Question about Dometic RM2652 Refrigerator
RM 2611 2-way ref. will not run on propane
I can light the burner but it goes out in a few minutes. This is repetative. I can always light it but the burner always goes out after a few minutes. Runs fine on AC. I don't know if any attempts have been made by the prior owner to correct this. None have been made by me.
  • RV REFER LLC May 11, 2010
    When it lights does it have a good hot blue flame that you can hear or is it a weak orangish flame. Also what year is it from. also take an air compressor or canned air and blow directly into where the flame comes out, may be just some rust or spiderweb in there.
  • 93 Answers
Replace the thermocouple cost is 12 dollars this is what holds the pilot lit thanks from gilles
Posted on Mar 15, 2009
How do i fix the side burner that won't light
If you have had this burner through the winter then check the inside pipe that goes to the burner. Most always spiders nest inside the pipes where the propane goes through. Just push a coat hanger or wire through the pipe to clear it out.
May 27, 2014 | Dyna-Glo Bronze 60,000 BTU 4 Burner LP Gas...
RM 2611
the relay for the ac powered heater is stuck closed. it should cycle on and off , and not be on at all with the unit off.
Apr 17, 2014 | Dometic Refrigerators
RM 2611
maybe bad 120 volt side of board that is bypassing thermistor
I HAVE A FULL TANK OF PROPANE, IS NOT GOING THRU THE LINES. WHAT SHALL I DO?
The best thing you can do it the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!! Thanks for choosing FixYa.
Sep 22, 2011 | Brinkmann 810-8410-S Stainless Steel...
Our rheem gas pack running on propane will turn not always ignite
have you cleaned the flame sensor located on the
far left side of the burners?. Watch it go through the
cycles.
Igniter glows, gas valve turns on and gas ignites. If it gets that far and shuts down, it sounds like a dirty
flame sensor,clean it with sand paper.
Jan 10, 2010 | Heating & Cooling
Burner on Charmglow patio heater will not stay on.
believe it or not, the propane tank may be too full. The vapor space is taken up and you have very little vapor. Run some warm water over the tank. The garden hose may be enough but if you get no frost line the water will need to be warmer. The warm water causes the liquid fuel to turn into vapor. Do not use boiling hot water. Another thing is oening the valve. Most propane tanks have safety valves. If the gas escapes faster than a normal rate, the valve closes. Open the valve slowlyand lt it burn for about 10 minutes before opening the valve further. It will get better as the fuel is used up and the vapor space in the tank increases. In real cold climates a heater blanket, sleeve is used tho keep the bottle warm. The vapor also creates the the needed pressure to move the gas through the system to the burners. Good Luck-Ned_
Sep 15, 2009 | Williams 2509612 Ceramic Mid-Size Heater
My check light keeps coming on my dometic ref in my 5th wheel
I have had this problem also. My experience has been that the propane line to the frig has air in it, especially after not being used for a while. Here's what I do:
1) Make sure the propane tank valve is open.
2) Light one of the burners on the stove. This may take a while but keep the gas on and a lighter at the burner. This is safe becuase as the air purges from the line it just blows the flame (from the ligher) around. Then when the air is purged the gas lights. Let the burner run for a couple of minutes. This sounds a bit odd, but what you are doing is bringing the "gas" close to the frig. The frig does not have to purge all that air as you have already done most of the purging by getting the burner to light. The facory setting for the frig is to stop trying to light after 45 seconds, and the "Check" light comes on.
3) Now try the frig. It may a couple times, but it should light and work fine.
I have found that this technique also helps with lighting the hot water.
Apr 05, 2009 | Refrigerators
Dometic rm2620
After running out of propane light the other appliances first to get the majority of air out of the system, such as your stove top burners. Then push and hold the manual button for a few minutes to purge air out then try to light the pilot.
Jul 30, 2008 | Dometic RM2620 Refrigerator
Rm 2611 will not run on gas when going down the road
Your voltage supply is being interrupted. The DC voltage needs to be at least 10.5 to work properly. If you are switching from shore to gen this can cause the interuption also. I presume the gas supply is staying on when you are traveling.
Jul 28, 2008 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
317 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
