Question about Garden
Surging tecumseh engine on snow blower
I have a John Deere snower blower (826) tecumseh engine was doing fine but started surging up and down is this the gov. needing to be adjusted or carb.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
That is not the whole fix,you need to find the brass needle valve incarnation body(whichhas a cap on it),remove and cleaned with small wire.put back in and you should be good to go. This controls the air mix and is non adjustable.
Posted on Feb 05, 2015
Hi, You have gum or old gas in the main jet on the carb, turn your fuel off, stand the snowblower on the front blower housing with handles in the air, remove main jet from the bottom of the carb and clean. Jim
Posted on Feb 01, 2009
I have a 826 john deere snow blower , when auger is engage it well turn but well kill the motor
This happened to me and it only needed a few adjustments. Maybe it will help if you watch an informative video on YouTube made by DonyBoy: https://www.youtube.com/watch?v=bbAq7m0d2qM
Apr 18, 2015 | John Deere Garden
Why is my v8 surging while under load
govenor not set correctly. weak fuel pump diaphram.
Jul 06, 2014 | Tecumseh Snowblower Snow Blower Starter...
What colour wires go to the coil on a 726 snowblower
OK the wire on a coil is to shut off motor when grounded, so if you don't hook it up it will not shut off when you try. That wire goes to throttle linkage so when you slow engine speed to minimum it shuts engine off. Most snow blowers that have the red safety key in shield have that same wire slit from the throttle so if that malfunctions you still have a safety shut down.
May 22, 2014 | John Deere Tecumseh Snowblower Heater 726...
1993 Chevy truck surging then dying
i take it you mean the revs keep going up and down
this effect is called hunting
this means you have to much air getting through to your engine
solution: tighten down your carburetor
you may have to replace the inlet manifold gasket seal
then adjust the throttle as required
Mar 14, 2014 | Tecumseh Snowblower Snow Blower Starter...
Engine surging
you could have leaking head gasket
Jan 02, 2014 | Tecumseh Snowblower Snow Blower Starter...
John Deere 430, Sundstrand series 15-U hydrostatic transmission. The tractor, at low ground speed, surges as it moves, in both forward and reverse, at any engine speed. At full ground speed, the surging...
you sure your engine isn't surging... you would see it at lower speeds... my motorcycle surges at a certain rpm due to fuel ratio's at the one speed ( running lean )... so what i am saying is, could it be that the engine surge only shows itself at a certain ground speed.
or is it because of a hydro system pressure relief valve ???
Oct 08, 2013 | Garden
John deere 826 will not go forward or reverse
Can anyone help me with a john deer 826 snow blower that won't engage in forward motion?
Mar 04, 2013 | John Deere Mowers Tillers Snow Blowers...
John Deere GX85 Riding Mower engine surges
did you drain the gas before putting it away last season? If not, I would drain all of the gas and put in fresh gas, also replace any in line gas filters
Apr 06, 2010 | Garden
Garden Logo
2,121 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
