Question about Panasonic KX-TA824PK Phone
Kxta824 disa help
We currently have the auto attendant ( disa) answer and route the incoming calls. Can I program a station (operator/receptionist) to turn off or delay pickup so I can have a live person answer if available? then re enable easily when she leaves her desk?
Thanks in advance
  • Panasonic Master
  • 2,460 Answers
Your system has 3 modes of operation, day, night, and lunch. Lunch doesn't have to be a specific time, and you could manually switch between the 3 modes. Most small customers don't even use NIGHT mode, except to control the voice mail system.
Full programming instructions are beyond the scope of the free forum, but in section 3.1 of the programming tool, you set the mode of the trunks for day/night/lunch. No matter what the status of the auto switching to day/night mode, you can still manually switch to lunch by dialing 782 from any phone, and manually switch back to day/night mode (780/781) to turn DISA mode on or off.
Now, you still can have different OGM's for day and night that will automatically work, and manually use the lunch to control the applicaion of DISA. Even if the receptionist steps away from the desk, you can go into 3.2 and turn on some delayed ringing, or anyone can put the system back in day or night mode.
Carl
Posted on Apr 23, 2009
NEC Dterm80 phone, Model DTH-16D-2. We have an Extension that rings as a back-up to the main attendent/receptionist in the event she cannot answer an incoming call. I need to disable the incoming ring at...
Hi if you just want to silence the actual unit, most often you will find a small switch on the unit, that switches OFF the ringer, or often one can turn it down, via a control on the unit. Other times one can set it Off or down in volume via the settings, use the manual in these case to ascertain what to do.
www.southwesterntel.com/.../ITH-IP%20Installation%20Manual.pdf -
Above is a manual so you can check exactly what and how to do what you want.
If this cannot be done, then take the phones case OFF, locate the "Ringer" and disconnect it from the board, problem solved.
Apr 19, 2011 | NEC Dterm DTP 16D-1 Corded Phone
I have a Nortel T7316E phone at work. We have extensions but don't have direct dial; only a receptionist that can place calls into our voicemail. My question is, how can I check my voicemail remotely after...
Depends on the voicemail, but generally:
Call the receptionist
When the auto attendant answers, press * (or sometimes "**"), OR ask the operator to transfer to your line and press "*" during your message.
It will ask you your login information.
Dial your extension and password together as one number and press #
You can now operate the voice mail.
Mar 16, 2011 | NorStar T7316E Phone
We have Panasonic TES 824. We connected 3-direct lines, one of them is for fax. However if I call the fax number, it goes to auto attendant. How to disconnect the fax number from auto attendant? Awaiting...
By programming. If the Auto Attendant is the DISA card, you can tell it to listen for the FAX tone and transfer it to the fax extension, or, you can program the 3rd number to ring only the fax extension and no others. Both require programming in the system cabinet.
Carl
Jan 18, 2011 | Panasonic KX-TA824PK Phone
We have a Landmark/Southwestern Bell Telecom DKS 308/616 system and need to know how to access and change the auto attendant greeting.
Call your own number or press and hold #1 button and when the message starts playing press either # or * and follow the directions. It's usually #
Apr 16, 2010 | Cell Phones
How do I set phone to ring at my extention?
Partner, all releases.
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist’s extension to Immediate Ring and the lines at the users’ extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users’ extensions -with the receptionist providing backup -set the line at the users’ extensions to Immediate Ring. Then set the line (or lines) at the receptionist’s extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist’s extension.
Programming
To change the way outside lines or pools ring at an extension:
  1. Press [ Feature ] [ 0 ] [ 0 ] [ System Program ] [ System Program ] [ Central Tel Program ].
  2. Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons on the phone show the current Line Ringing settings for all lines assigned to the extension. (If a line is not assigned to a button, the green light next to the button is off.) The following ringing options can be shown by the green light next to the line button.
    • Immediate Ring - on steady
    • Delayed Ring - flashes slowly
    • No Ring - flutters quickly
  3. To change Line Ringing for any line, press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
  4. Continue programming or exit programming mode.
Dec 01, 2009 | AT&T Lucent MLS-12D Phone
Help answering calls during peak call times
Yes you need the PC ASA card and not ASX,
Example: to speak to a live person dial 72 and the zero time out option sends it back to reception and it will place it on hold,
reception would need to activate a programmable button ASA button when experiencing high volume calls,
If nobody picks up it will revert to the reception or zero time out attendant with another greeting depending on what type of avaya voice mail you have?
If you have R5 vs mail or Partner mail and not a PC mail some tricks can be done.
This may not solve your answer and ring delay on day or night mode needs to be looked at.
The reality is you can delay the callers ability to get to a live person for a minute or so if they choose to hang out without a ASA card.
Send them to an unused ex port and assign the port to automated attendant two. Depending on you VM we can have up to 5 AA's and greetings.
The fact is if your receptionist can't place the call on hold with a music on hold greeting that says's Bla Bla Bla and more nice stuff and stay on the line we will be with you shortly then you need to hire a new receptionist.
Aug 08, 2009 | Avaya Lucent Partner 616 Phone
Auto attendant does not pick
What kind of phone system? If Partner, it sounds alot like you lost all your programming, so the phone system isnt programmed to know where the voicemail is. So hwen a call comes in, the ports where the voicemail is, ring, so they pick up, but dont know what they are to do with the call, so they shove it to the receptionist.
#505 needs to be programmed, then #206, that will get you to at least asnwer incoming calls.
Need to know more, like WHAT KIND OF SYSTEM.
May 27, 2009 | Avaya AT&T Partner Phone
Be able to pick up incoming calls from all front office phone sta
Get a copy of the manual here
http://www.cactcom.com/Manuals/Vodavi/Vodavi%20DHS/Vodavi%20Starplus%20DHS%20Installation%20And%20Maint%201995.PDF
Looks like you can group the stations together and then any one of them can answer incoming calls. See page 45 or so.
Jan 22, 2009 | Vodavi Starplus SP7314-08 Corded Phone
AUTO ATTENDANT NOT ANSWERING
There is about three to four programs that need to be set up in your phone system in order to do this , the program number my be a little different depending on the partner system you have .
Jan 19, 2009 | Lucent PARTNER18 Corded Phone
Stop ringing at certian phones when outside calls come in.
http://dstech1.com/programming-line-ringing/
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist's extension to Immediate Ring and the lines at the users' extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users' extensions -with the receptionist providing backup -set the line at the users' extensions to Immediate Ring. Then set the line (or lines) at the receptionist's extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist's extension.
Programming
Jan 09, 2009 | Lucent PARTNER18 Corded Phone
Panasonic KX-TA824PK Phone Logo
888 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
