said that there was a file under windows that had to be deleted but it didn't say how to get rid of it. Any ideas
  • 537 Answers
I don't know which OS you have. I will assume it is a newer OS like WinXP. You have tried to reboot the PC I'd imagine. Try stopping the print spooler by running the following command from the cmd prompt.
net stop spooler
Then check the print queue and see if you can manually delete the print job. Then issue the command
net start spooler
Posted on Jan 30, 2009
HO C4200 DOCUMENT STUCK IN QUE CAN'T DELETE
First You Need to Open the Print Queue, follow the below steps on how to open a Print queue
  • Windows 98 - click Start, Settings, Printers
  • Windows XP - click Start, Printers and Faxes
    or click Start, Control Panel, Printers and Faxes
  • Windows Vista - Start, Control Panel, Hardware and Sound, Printers
Double click on the appropriate printer to open up the Print queue,Check whether you have any pending or the queued jobs, try to cancel the jobs by following the below steps.
To cancel one or more print jobs, follow these steps.
1. Click Start, and then click Run.
2. In the Open box, type control printers, and then click OK.
3. Right-click the icon for your printer, and then click Open.
• To cancel individual print jobs, right-click the print job that you want to cancel, and then click Cancel.
• To cancel all print jobs, click Cancel All Documents on the Printer menu.
If you are using an HP printer and a windows vista operating system then you are lucky to automaticlly fix the issue with the HP Print Diagnostic UtilityClick Here For How to cancel printing or to delete a print job that is stuck in the print queue in Windows XP.
Alternatively You can check the below steps.
Delete Pending Jobs
How To Restart Spooler restart In Windows Vista
Click the Start button.
Click Control Panel.
Click System and Maintenance.
NOTE: This step is not required when using Classic view in Windows Vista.
Click Administrative Tools.
Double-click Services.
On the User Account Control window, click Continue.
Click Print Spooler.
Click Stop to stop the Print Spooler.
Click Start to restart the Print Spooler. Then click Restart
Click OK
Hope this helps!
Thanks!! - See more at: http://hpanswers.blogspot.com/2008/10/cancel-and-delete-stuck-print-jobs-in.html#sthash.QD3KNI9q.dpuf
Jul 01, 2014 | HP LaserJet 4200 Printer
I was printing a job and had reworked the document and wanted to print it again, but, all of a sudden, the printer does not print or copy anything. All the cables are securely fastened. I have plenty of...
unfortunately, you have to delete the print queue, then delete the printer (including copies of it if there's any). unplug / reconnect usb cable
Apr 04, 2008 | SATO M-8450 Printer
Can't print a cd on epson stylus 1400. The printing queue says paused.
right click on the print job in the queue, and click "restart". Other wise try this:
If you've ever had a print job hang, you're probably familiar with the Windows Print Spooler window. You get to this window simply by selecting the relevant printer from the Control Panel's Printers and Faxes applet (simply Printers in Vista). In the somewhat unusual event of a printer queue jam, you can go to the Print Spooler and simply delete the job. Sometimes, though, the system won't let you cut off print jobs that way: It marks the job "Deleting..." but never quite gets there, and you end up rebooting. But there's an easier way.
Open a command prompt (go to Start ' Run, then type cmd) and enter the following:
net stop spooler
del c:\windows\system32\spool\printers\*.shd
del c:\windows\system32\spool\printers\*.spl
net start spooler
In Vista you'll need to open an elevated command prompt by right-clicking on cmd.exe and selecting Run as Administrator. For those of you who remember batch files, use Notepad to save the four commands above as a batch file. I've named mine Killqueue.bat.
Dec 14, 2010 | Epson Stylus 1400 InkJet Photo Printer
Epson nx 215 won't print
Hello.
If there are no jobs in the print queue, be certain that your USB cable is snug.
If still a problem and there are jobs in the print queue, go to Printers and Faxes and delete your printer icon.
Note: Here's how to delete a printer icon in Windows 7:
1. Open Printers by clicking the Start button, clicking Control Panel, clicking Hardware and Sound, and then clicking Printers.
