Question about Whirlpool Duet GHW9150P Front Load Washer
Washing clothes all day have an F35 flashing
Whirlpool duet frontloader washing machine..washing clothes all day ..went up to check and it was flashing a F35 on screen and will not let me open door even after poushing cancel button
  • 750 Answers
F35
ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer
component detected by the Steamer Electronic Board.
Possible Causes/Procedure
1. Check if pressure hose is fixed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
Check these problems.
Plesae leave a solved rating before you leave the site
Posted on Jan 30, 2009
    Scholar:
  • 79 Answers
The water level sensor or analog pressure sensor (APS) could have failed. I've seen these fail where you replace them and the machine works correctly.
Another cause for the F35 and SUD error could be your CCU (control unit). There are components that seem to fail over time and cause the F35 and SUD errors. You can replace those components yourself now...
See f35error.com for more information.
I hope this helps,
Jeff Hartman
"The Neptune Man"
Posted on Jul 10, 2015
Duet GHW9150P Front Load Washer: F35 keeps flashing clothes are wet, when I turn of...
Check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Suds and F35 keep shuting down my laundry day:(
Remove the service panel and see if the filter has something in it77cb04b.jpg2402fad.jpgf032166.jpg
May 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code washing is delayed wil wash half the clothes
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 06, 2010 | Whirlpool GHW9300 Duet Washer
Whirlpool Duet -Sud displays and washer stops
I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F35 flashing
if it is less than one year old call for service it should be covered. if not take the kick panel off and locate the tech sheet it is either in the kick panel or in the cabinet to the right. it will give you a list of error codes find out what it means and let me know thanks
Jun 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL FRONTLOAD WASHER
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@@@@
Apr 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
530 people viewed this question
Dan Webster
Dan Webster
Sal De
