Question about Fellowes SB95C Cross-Cut Shredder
Shreds halfway, then stops. Fellowes SB-95C
I feed a sheet in and it shreds down about halfway and then just stops. I have cleaned it, oiled it and still same problem.
  • LindaBailes Feb 17, 2009
    We must manually turn the switch on and then we can shred about one page before the machine stops and the red light goes on. Then we have to manually turn the switch on and hold it while we do another sheet. There is no "automatic" feeding of paper with this unit.
    There is plenty of room in the basket and the motor is not overheating.
On the underside of the shredder, at the top of the space where the cuttings box is, there are 2 sensors, 1 at either end of the shredder blades. it sounds like these sensors could be either dirty, or defective. try to clean these with a cotton bud or similar. it may need new sensors, bu it is worth a try!
Posted on Feb 05, 2009
Yellow light comes on
Look at the manual in the link below. If you do not find the answer, call Fellowes.
Fellowes Shredder Manuals
Sep 18, 2014 | Fellowes FEL-3011001 DS-1 Light-Duty...
What causes the Fellowes Powershred SB-15C shredder to show that it's full when it isn't?
Check and make sure there is no paper or paper dust covering the Bin Full sensor. underneath the head.
Aug 03, 2014 | Fellowes Office Equipment & Supplies
Fellowes S8-95C is full, but can't get it open. Help!
I was able to pull really hard and open the bin 1-2". I turned the unit on its side over the trash can and some shreds came out. I alternated shoving a sturdy metal rod inside (first an aluminum architectural ruler then the longer handle of a squeeze clamp) to loosen up the shreds and tipping the machine on its side to get some loose shreds out. After doing this enough times I was able to dislodge the dense clumps and remove the drawer. Now that the machine is empty there is a red light on and it does not shred.....UPDATE: turns out somewhere along this rough process (paper was in rock solid clumps) a small piece of the door that presses the "door closed" switch broke off. Jammed a piece of cardboard in there and it shreds again, although it does not automatically turn off when the door is open.
Jun 30, 2011 | Fellowes SB95C Cross-Cut Shredder
My Fellowes shredder DM17Cs won't stop running unless shut off
Blow some canned air down into the feed slot to clean the sensors.
Nov 20, 2009 | Fellowes Powershred DM8C (Confetti)...
The Auto-On switch does not work. I have to manually turn the shredder on and then feed paper into the slot. It feeds and shreds the paper just fine, but I have to manually turn it off to stop it. All of...
There must be an auto-on/off sensor in the middle of the paper entrance slot - either mechanical or optical.It needs to be cleaned from any obstructions like paper chads or paper dust.It this doesn't help,the sensor maybe defective and it needs to be replaced.
Oct 02, 2009 | Fellowes Powershred SB-87Cs Shredder
I have a DM8C that only runs for a couple of seconds at a time and then it stops. Toggle the switch back and forth and it feeds a little at a time until the page is completely shredded. It works okay in...
Common solution is to clean upper and lower sensors with cotton swab. If it still jams, then you will have to remove the top carefully and clean all paper shreds out of the housing. The paper shreds are most likely packed in the housing shroud and jamming or overloading the motor.
Jun 21, 2009 | Fellowes DM8C Cross-Cut Shredder
Overly loud shredding; stops prematurely
I have taken many shredders apart and found them so clogged up with shreds of paper and too much oil will turn into paper mud.Be bold and take the top off and clean it out. Unplug the power source and when removing the top , be careful because their will be a short cable connecting the top to the circuit board. Easy to damage.
May 12, 2009 | Fellowes S701CM Shredder
Novitech shreader
I have the Fellowes shredder oil. The bottle has ABSOLUTELY NO instructions on how to use it.
I used to drizzle oil in on the cutting blades through the feed slot on top, grumbling all the while because it was so messy.
Then I got this tip: Once a week squirt oil on sheet of paper that will be shredded. Do 3 or 4 sheets.
Or do it each time the machines stops for its cool-down period.
I run the oily shreds into a separate bag because I recycle my shredded paper and want to keep it clean.
Jul 31, 2008 | Fellowes DM15C Shredder
Fellowes SB95C Cross-Cut Shredder Logo
922 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
