Question about Plantronics Explorer 220 Bluetooth Headset Wireless Headset
Volume control I have found that my volume on my headset is getting lower.Is there any way to fix this problem
    Problem Solver:
  • 5 Answers
Well, in one side of the device, there is a button which you can press it either in the top or at the bottom, if the device is on, press it on the top
Posted on Feb 02, 2009
  • anasophy2 Feb 02, 2009
    Oh, sorry for posting again, but if it doesn't work you can do it by raising your phone's volume. I do it either way.
We are using the Plantronics CS55 wireless headsets. The users are complaining that the '3-beep' incoming call alert tones are too loud. We have tried to adjust this tone level by manipulating...
Lowering the ring volume on the phone only decreases the sensitivity of the lifter, which generates the signal to the headset. The signal volume between the two is preset and cannot be adjusted.
Good luck from Headsets Direct!
Jul 20, 2011 | Plantronics CS55 Wireless Headset
My headset was working fine but all of a sudden the volume will not stay at the level I turn it up to. It keeps rolling back down to barely any sound coming through. I try to use the button on headset but...
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to solve your problem. Your Logitech ClearChat Pro USB Headset's volume will not stay at the level you turn it up to, and as a result it keeps rolling back down to a lower sound quality. Your volume control button doesn't solve the problem neither. Well, when a problem occurs, you should first troubleshoot where it's coming from. We will use a method called "Process of elimination". Your headset's volume has two controls: one control is on the headset itself, and the other control is located in the sound settings of the device you have your headset plugged into. With this thought in mind, lets go up to the problem explanation above. You said that the volume control attached to the headset didn't make a difference, this means the you can eliminate the hypothesis that it's the volume control causing this. The problem is coming from the earphone portion of the headset. Either a mute setting has been activated, volume is turned down real low or your headset is not the default device to receive sound input. The first part of the investigation is done; now, to get further into the investigation, you will need to connect your headset to your computer. This is where troubleshooting and solving the problem meet. Step-by-Step, I am going to explain to you how to get audio presentations into your headset. This device works with two Windows Operating Systems (Vista and XP) and one Mac Operating System (OS X). If your computer's operating system is Windows, open your Control Panel. Under the Hardware & Sound link, click Manage Audio Devices (for Vista users), and the Sound & Audio Devices link (for XP users). If your coumputer's operating system is Mac OS X, open your System Preferences and click the Sound link. In Windows Vista, click the name of your device, then click Set Default. Click the Properties button and increase the volume slider or unmute the volume if needed. If applicable, click the Apply button, then click OK. If the Apply button is void, just click OK. Click the Recording tab and perform the same procedures as you did before, only difference is that this will make your headset microphone the default recording device. In Windows XP, click the Audio tab and set the headset as the Sound Playback and Recording device. Increase the volume or unmute it if needed. When finished, click the Voice tab and perform the same procedures as you did before. In Mac OS X, click the Input tab and select the headset as the input device. If you still can barely hear anything, increase the volume slider. When finished, click the Output tab and repeat the same steps as before; only thing, you will be making this the sound output device, meaning the sound of your voice will be outputed from the microphone. Increase the volume slider if needed. You should be able to receive sound in and out of your headphones now. If we succeded, through this experience we have: troubleshooted where the problem was coming from, found a way to solve it and fixed the problem! Thank you for choosing FixYa as your one-stop solution spot for problems, questions, concerns and requests. Visit our website again the next time you need assistance with something. Thank you and have a good morning, afternoon, evening or night; whatever time of day you are viewing this solution post.
May 27, 2011 | Logitech ClearChat Pro USB Headset
I have a CS361 plantronics wireless headset and I get alot of echoing when I get calls in and out, and when I call my coworker
Reduce speaking volume by changing the speaking volume
major adjust switch setting. See page 15 in the User's Guide (link below).
• Point microphone towards your chin.
• Listening volume too high on phone. If your phone has a handset
volume control, lower this until the distortion disappears.
• If the distortion is still present, lower the listening volume adjust
button on the headset. If the distortion persists, select another
listening volume major adjust switch setting. See page 14 in User's Guide.
• Base is too close to computer or phone. See page 9 in User's Guide for
proper positioning.
For further help, this is the link for the Plantronics Wireless Headset User's Guide.
Apr 19, 2011 | Plantronics CS55 Wireless Headset
Set up the headphones and played with the volume control. Once I lowered the volume I have not been able to get it back to maximum volume
this could be a number of reasons. The device you are streaming the audio from is at a lower volume. The volume control has broken ont he headset itself and wont turn up to full volume.
first determing if the device you are streaming audio on is turned up all the way. If it is and it still wont get any louder. Try to turn the volume all the way up. if you determine it is all the way. It may be the headset. But the only way to ensure this is to actually try the headset on another device
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
Aug 19, 2010 | Motorola Mobility S9 Headphones
May volume keys on my keyboard are not responding. My speaker/headset volume is inaudible. whenever I press the volume keys on my keyboard, nothing happens. the same as when i click the volume symbol on...
They are actually two separate issues:
I will assume that you have funtioning speakers or headset.
1) first fix your main audio problem by re-installing your sound card driver that would normally come with your PC/Laptop or (external) Sound Card. This should fix the issue with your software volume control
2) second fix your Keyboard volume control: if after fixing your audio system driver previously, this is still not working, then you will need to re-install your Keyboard 'soft' key driver that control the extended function of your specific keyboard: the driver may also be included as part of your PCLaptop but may also have come with a 'third party' non-orininal keyboard.
Hope it helps & good luck!
Dec 25, 2009 | Computers & Internet
Volume control problems with motorola bluetooth stereo headset. Sometime volume switch won't respond to lower the volume and at other times, the headset beeps and then volume decreases on its own.
may the problems also lies with the connection between handset and stereo. may it has lost its service. try getting another one. good luck!
Oct 14, 2009 | Radio Communications
I am getting feedback with Plantronics CS70 Wireless Headset
Echo is usually caused by the transmit (speak) level on the unit being set too high.
1. First, try lowering the volume of the telephone. If you still hear an echo, adjust the volume of the headset itself.
2. The master transmit controls of the headset are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting.
3. You can fine tune this setting with the plus (+) and minus (-) buttons on the back of the charging base.
4. If this doesn't fix the echo, try moving the configuration dial on the left side of the charging base. The recommended setting for most phones is 1.
Jun 05, 2009 | Plantronics CS70 Wireless Headset
Mic Volume Auto Sets Too Low
Delete the registry files for the devices and then uninstall the driver from device manager and then uninstall the software.
That worked for me.
If you need additional help you can contact me on Skype. Username: Skatedawg.
Feb 09, 2009 | Microsoft LifeChat™ LX-3000 Headset
Volume trouble
The top button on the control surface, the one with the green flashing LED, is the volume control. When the unit is "ON" pushing the button up or down raises or lowers the volume, simple. When you connect it to the charger that same green light will turn red while charging. If you push the top button forward (up) at the same time you press the lower button (power) the LED will flash 1-3 times. Three flashes is fully charged and one means it's getting low.
This is a great head set. I just sat on mine and broke the ear piece. I'm looking for another as we speak! It's worth more than it's current retail price by far!!!
Jan 27, 2009 | Body Glove Earglove Bluevoice Bluetooth...
Plantronics Explorer 220 Bluetooth Headset Wireless Headset Logo
142 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
