Question about HP Pavilion dv8000z Notebook
HP Pavillion a1017c will not accept recovery disks provided by HP
My hard drive for my HP a1017c died. I installed a new Western Digital 250GB hard drive, formatted it with the data lifeguard tools disk, and attempted to utilized the HP recovery disks provided with my computer. The recovery starts, and when it gets to the recovery main screen, I "press any button" and get an error message that states that those disks are only for use in an HP Pavillion computer. Well duh, this is what it still is. It just has a new hard drive. How do I get past this?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
In some instances parts of the recovery software or the computer identity are stored in a hidden partition of the original hard drive. Since the original hard drive is now faulty, there would be no way to recover them. One manner of addressing this issue is to use an OEM Windows installer. You can borrow one from a friend and use the CD key or Windows numbers printed on the sticker at the rear or side of your computer. Thereafter, drivers may be installed from the recovery CDs or downloaded from the HO Support page assuming that the networking is already functional.
Good luck and thank you for using FixYa.
Posted on Jan 30, 2009
    Genius:
  • 2,035 Answers
Well if this new hard disk you cannot recover the data because its stored in the old hard disk and data recovery is only possible in that hard disk ..You need to install fresh OS in the hard disk inorder to work on the computer ..
Good luck....
I have a w.d. external HD all my files is gone, so how can i get it again? but if i check the propeties the used space is it there.. so how can get back again?
To recover your WD files, please follow the below steps:
First thing first - STOP using your WD drive immediately! If you continue using the disk drive, you significantly increase the risk that the files you want to recover will be lost forever due to overwritten. Every new file or action will take up more "free space" and reduce your chances of retrieving your deleted files from WD. So really, you need to act quickly.
The next step - get a good HDD data recovery software to retrieve the data as most as possible.
Learn more from: http://www.western-digital-data-recovery.com/
Jun 05, 2011 | Western Digital WD Passport 250GB Portable...
Western digital 250 external - not opening
you can try some data recovery software. You can see
http://www.asoftech.com/adr/
It tells the steps how to perform data recovery.
If above does not work, you may have to format the hard drive (use quick format), and then use above mentioned software to scan again the hard drive and recover your files.
Nov 11, 2010 | Western Digital WD Passport 250GB Portable...
Why wont my Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive work?
Several possibilities:
* bad USB port in your computer (try another USB port)
* messed-up copy of Windows (try connecting to a different computer)
* damaged USB cable between computer and the Passport (replace it)
* bad disk-drive inside the enclosure (replace it)
* bad USB-to-disk-drive adapter (buy a new "empty" enclosure)
Check the warranty on it, to see if W.D. will replace it, at minimal cost to you. If the warranty has expired, W.D. has a "Customer Loyalty" program -- buy a new Passport through their web-site, and you qualify for a discount on your purchase.
Oct 30, 2010 | Western Digital WD Passport 250GB Portable...
Hello sir, i recovered some imported data from my corrupted hard disk (WD2500js) but after that i could not install the windows on it. I have partitioned it three times but didn't affect. i think i need a...
I think that your disk-drive is about to "die", and the symptom of not being able to install Windows (which tries to write many files onto the disk) is a strong indicator.
Is the drive still under warranty? If so, W.D. will give you a free replacement. If not, W.D. has a 'Customer Loyalty' program -- buy a new disk-drive from their web-site, and get a discount.
Oct 25, 2010 | Western Digital WD2500JS 250GB SATA2...
What is the max hdd capacity I can install in a HP ZD8000 laptop?
Your computer uses ATA drives which topped out around 250MB simply because manufactures switched over to SATA drives. It is a pain to change out disks on laptops since you can only have one internal drive. You then have to reload everything.
Here is one I found: Western Digital Scorpio Blue WD2500BEVE 250GB 5400 RPM 2.5" ATA-6 Internal Notebook Hard Drive -Bare Drive
  • 250GB
  • 5400 RPM 8MB Cache
  • ATA-6
I'd consider one of the external USB disks instead to store your data, pictures, etc. You could then put it on your desktop or on a new notebook.
Sep 16, 2010 | HP Pavilion zd8000 Notebook
HP Pavillion DV9000t ''Unrecoverable error has occured''
The recovery disk is defective so the install is bad. Install using another disk (even a generic retail one of the same type will do) and your key.
Jul 14, 2010 | HP Computers & Internet
If the disk drive of my WD portable drive failed, can I recover the data?
yes, you can connect disk drive to another computer, and then use some data recovery program to recover your files. you can download this file recovery software called asoftech data recovery that helped me before
http://www.softpedia.com/get/System/Back-Up-and-Recovery/Asoftech-Data-Recovery.shtml
May 03, 2010 | Western Digital WD Passport 250GB Portable...
Installing new sata drive in HP pc
a clean xp installation does not recognize sata drives at all. you can either use nlite to build a custom install cd, press f6 during setup to load additional drivers, try to change your sata mode from native to compatible in your bios or use your restore cds.
Mar 18, 2009 | Western Digital WD2500BEVSRTL Scorpio...
Western Digital 250GB External Hard Drive not working
there are a couple of reasons for this. Likely the drive has not been setup in Windows. Hard drives need to setup in Disk Management. Disk Management can be found under Computer Management in the Control Panel. After you run Computer Management, expand the Storage tab and Disk Management is located there. At the bottom of the screen threre is a listing of all drives (hard and CD) located in or attached to system... You will see your new drive listed, but not active. Right click on the new drive in the bottom window and Windows will prompt you on how to configure the drive. You'll need to activate so Windows can assign a drive letter to the drive, partition and format. Once this is done, you will be able to see and use the drive under windows.
I've attached a link from Western Digital that provides their FAQ response to your issue.....
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1017&p_created=1055796499&p_sid=7R8631pj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTQsMTQmcF9wcm9kcz0yMjgsMTAxLDIxOSZwX2NhdHM9JnBfcHY9My4yMTkmcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PXJlY29nbml6ZWQ*&p_li=&p_topview=1
You didn't mention what type of connection it uses (USB, etc). According to Western Digital, if you have a USB External Drive, you should get a prompt to install drivers by Windows when a new device is installed. Similar for Firewire device.... Did Windows "recognise" the new device by opening a New Device Found window? If not, try using a different USB port and/or ensure the USB port is enabled in WIndows.... The Quick Start guides for all models can also be found from the link provided above.
Jan 24, 2009 | Western Digital 250GB MyBook External USB...
HP Pavilion dv8000z Notebook Logo
42 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
