Question about Kenmore 22422 Top Load Washer
Removing Back Panel of Kenmore Washer Model 11020902990
I'm trying to remove the back panel of the Kenmore Washer model # 11020902990. The spin cycle no longer works. I'm thinking belt replacement, but I can't get the back panel off.
  • oliverjno May 05, 2009
    I have same problem but yeah how do you remove the cabinet?
    Problem Solver:
  • 7 Answers
If its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
Posted on Jan 30, 2009
MODEL 110-24722300 KENMORE WASHER. LID SWITCH DOES NOT WORK AND HAS COME LOOSE. HOW DO I PUT IT BACK TOGETHER?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11024722300/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet. See the Sears diagrams on the control panel and cabinet to see where / how the switch connects.
Nov 24, 2010 | Kenmore 22422 Top Load Washer
I have a Kenmore model # 13212200 it will agitate but will not drain or go to the rinse or spin cylces. I have tried by closing the lid as well when trying to got the next cylce. Is it my control panel?
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11013212200/0582/0153200?pathTaken=
Oct 26, 2010 | Kenmore Washing Machines
My washer won't spin or drain, but it will wash
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Jul 11, 2010 | Kenmore 22422 Top Load Washer
DOES NOT SPIN WHEN GET TO THAT CYCLE
May 17, 2010 | Kenmore 22422 Top Load Washer
Kenmore model 2072290 top load washer machine
http://www.searspartsdirect.com/partsdirect/getModel!retrieveModelDetails.pd?modelNumber=11020722990&productCategoryId=0153200&brandId=0582&brandDeion=KENMORE&modelName=AUTOMATIC-WASHER
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If it works, the Lid Switch is a relatively inexpensive part.
Jan 14, 2010 | Kenmore Washing Machines
I have a Kenmore 3.5 washer model # 44152. The washer is going through all the cycles but for the final spin it does not spin. Thus leaving the clothes sopping wet. What is wrong?
Is your pump clear? Nothing is in the pump blocking it? Does it drain ok? Check out your pump buy removing the bottom panel..Then check you drain hose where ever it is draining into, make sure drain isnt tp far into drain, or sink becausewater will syphen back into washer...try checking these simple checks first. i think your pump has a screw in type plastic cap. unscrew and check if you have anything in it and nothing is restricting the inpeller. spin the impeller with you finger make sure it spins around freely. you will feel some tension from the magnitation it is getting. but yeah, try these simple checks first and see what happens....
Jul 31, 2009 | Washing Machines
Model 23832 Spin cycle doesn't spin
I believe this is the direct drive model. Your clutch is slipping. There is a quick easy fix available that I have used in the past. Remove cabinet from washer. Make sure you know the easy way to do this... 2 screws on top back of washer and 2 holding control panel. cabinet tips toward from of unit and off. Real easy... Remove wire harness from motor under basket. Remove 3 screws holding motor to basket. Remove agitator inside basket. 1 screw holds it in place. Remove entire motor and shaft from unit. Clutch is attached to shaft on top of motor. Pinch spring to remove clean everything with alcohol. Insert #10 washer between cup and spring to give a little more tension. Replace and viola.... all should work well.
Jul 10, 2009 | Kenmore 23822 Top Load Washer
Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore 22422 Top Load Washer Logo
1,932 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
