Question about Lexmark 2381 Plus Matrix Printer
Dot matrix printer. very light print on last page of form
Lexmark 2381plus printer 7 years old. I installed a new ribbon and set the forms setting all the way up. The last page of the 3 part form is very faint. I'm not sure if it is a printer problem or a form issue. Do I need a printer head, an adjustment or a new printer.
thank you for your time!!
  • mengle23 Jan 30, 2009
    Thank you for your quick response.
    I am unable to see if the ribbon is advancing. The top copy of the form is very dark and easy to read.
    Is the ribbon ink transferred through to the last copy or is the impact what makes the impression on the 2nd and third copies? The final form is actually a return envelope. I don't know if the thickness counts twice.
    This printer has been working fine for years this is problem that recently arose.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Based on your description, the printer is working, it is not a form issue, the printer head is good, an adjustment might be needed and it works, there is no reason to replace the Lexmark 2381plus printer even if it is 7 years old (not unless you would want to).
To the faint printing on the last of the 3 pages:
  • the take-up spool/wheel drawing the ribbon is not working (most likely). The ribbon is not moving hence the printer head is not striking fresh ribbon area. Check the ribbon cartridge, it may be stuck or the driving spindle where the ribbon's take-up spool/wheel locks into. It may need a bit of cleaning and/or lubrication;
  • the printer head is slightly adjusted away from the paper. Normally, there is a mechanical lever/adjustment that sets how many paper & duplicates are fed. Adjust for 1 only.
Good luck and thank you for using FixYa.
Posted on Jan 30, 2009
  • Louie  Role
    Louie Role Jan 30, 2009
    Hi again and appreciate the postback.
    Since it is the impact that actually prints, the problem maybe that it is not reaching deep enough make a clear impression on the 3rd copy. There would be no harm in adjusting the printer to a setting of 2 meaning 2 copies or even 1 (aside from the original, on top).
    Cheers.
Skips pages while printing
check the page length set on printer/ system/print server in printer & fax
Jul 26, 2013 | Lexmark Forms Printer 2590 Dot Matrix -...
We had a power failure and now our Lexmark 2391 dot matrix printer will not print from the top of the page. i need to know how to setup/reconfigure the top of the page? thank you
  1. Push the ALT button and then the PARK LOAD button to back the paper out.
  2. Push the PARK LOAD button to reload the paper. The Ready light should now be blinking.
  3. Use the MICRO up or down buttons to adjust as needed, making sure that the top of form is set on the very first page that enters the printer. Typically, the top edge of the first sheet of paper should be even with the ribbon.
  4. When the page is lined up properly, press the START/STOP button. The printer will record the current position as the top of form and then feed paper to the tear off position.
  5. Use the MICRO up and down buttons to place the top of the paper at the tear off bar.
  6. After the tear off is positioned properly, press the START/STOP button twice to save the tear off position.
  7. Test the positions with a sample print job. If the alignment is still off, follow this entire procedure from the beginning again as needed.
Aug 08, 2011 | Lexmark 2391 Plus Matrix Printer
Ms word does not print properly on tally 2250 printer
you need to create a forms for your specified paper size.
1.open printer and faxes in win xp.
2.file...server properties...create a new form(check)
3.type a name for forms
4.type a size in below boxes...(like 10 x 12 paper , width is 10 inch, height is 12 inch)
5.save it
6.close
7.rht click the printer...device setting tab... select a form name in the tray .
8.it will work
Feb 26, 2010 | Tally T2250 Matrix Printer
The print is only clear on the left side of the forms...
Platen Gap Adjustment (Figure 35)
IMPORTANT Only do this procedure if the original equipment shuttle frame assembly or platen has been replaced by a new or
refurbished unit.
1. Prepare the printer for maintenance (page 338).
2. Remove the shuttle cover assembly (page 357).
3. Loosen the platen open belt (page 415, steps 2, 3, and 4).
4. Raise the forms thickness lever (1) to the fully open position.
5. If you are adjusting any model except the 6400-i20, select a 0.011 inch (0.28mm) flat feeler gauge.
If you are adjusting a 6400-i20, select a 0.012 inch (0.30 mm) flat feeler gauge.
ATTENTION Do not force the platen against the feeler gauge. Damage to the hammer tips will result.
6. Insert the feeler gauge (2) straight down between the hammer bank cover plate (3) and ribbon mask (4), within four
hammer positions of the left end of the hammer bank.
ATTENTION Adjust the platen set screws less than 1/4 turn on one side, then check the other side. Adjustment sensitivity is
approximately 0.03 inch per revolution of the set screw. Also, insert the feeler gauge no more than two inches down
from the top of the ribbon mask.
