Question about Lexmark 2381 Plus Matrix Printer
I have a 7 year old Lexmark 2381plus dot matrix printer. Recently, the print on the last page of the 3 part form has become very hard to read (very light). I changed the ribbon and have the form setting as high as it will go. No luck. any ideas? thank you
  • 85 Answers
Since the top copy where the ribbon is used is ok, problem is with the printhead. You could try moving the printhead closer, but will risk paper feed problems/paper jam
Posted on Feb 15, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
It would seem you posted twice.
Based on your description, the printer is working, it is not a form issue, the printer head is good, an adjustment might be needed and it works, there is no reason to replace the Lexmark 2381plus printer even if it is 7 years old (not unless you would want to).
To the faint printing on the last of the 3 pages:
  • the take-up spool/wheel drawing the ribbon is not working (most likely). The ribbon is not moving hence the printer head is not striking fresh ribbon area. Check the ribbon cartridge, it may be stuck or the driving spindle where the ribbon's take-up spool/wheel locks into. It may need a bit of cleaning and/or lubrication;
  • the printer head is slightly adjusted away from the paper. Normally, there is a mechanical lever/adjustment that sets how many paper & duplicates are fed. Adjust for 1 only.
Good luck and thank you for using FixYa.
Posted on Jan 30, 2009
Skips pages while printing
check the page length set on printer/ system/print server in printer & fax
Jul 26, 2013 | Lexmark Forms Printer 2590 Dot Matrix -...
How do I print from ipad 2 to z2400
i would download a decent printing app like print n share from the app store?
Dec 16, 2012 | Lexmark Forms Printer 2400 Series...
We had a power failure and now our Lexmark 2391 dot matrix printer will not print from the top of the page. i need to know how to setup/reconfigure the top of the page? thank you
  1. Push the ALT button and then the PARK LOAD button to back the paper out.
  2. Push the PARK LOAD button to reload the paper. The Ready light should now be blinking.
  3. Use the MICRO up or down buttons to adjust as needed, making sure that the top of form is set on the very first page that enters the printer. Typically, the top edge of the first sheet of paper should be even with the ribbon.
  4. When the page is lined up properly, press the START/STOP button. The printer will record the current position as the top of form and then feed paper to the tear off position.
  5. Use the MICRO up and down buttons to place the top of the paper at the tear off bar.
  6. After the tear off is positioned properly, press the START/STOP button twice to save the tear off position.
  7. Test the positions with a sample print job. If the alignment is still off, follow this entire procedure from the beginning again as needed.
Aug 08, 2011 | Lexmark 2391 Plus Matrix Printer
Poor Print Quality
the print head has a series of pins that shoot back and forth striking the ribbon and placing a dot on the page, a series of dots create a letter etc. one pin is not working correctly. it could be the head but try re-instal drivers to eliminate that as a cause. if the line persists then i'm afraid it may well be the head to be replaced. good luck
Apr 06, 2010 | Panasonic KX-P3123 Matrix Printer
I have poor print quality on my Lexmark 4550
That obviously shouldn't happen. Did you print an alignment page after you inserted the new cartridges? There could also be some clogged nozzles on the new cartridges. If you haven't contacted Lexmark technical support through www.lexmark.com, suggest you do so.
Aug 05, 2009 | Lexmark X4550 Multifunction Wireless Color...
P2023 prints garbage with vista
Did you get the Vista driver for your machine from Panasonic? If not, it may not work. I use VM ware and run windows xp in virtual machine in order to use some of the older drivers.
Jul 30, 2009 | Panasonic KX-P2023 Matrix Printer
Dot matrix printer. very light print on last page of form
Jan 30, 2009 | Lexmark 2381 Plus Matrix Printer
Epson DFX-9000 dot matrix printer not printing far right column
It probably is a margin setting. Can you try printing on a blank w-2 and preview it before printing. That way you should be able to adjust the margin as needed.
Jul 30, 2017 | Epson DFX-9000 Dot Matrix Printer
Tally printer form feeding continually on its own
When was the last time it was services? It may be nothing more than a dirty paper sensor. Also, some Tally printer sensors require adjusting, it may be a simple matter of adjusting a sensor setting. That would require a technician with the manual and settings chart. Let me know how it goes!
May 01, 2007 | Tally T6215 Matrix Printer
Lexmark 2381 Plus Matrix Printer Logo
170 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
