Question about Kenmore 659 Electric Dryer
90 series will not stay running or heat
You have to keep the start button pushed in i  order to run the dryer but it will not heat and the timer will not run just happend it was running fine any clues.
  • jwoodring7 Jan 30, 2009
    my model is 68944890   68944
  • Anonymous Feb 25, 2009
    The push start buttom doesn't work. I need to keep it holding or tape it. Need help
  • 107 Answers
DO NOT KEEP THE BUTTON PUSHED IN AND RUN IT...It's the motor relay and the even heat board in the console. By keeping the button in, you're bypasssing a safety feature and could cause fire. It won't heat like that anyway. Repl. the relay witht the small blue wires and the board in the console and you should be fine.
Posted on Mar 25, 2009
My series 90 will only Run if i holding the Starter but ton
I would start by checking the centrifugal switch on the motor.
When you push the start button, the motor starts turning, then the centrifugal switch on the motor clicks in and keeps the motor running until the timer or the door switch cuts power to it. If the centrifugal switch isn't working, the motor won't stay running.
Good luck
Oct 27, 2014 | Kenmore Dryers
Roper dryer repair manual
90% it's the timer
Jan 30, 2014 | Dryers
I have a kenmore 90 series dryer- It is not working - when I push the start button there is a humming noise and the dryer does not start. However if I push the start button and rotate the drum manually the...
You have a "Dead Spot" in your Motor...When you rotate the drum you move it from the dead spot and it continues to run as normal.
If you want to solve that problem then you will need to replace the motor...otherwise just live with it.
Free Answer...Please rate me
Apr 15, 2011 | Kenmore Dryers
Dryer doesn't always start, and doesn't keep running
your have a dieing dryer motor,weak weak to turn the drum anymore,the model number is inside the dryer door if you want to try and find one cheap on ebay-mike
Feb 23, 2010 | Kenmore Dryers
Have a 90 series kenmore dryer, won't always run. replaced the motor about 6 months ago, and now it will sometimes run, sometimes not. It gets hot, and will run for a bit then shut down, then start up...
If the timer is not advancing but is ticking that could be the problem. A dryer achieves a set temperature and stays there for a certain amount of time during a cycle. If the time never changes it may just keep heating up until the heat sensor shuts it down. If it is starting and shutting down its likely still related to the heat sensor.
Dec 07, 2009 | Dryers
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Kenmore Dryer 90 Series will start but suddenly stop...
Hello , Sounds like your motor is over heating , it will run until the sensor shuts it down from getting to hot , it is most likley because the motor is covered in lint and needs cleaned. Hope that helps.
Dec 30, 2008 | Dryers
Whirlpool dryer will not stay on, no heat, and timer acts weird
sounds like the motor or the even heat board is out i would say the even heat board is more likely
Dec 09, 2008 | Kenmore 62602 Electric Dryer
Kenmore 659 Electric Dryer Logo
120 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