7. Gently close the forms thickness lever (1). As the platen is closing, gently slide the feeler gauge up and down, keeping it
between the hammer tips and ribbon mask. If the feel is too tight as the platen closes, adjust the 3/32 inch set screw (5)
counterclockwise. If the feel is too loose, adjust the set screw clockwise. With the forms thickness lever closed all the way,
the feeler gauge should contact both the tips and the ribbon mask and move with light friction. Shift the gauge slightly to
verify.
8. Repeat steps 4 through 7 at the right end of the hammer bank.
9. After adjusting both sides, check the gap again at both ends. Readjust if necessary.
Aug 25, 2009 | IBM 6400 Matrix Printer
TallyGenicom 2265+ not printing with custom paper size
There may be a number of causes for the problem you are seeing. There are a number of places which may hold the origin to the page length problem you are seeing, in order of precedence these are;
  1. The page size set in the software package printing the 6 x 4.25 cards
  2. The page size set the printer driver printing to the printer
  3. The page size set on the printer
I would recommend the follwoing;
  1. Set the form length on the printer to 6 inches (i am assuming this is the length of the card)
    The form length can be set through the menu and is normally set in lines (normaly the print size is set to 6 LPI) so the form length should be set to 33 lines
  2. Create a custom form size in SERVER PROPERTIES on the Windows XP machine to match the form size you are using.
    Ensure you select this form size in both PRINTER PROPERTIES and PRINTING PREFERENCES
  3. Try printing some Windows Test pages to see if these respect the page size selected withing the printer driver properties.
If the Windows Test Pages do not print correctly I would recommend checking how you are creating the CUSTOM SIZE form, perhaps create a new form and double check the form properties one it has been saved to confirm these are correct.
Check you are using the correct printer driver for the printer, you should be using the 2265+ printer driver. As a test you may wish to install the GENERIC TEXT printer driver or the EPSON LQ2250 driver, these will be included in the Windows Add Printers Wizard and should print OK to the 2265+.
If the Windows Test Page prints OK I think you would need to look at the software package printing to the printer. Ensure the correct page size is selected here also, perhaps try printing from another software package selecting your custom size form to see if these print correctly.
It is passable your software package is sending escape commands to the printer to call up the page size, I note you say Genicom printers printed ok from Win 98. The 2265+ may not have the same emulations as the Genicom printers.
You can print a menu print on both Genicom (if these are available) and 2265+ and compare the settings on these.
I do not believe the 2265+ has a Genicom emulation as standard, but you may be able to load an alternative version of firmware into the 2265+ which provides the Genicom emulation. If the data going to the printer contains Genicom Escape command to set form length this may resolve the issue.
You may need to contact your TallyGenicom support department for the firmware (I think it may be called 7265+ firmware)
If you are able to provide Hex Dumps of the data to the TallyGenicom support people they should be able to say what is going wrong with the form length setting.
May 07, 2009 | TallyGenicom 2265+ Matrix Printer
I have a 7 year old Lexmark 2381plus dot matrix printer. Recently, the print on the last page of the 3 part form has become very hard to read (very light). I changed the ribbon and have the form setting...
It would seem you posted twice.
Jan 30, 2009 | Lexmark 2381 Plus Matrix Printer
Printer prints too light and not threw all copies of form
If you lift the lid open do you see a lever to adjust the printer head closer to the paper?
Jun 23, 2008 | Panasonic KX-P2023 Matrix Printer
TALLY T2250 PRINTER
It sounds like there is 12 inch form length (or may be A4) selected on the computer system. The data from the system will take precidence over the 11 form length set on the printer.
If using Windows, ensure the Printing Preferences in the pritner driver are set to 11 form, Also check Printer Properties for a paper size ensure this is set to 11 inch
On the 'System' check the paper size selected within the application (if available) Check this is set to 11 inch form length
Check document margins to ensure these are not reducing the 'printable area' on the page. If availabe to a Print Preview on system to see what the document looks like.
If your application outputs raw data to the printer, check the number of lines per page assming printing at 6 lines per inch you can fit 66 lines on an 11 form. Check no more than 66 lines are per page, it sounds like 72 might be being sent befor a Form Feed in the data. (there may be a 1 line top margin set on the printer)
Finaly check the top margin setting on the printer to ensure it is set to 0 so you have the full 66 lines available on a page on the printer I think you would be looking to set the FORM ADJUST to 0 to adjust the top margin
Feb 22, 2008 | Tally T2250 Matrix Printer
Lexmark 2380 Top of Form
Can't get printer to set top of form. Can you help?
Dec 10, 2007 | Lexmark 2380 Plus Matrix Printer
Lexmark 2381 Plus Matrix Printer Logo
406 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
