Problem for Dell Dimension 4550 PC Desktop
BOOT.INC default= signature
I removed old hd installed new one . Hd has been picked up but can not boot from any drives BOOT.INC default= signature(782dcdc)
Comments:
Jan 30, 2009
- i did reinstall my windows xp home with my installation cd and also my drivers. I then updated everything. Jan 30, 2009
- No apologies required ... I didn't do enough research on hd installation and now I am in a mess..heres what I did . When I got the new hd it didn't come with instalation cd so I didn't realize I needed it to be able to format hd, anyway after a couple of sleepless nights i was able to get comp. to reconize hd. I updated all my drivers,had a blue screen errordriver IRQL-NOT-LESS-OR EQUAL,finally got through that...... now I can not format hd. I can not re-install windows because my installation cd is older than what i have running .alot of my programs are not running correctly and in bios ini goes like this:
default=signature(78cdcdc)disk(0)rdisk(0)partion(1)\windows
{operation systems}
signature(78c2cdc)disk(0)rdisk(0)partition(1)\windows=microsoft windowsxp home editin\fast detect
I have tried to re-install using microsoft download to a floppy but I am getting bad sector error can not complete.. I am not that familiar with all this programing stuff just stubborn ha ha . there has to be a fix for this..Jan 31, 2009
- figured out the promblem I could not re-install because I had downloaded sp 2 and my installation disk was sp 1 once I removed sp2 was able to re-install also my virus program was keeping my floppy from working. tnks for all your help....
Best Solution
posted on Jan 30, 2009
Rank: Master
Rating: 91%, 13 votes
Your old hard drive contained files used by the OS, as well as the OS itself. If you replaced that HD with another, and did not clone your existing install onto the new HD, then there is no boot record, nor is there anything to boot. It is not possible to just swap a HD and expect it to work without either cloning the old drive or performing a fresh install of an OS. The fact that it is detected by the BIOS is good, as you can install a new OS onto the new drive, or use a program like Ghost to clone your old drive's contents onto the new drive.
Comments:
Jan 30, 2009
- My apologies, rosemarie... you did not make clear that you had indeed re installed your OS.
So are you saying that you were able to install a new clean OS onto the new HD, and apply all the relevant Windows Updates to that new installation, but at some point since then, you have not been able to boot from the newly updated installation?
Jan 30, 2009
- A bad sector on the Hd can be a lot of trouble, sometimes meaning that the drive is in fact, no good. Have you set your PC to boot from the Windows cd? If not I would suggest you do that by going into your BIOS, and setting the CD ROM as the first boot device. Then I would boot the pc, and while Windows is loading files, look for and option to hit a key to repair your computer. I think it's F2 or something similar. Once in the repair console, you should run a program called chkdsk.exe /r
This will scan for and attempt to recover and trepair any bad sectors on the HD.
If that doesn't work and you are still getting a bad sector error, I would have to say that the HD itself if broken, and will need to be replace. It is not uncommon to get a faulty drive nowadays.
Good luck and feel free to ask if you have any more questions.
Popular Solutions for Dell Dimension 4550 PC Desktop
Questions and Unsolved Problems for Dell Dimension 4550 PC Desktop
Do you recommend Dell Dimension 4550 PC Desktop?
my pendrive is not working properly whenever i double click on it , it shows u want to format it but...
(More)
my pendrive is not working properly whenever i double click on it , it shows u want to format it but when i click yes it is not getting formatted
Need to separate main case to repair DC socket. Cannot find last screws? around socket. Seems 2...
(More)
Need to separate main case to repair DC socket. Cannot find last screws? around socket. Seems 2 halves are glued together? Can you supply a disassembly instruction pdf, or a sevice manual?
have an older jiffy ice auger its starts, but does not stay running. when i start it, it runs and...
(More)
have an older jiffy ice auger its starts, but does not stay running. when i start it, it runs and while running i push the primer and it stays running. then when i stop pushing the primer it stallss. how do i fix this
don,t write DWD-R+R-RW disk SH-S222A WinXP3, CD-R,RW ok ...
