Question about Jenn-Air JCD2295KE Side by Side Refrigerator
Jenn-Aire Refrigerator Shutting Down
My Jenn-Aire JCD239GES Side-by-Side Refrigerator is shutting down. The compressor was just replaced, under warranty, for the second time, in September 2008. Now, the change filter light starts blinking, the cube ice light starts blinking, the filter light goes off, and then the refrigerator shuts down. I have checked my breaker, and it is fine. It now is making a strange clanky humming noise. My warranty is good until February 2009. What is the problem now?
  • 410 Answers
Sounds as if the control board has gone bad unless you have an extended warranty that you purchased extra this will probably not be covered, but check with jenn-aire to be sure. I dont think I would worry about a 3rd compressor being bad but I would unplug the unit to prevent any further damage to it. good luck peyton
Posted on Jan 30, 2009
The fan is running but the condenser keeps shutting off and on
its not the condenser thats turning on and off thats the compressor thats cycling due to a bad ptc overload/relay on the compressor that aids in start up and running of the compressor
Dec 25, 2012 | Jenn-Air JCD2389G Side by Side...
Jenn Aire side by side, both sides warm, PTC replaced.
If you hear it trying to come on, (the lights may even dim more than normal) followed by a "tink" noise, it's the compressor.
Jan 11, 2008 | Refrigerators
The compressor makes a big clunk clunk sound when it shuts off
The compressor motor mount is broken and that allows the compressor to flop around and clunk when shutting down.
That also allows it to twist and turn as it starts...
this will have to be fixed before the refrigerant piping breaks...
heatman101
Oct 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Jenn-Aire side-by-side refrigerator Model #JCB2280HES, Serial #10024253EP. The warranty expired in February 2010. The food in the bottom half of both the freezer and refrigerator is frozen and...
Hi!!
Check to see if the evaporator fan behind the freezer wall (remove wall) is running. If it isnt the air will not flow properly in the unit. Replace the fan motor and it will fix it.
Good Luck!!
Jul 29, 2010 | Jenn-Air JCB2280HES Side by Side...
Jenn Aire frig is 6 years old and compressor is bad. Should I replace it or buy a new one?
check the warranty on the unit, if no warranties are valid anymore i would proabaly replace the unit... most compressor repairs can range from 300-800 dollars after parts and labor so its kind of whuts a cost effective way to go ...
Jan 31, 2010 | Jenn-Air JFC2089H Bottom Freezer French...
Jenn Aire refrigerator keeps freezing food.
Your thermostat is faulty, pure and simple.
If the thermostat fails to do it's job, your compressor continues to run thus freezing your produce.
Feb 02, 2009 | Jenn-Air JCB2280HES Side by Side...
Refrigerator making noise at bottom rear when shutting down.
This sounds like a compressor motor mount problem. Unfortunately, the only way to fix this is to change the entire compressor, which is something that only a trained technician can do- they will need to drain and recharge the freon. It can cause upward of $400 or more. Fortunately, your refrig will still work if you don't mind living with that sound.
Dec 29, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Jenn Air 48" Built In Not Cooling
the company that replaced the parts also should have changed the low side line and capiliary line it comes together as one unit
the capiliary line is partialy restricted
May 15, 2008 | Jenn-Air JS48SEFXDA Stainless Steel Side...
Jenn-Air JCD 2295 Refrigerator
I would say the cold control may be bad.If the fridge is getting too cold it sounds like the control is not shutting the unit down when it gets to temp. You can check the cold control with a OHM meter and see if it is working properly. If it is not you will need to replace it and your refrigerator should work fine.
Jul 15, 2007 | Jenn-Air JCD2290HES Side by Side...
Jenn-Air JCD2295KE Side by Side Refrigerator Logo
640 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
