You almost certainly have a bad lock motor & latch assembly. Please provide model & serial # if you'd like more help, and with more detail on exactly what it will take to repair the oven.
My name is Peter. I am a retired field service appliance technician.
1.) Obtain your model number. It is located on a metal plate on the face of your oven when you open the door.
2.) Go into the Sears website below. Input your model number (on the left). You will receive diagrams and part numbers. Select the door latch assembly. Record the part number.
3.) Input the part number into your computer sear engine and search best price and purchase.
4.) Go into the below video website for instructions on how to repair.
The main control and door latch are not talking to each other without testing impossible to say which one on the latch assembly there are micro switches which have contacts that are open or closed depending on latch position this tells the control the position when you power up the door locks the unlocks try a latch assembly first
Error code F5 indicates that there is an issue with the
door latch switch assembly; if the switch tests open then the door lock
assembly should be replaced. Hope this helps...please post back for further
assistance.
Based on your description, the E1 F5 error code likely indicates that the door latch is not operating.
Make sure that the oven door is closed when you start the Self Clean cycle. Check the door switch to see if it is apparently operating properly. Open the oven door and the oven light should turn on. Press in the door switch plunger and the light should turn off. If the light switch is not operating properly, it could cause this type of problem.
If the light switch is operating properly, then you could have a failed door latch assembly. A wiring failure or a problem with the control board could also cause this failure. I recommend that you unplug the range and access the door latch assembly at the back of the range. Pull the upper and lower back panels off of the range. Caution: The edges on these panels can be sharp. Protective gloves are recommended. With the panels off, check the wire harness connections on the door latch assembly.
Hello,(1)Open the door and remove the two screws in the door lock latch
plate on the edge of the door by backing them out with a Phillips
screwdriver in a counter clockwise direction. (2)Remove the two
screws (located on the interior lock face plate)holding both halves of
the lock assembly to the door by backing them out with a Phillips
screwdriver in a counter clockwise direction,pull each side of the lock
assembly from the door,using a flat blade screwdriver to pry them off
if needed. (3)Pry the latch bolt out of the door by inserting the edge
of a flat blade screwdriver under the latch plate on the edge of the
door.slide the latch assembly out and set aside.(4)Insert the new latch
assembly into the hole left by the old latch bolt.Trim the recessed
opening with a sharp chisel if the new lock latch plate is larger than
the old latch plate.Secure the latch to the door with the two screws
provided by turning them in a clockwise direction with a Phillips
screwdriver.(5)Hold both side of the new lock assembly to the holes in
the faceof the door.Line up the shaft from the lock cylinder into the
slotted hole in the latch assembly.Make sure the lock face plate with
the screw holes is facing the inside.Attach the lock assembly to the
door by turning in the screws with a Phillips screwdriver in clockwise
direction.(6)Remove the old striker plate from the door jamb by
backing out the two screws with a Phillips screwdriver in a counter
clockwise direction.Install the striker plate that came with lock kit
with the screws provided using a Phillips screwdriver in clockwise
direction. (7)Close the door and test the operation of the lock from
the inside and outside using the turn lever and the key.Make adjustment
to the striker plate if needed by removing the holding
screws.Reposition the striker plate and replace the screws
Hi. The unit is programmed to not operate,or heat, when there is a serious fault within the door latch assembly. This F-9 code, represents a failed door latch assembly. This device must be replaced. Once replaced, the unit will operate correctly.
NOTE_ Try to reset the mechanism. This can be done by shutting down the power, or unplugging for five minutes. Once the five minutes have passed, simply, re-introduce power to the unit, and observe. if the error code returns, replace the door latch assembly.
F5
E0
E1
DOOR AND LATCH SWITCH DO NOT AGREE
DOOR LATCH NOT OPERATING.
PROCEDURE: Before proceeding, press OFF, OFF, START to enter
the Diagnostic mode and verify the error codes.
TO VERIFY DOOR SWITCH:
A. While in diagnostics, open the oven door. The second digit on the clock display
should toggle between “1” and “0” as the door opens and closes. When door is
closed display should show “1”, when the door is open display should show “0”.
If the second digit on the clock display did not toggle, go to step B.
If the digit did not toggle after replacing the door switch, go to step D.
If the digit did not toggle after replacing the door switch harness, go to step F.
B. Unplug oven or disconnect power.
C. Replace door switch. (If door switch is integral to the door latch motor
assembly, replace the entire door/latch motor assembly). Go to step H.
D. Unplug oven or disconnect power.
E. Check the integrity of the harness wires and connections between the
appliance manager and the door/latch assembly. Ensure there are no shorted
or pinched wires.
If the wiring harness is pinched or damaged, replace the door switch harness.
Go to step H.
If wiring harness is good, go to step H.
F. Unplug oven or disconnect power.
G. Replace appliance manager. Go to step H.
H. Replace all parts and panels before operating.
I. Plug in oven or reconnect power.
J. Press OFF, OFF, START to reenter the Diagnostic mode and complete checks.
Repeat step A.try this lighting may have knocked either the door switch or latch motor out
The latch assembly should have a switch on it to indicate whether or not the door is open. Press in or sideways on the latch arm to simulate a door closed condition.