(More)
don,t write DWD-R+R-RW disk SH-S222A WinXP3, CD-R,RW ok Тип компьютера Компьютер с ACPI Операционная система Microsoft Windows XP Professional Internet Explorer 6.0.2900.5512 DirectX 4.10.0.18000 (DirectX 10 Дата / Время 2009-12-17 / 20 Системная плата Тип ЦП Intel Pentium 4, 1978 MHz (18 x 110) Системная плата DFI NB72-SC/SR (5 PCI, 1 AGP, 1 CNR, 3 DIMM, Audio) Чипсет системной платы Intel Brookdale i845 Системная память 512M 133MHz Тип BIOS Award Modular (11/14/01) Коммуникационный порт Последовательный порт (COM1) Коммуникационный порт Последовательный порт (COM2) Коммуникационный порт ECP порт принтера (LPT1) Отображение Видеоадаптер NVIDIA GeForce4 Ti 4200 with AGP8X (128 Мб) Видеоадаптер NVIDIA GeForce4 Ti 4200 with AGP8X (128 Мб) 3D-акселератор nVIDIA GeForce4 Ti 4200 with AGP8X Монитор Samsung SyncMaster 703(M)s/750(M)s/753(M)s/MagicSyncMaster CM173A(M) [17" CRT] (HSBX208190) Мультимедиа Звуковой адаптер Realtek ALC200(P)/ALC201(A) @ Intel 82801BA ICH2X - AC'97 Audio Controller [C-0] Хранение данных Контроллер IDE Intel(R) 82801BA Ultra ATA Storage контроллер - 244B Контроллер хранения данных A2CH9WBD IDE Controller Дисковый накопитель ST380011A (80 Гб, 7200 RPM, Ultra-ATA/100) Оптический накопитель GG3924Z UGQ028O SCSI CdRom Device Оптический накопитель TSSTcorp CDDVDW SH-S222A (DVD+R9:16x, DVD-R9:12x, DVD+RW:22x/8x, DVD-RW:22x/6x, DVD-RAM:12x, DVD-ROM:16x, CD:48x/32x/48x DVD+RW/DVD-RW/DVD-RAM) Статус SMART жёстких дисков OK Разделы C: (NTFS) 12000 D: (NTFS) 64307 Мб (41374 Мб свободно) Общий объём 80000 Ввод Клавиатура Стандартная (101/102 клавиши) или клавиатура PS/2 Microsoft Natural Мышь PS/2-совместимая мышь Сеть Первичный адрес IP [ TRIAL VERSION ] Первичный адрес MAC 00-21-91-91-05-7B Сетевой адаптер D-Link DFE-520TX PCI Fast Ethernet Adapter (192. [ TRIAL VERSION ]) Периферийные устройства Контроллер USB1 Intel 82801BA ICH2X - USB Controller 1 [C-0] Контроллер USB1 Intel 82801BA ICH2X - USB Controller 2 [C-0] DMI DMI поставщик BIOS Award Software International, Inc. DMI версия BIOS 6.00 PG DMI производитель системы DMI система DMI системная версия DMI системный серийный номер [ TRIAL VERSION ] DMI производитель системной платы DMI системная плата i845 DMI версия системной платы DMI серийный номер системной платы [ TRIAL VERSION ] DMI производитель шасси DMI версия шасси DMI серийный номер шасси [ TRIAL VERSION ] DMI Asset-тег шасси [ TRIAL VERSION ] DMI тип шасси Desktop Case DMI всего / свободных сокетов памяти 3 / 1
don't get the contol wires like LED+ and LED- I have a DELL DEMINSION 4550 Motherboard and the fan...
(More)
don't get the contol wires like LED+ and LED- I have a DELL DEMINSION 4550 Motherboard and the fan won't woke I have no disc drives or floppy, just a harddrive and the fan also the motherboard on a 250W psu FAN won't work HELP!!!!!!
