Question about Nintendo DS Console
Ds wont turn on
I replaced the upper lcd on my grandsons ds when you turn it on the green lite comes on and then back off the lower screen flashes but noyhing else isit possible to buy the circuit board that the cables attach to?
    Problem Solver:
  • 10 Answers
Yes and is it charged if so buy the circuit board.
Posted on Feb 15, 2009
NDS lite has the power(green lite flashes), but screens wont lit
When you switch the DS lite on you should notice that one of the screens flashes... if thats correct then the screen that doesn't flash is the one that will need replacing which, I would assume is the upper screen as judging by what you say has a damaged ribbon.
Regards,
SOD69
Feb 10, 2010 | Nintendo DS Lite Console
I replaced the top lcd screen on my son's Nitendo DS lite and now when I turn it on the bottom screen flashes and shuts off. What is wrong with it?
Hello!
The bottom screen flashes because something is still wrong with the upper lcd
Make sure you didnt put a rip in the upper lcd. The smallest rip will mess it up.
Also, make sure the cable is in completely.. If its off the slightest cm , it'll cause the lower lcd to blink which causes the DSlite to not work
Dec 29, 2009 | Nintendo DS Lite Console
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
Wont turn on
I'll quote GBATemp here:
symptom:
the ds lite powers up for a brief instant, but then shuts off
potential solution:
disassemble the lower shell and check the connections of upper and lower displays (all three flexible cable connections).
You can view the full and detailed guide here:
http://gbatemp.net/index.php?showtopic=98240
GMAC
Jun 14, 2009 | Nintendo DS Lite Console
Unit not powering up
You have a defective LCD screen that makes a short circuit (thats the flashing green led)
Mostly the upper LCD screen is the problem.
You cab replace the LCD screen by buying one (ebay) and use a manual found on youtube but you need to have the skills. If not, please find someone that can repair it for you
Apr 26, 2009 | Nintendo DS Lite Console
Nintendo ds lite flashing top screen
i had a similar problem to this, i would check the connector strap in between the two screens if it is just one pin out this can happen
Jan 25, 2009 | Nintendo DS Lite Console
Green Light Flashes
Possible you have a defective LCD screen. Could be the upper or the lower. Personally i think the upper (broken LCD Flatcable)
john
Nov 26, 2008 | Nintendo DS Lite Console
Case mod then a lose of power.
Easy solution, not so easy to fix yourself. the problem is your upper lcd screen, (yes your upper lcd), once the lcd is damaged, most likly from rolling the ribbon threw the hinge.the system will flash from the bottom screen, this is the start up screen. this i know for i've fix over 100 systems, you can have it fixed on ebay for $45.00, look under repair service nintendo ds lite (texas)
Aug 12, 2008 | Nintendo DS Lite Console
Nintendo DS lite
Baakie,
You turn de DS Lite on, the green light flashes and the unit turned of. Is that correct?
The DS Lite checks some things before he starts-up. One of these things are the screens. the DS sends a signal to it and expect an answer back. When this answer is not received, it shuts down.
The most common problem in these cases is the flatcable of the upper screen.
Question is, did you replaced the housing? If so, you might dammaged the flatcable of the upper screen. If not, the flatcable might be defective because of using the DS Lite a lot (open /close the unit).
So first check the flatcable of the upper screen (google and you will find manuals how to open the DS Lite but be carefull!!!!)
Second, on the mainboard are two fuses (F1 and F2) . Check these! One of them might be defective
Success
Jul 19, 2008 | Nintendo DS Lite Console
Lower screen flashes when power is turned on
That means the upper screen cable is either broken or not insert it right. If you try to insert it all the way and it still doesn't work, then you will need to buy a new top LCD to replace it. Thanks.
Aug 28, 2007 | Nintendo DS Lite Console
Nintendo DS Console Logo
44 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