2. Right-click the printer that you want to remove, and then click Delete.
If you can't delete the printer, right-click it again, click Run as administrator, and then click Delete. Administrator permission required If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Disconnect the USB cable.
Restart your computer.
Reconnect the USB to your computer.
Your computer should see your printer. Install the printer driver.
If still a problem, either your USB port on your PC, or the USB printer cable is probably faulty.
Hope this helps.
Aug 01, 2010 | Epson NX215 All-In-One InkJet Printer
I am trying to delete a document from my hp 6180, ...
From the PC Magazine blog:
WINDOWS
Clear a Print Job Without Rebooting
If you've ever had a print job hang, you're probably familiar with the Windows Print Spooler window. You get to this window simply by selecting the relevant printer from the Control Panel's Printers and Faxes applet (simply Printers in Vista). In the somewhat unusual event of a printer queue jam, you can go to the Print Spooler and simply delete the job. Sometimes, though, the system won't let you cut off print jobs that way: It marks the job "Deleting…" but never quite gets there, and you end up rebooting. Here's a better way to do it.
Open a command prompt (go to Start | Run, then type cmd) and enter the following:
net stop spooler
net start spooler
In Vista you'll need to open an elevated command prompt by right-clicking on cmd.exe and selecting Run as Administrator. For those of you who remember batch files, use Notepad to save the four commands above as a batch file. I've named mine Killqueue.bat.—Craig Ellison
May 21, 2010 | Office Equipment & Supplies
How do I cancel unwanted print jobs.
on the printer driver has a spooler area. to enter this area go control panel, printers and faxes, enter your printer, then select the print jobs and on top has a menu document, and choose cancel . the 1st print job is printing, so takes longer time to cancel.
Dec 28, 2009 | Epson Stylus Photo 1400 Printer
Communication error
Click on start-control panel-printers and faxes. Do you have more than one copy of the printer installed? If so, my advice is to uninstall them all and then do a new installation. But FIRST, make sure there are no jobs left in the print queue. Double-click each printer icon in turn and delete/cancel any print jobs listed. Then delete each "copy" of the printer and finally uninstall the printer using the Control Panel-Add/remove Programs-Epson Printer Software. After you have done all this, turn OFF the printer, reboot the computer and then re-install the printer. Make sure you keep the printer turned off until the installation program asks you to turn it on.
If none of this helps or is appropriate, or you want further information, please report back.
Feb 06, 2009 | Epson Stylus C46 InkJet Printer
HP Laserjet 1018 won't delete a printing job
to delete the print job.
shut off the printer, disconnect the printer cable to the computer.
go to strat>>printer and faxes.
open the pirnter queue. stop the print job then delete. you may have to restrat the computer.
once the job is deleted, connect the printer cable back to the computer and turn on the printer.
Jan 09, 2009 | HP LaserJet 1018 Printer
No printing on epson c62 inkjet
Hi songerjohn
Turn off the printer. Click on start-control panel-printers and faxes. Double-click the printer icon and delete/cancel all print jobs listed. Then reboot the computer and turn on the printer. It should now print normally.
If it doesn't you will need to uninstall the printer using the Control Panel-Add/remove Programs-Epson Printer Software. After you have done all this, turn OFF the printer, reboot the computer and then re-install the printer. Make sure you keep the printer turned off until the installation program asks you to turn it on.
If none of this helps, or you want further information, please report back. If this solution has been helpful, please rate it.
Nov 20, 2008 | Epson Stylus C62 InkJet Printer
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
To cancel a print job in Windows you can use one of the following two methods:
CANCELLING A PRINT JOB WITH THE PROGRESS METER:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
CANCELLING A PRINT JOB FROM THE PRINTERS WINDOW:
If no PROGRESS METER appears, you can access the document queue in this fashion:
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS (START, CONTROL PANEL, PRINTERS and FAXES in Windows XP).
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Jul 16, 2008 | Epson Printer
Epson Stylus C88 InkJet Photo Printer Logo
418 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
