Question about Fuji FinePix F420 Digital Camera
Focus error Until last week it was working well. Unfortunately I dropped my camera, and since then it is not working. Whenever I try, it gives the message "Focus error". And when I try to close it, the lens does not close properly. ANy solution? Please.....
  • 4 Answers
It sounds like you've either broken the focusing motor or sheared the connecting gears. Though the latter is less serious (and cheaper to fix) both require the camera to be sent off to the repair man. Good luck!
Posted on Jul 28, 2007
Getting an zoom error on my fuji film finepix z90, what can i do?
Lens errors (zoom errors on Fuji's) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 25, 2011 | Fuji FinePix S304 Digital Camera
I have a Kodak easyshare c183 camera but whenever I try to turn it on it says, lens obstructed and then turns off. How do I fix this?
Jun 21, 2011 | Kodak C183 Digital Camera
My Nikon S230 says lens error when i turn it on. It trys to focus but then it closes again and says lens error on my lcd screen. What can i do?
Jun 14, 2011 | Nikon COOLPIX S230 Digital Camera
When the camera (Nikon Coolpix S3100) is turned on the screen soon goes black and there is an error message that reads "Lens error". This camera is almost brand new! Should I just return it?
Yes, try returning it first. If less than 30 days, AND you didn't drop this camera, your store should accept it for exchange or refund.
But in the case that your store gives you a hassle and directs you to the vendor under warranty, AND the vendor refuses to repair the camera saying it has dirt accumulation or was dropped, see the following:
Jun 05, 2011 | Nikon Cameras
My daughter(5) dropped it and when they turned it on the lens came out and won't go back in.And on the screen it say "Focus Error".Can it be fixed or should I get her a replacement?
Lens errors (focus error's on Fufi's) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Dec 24, 2010 | Fuji FinePix A500 Digital Camera
Focus error on camera wont take pictures wont put
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 12, 2010 | Fuji FinePix A500 Digital Camera
Fuji finepix f50 camera was dropped with lense out, and now wont return. it also says focus error on screen. I have the same problem and Fuji want £88.00 to repair it - you can buy a new camera for...
Unfortunately dropping this model, and the f40, 45, 47 fd models, is suicidal for the camera. The lens has an inner slide ring which other models do not have and this ring has three lugs to keep the lens from spinning when powered up and used. Unfortunately these lugs are also clips which hold the focus lens inplace. These are tiny. hard to repair
Feb 13, 2009 | Fuji Finepix F50FD Digital Camera
Lens Error
well don't play with ur lens on ur own give it to the ppl they will repair ur lens and give them a phtocopy of ur warranty card.
But yes if the problem persists thats is the test they do after repair they might cahe ur camera .....But there are slime chances for an exchange
Jan 05, 2009 | Nikon COOLPIX L18 Digital Camera
Finepix A300 focus error
Check out this link: www.digitalcamera-hq.com/digital-cameras/fuji-finepix-z1_question.html?qid=4289
After the basics (cleaning the lens, replacing the batteries, etc.), try dropping the camera on a carpeted area from about 2-3 feet. It worked for my Fuji A500 and 90% of the responders on the link. Everything on the web said it would cost ~$100 to fix. I was in the process of researching new cameras to buy and had nothing to lose by dropping it on the floor.
The error may be caused by debris in the zoom mechanism preventing it from working. Dropping the camera loosens the debris and voila!
Jun 11, 2008 | Fuji FinePix A500 Digital Camera
Fugi FinePix A330 Focus Error
i think that the focus is no good, probably dropped it. it happen to me before.
Feb 06, 2008 | Fuji FinePix A350 Digital Camera
Fuji FinePix F420 Digital Camera Logo
204 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
